Welcome to the North American Subaru Impreza Owners Club Thursday March 21, 2019
Old 02-17-2019, 03:27 PM   #1
pazzoduc
Member#: 493859
06 WRX TD Swapped
sorta black-ish
Default KEIN Fender Braces?
Anyone have experience with the KEIN for GD Chassis?
https://www.importimageracing.com/pr...&isp_ref_pos=3
pazzoduc is offline   Reply With Quote
Old 02-18-2019, 02:33 AM   #2
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
The 2007 STI Limited braces are a little better than the stamped ones but frankly, spending more than $60 or so is a total waste of money here.
mrsaturn7085 is offline   Reply With Quote
Old 02-18-2019, 04:32 AM   #3
Ryandorres
Member#: 497878
+1
Ryandorres is offline   Reply With Quote
Old 02-20-2019, 12:05 PM   #4
pazzoduc
Member#: 493859
06 WRX TD Swapped
sorta black-ish
Cool, THX guys.
Old 03-06-2019, 06:24 PM   #5
H_wells3000
Member#: 322035
Ill disagree. Considering this is the only readily available triangular fender brace Im going to buy a set since my fenders are off.
I remember Turn in Concepts offered their front cowl braces. they were talking these things up big and they were only straight like oem but much stiffer. Tic doesnt make them anymore.
you cant get the GTspec triangular brace anymore either. this is Copied from GTSPEC
"GTSPEC Fender Reinforcement Brace for Subaru
Description:
Known as the "Gacchiri Support" in Japan or CAWL Support by SPT. This chassis reinforcement will greatly improves the handling dynamics of your car. Mounts onto the door hinge and inner fender, creating a triangular support that greatly increases rigidity over OEM. Confidence in steering is gauranteed while reducing flexing of the unibody.
Car Manufacturer: SUBARU
Application: GDA04 (04 WRX),GC8,GDBC (04 STI),GDA02 (02 to 03 Impreza Sedan),GGA (02+ Wagon)"
H_wells3000 is offline   Reply With Quote
Old 03-07-2019, 02:35 PM   #6
fartbox420
Member#: 483915
2004 wrx
They look pretty beefy. a decent welder might be able to make some at home.
fartbox420 is offline   Reply With Quote
Old 03-17-2019, 02:00 PM   #7
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
https://www.paranoidfabrications.com...-fender-braces
The GTSpec is exactly what these were copied from.
Unless the car is going to autocross/open track/time attack, the triagluated is way over kill.
the Paranoid's work incredibly well. You can definitely hear and feel the difference in the drive and when closing the doors.
And yes this would be an excellent "learning to weld" project. Here in Dallas there are lots of metal-fab companies. Stop in and ask for 3/16" plate scraps and 1" x 1" or 1x 2 scraps they have. Most Fab companies have bins upon bins of scrap pieces. then buy a Harbor Freight 110V flux-welder for $100 and make your own...
~Rob
TXwrxWagon is offline   Reply With Quote
Old 03-18-2019, 03:45 AM   #8
mrsaturn7085
Member#: 375462
WR Blue
FWIW, even stage rally cars, which take more abuse in this area than anything you'll be throwing at it, don't even upgrade this stamped steel support - they just weld it to the chassis:
Purchasing any aftermarket part for this area is a total waste of time and money, and just adds dead weight to the front end.
Old 03-18-2019, 10:09 AM   #9
fartbox420
Member#: 483915
2004 wrx
thats cool, i may do this on my car instead of replacing them.
