Welcome to the North American Subaru Impreza Owners Club Saturday July 20, 2019
Old 02-18-2019, 06:52 AM   #1
freshazphuk
Member#: 494082
2003 wrx
Default 03 wrx 5mt removal?
ok so before i yank out my hair, and yes i have read the writeup on trans removal for the car..... I am curious as to if the clutch fork pin needs to be removed to pull the trans? being that i am swapping trans out anyways and will be swapping all accessories from the current trans to the new one (ie. clutch fork, slave, and sensors) could one just leave the fork and pin attached to current trans upon removal..........i have everything pulled completely but cant seem to get trans pulled from the engine? so before i start yanking and using pry bars id like to know if the fork pin needs to be pulled in order to remove trans or if it can stay on?
freshazphuk is offline   Reply With Quote
Old 02-18-2019, 10:01 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I usually do Subaru push clutches, but I believe, yes, you need to pull the fork pin so you can disengage the fork from the ToB.
Old 02-18-2019, 10:06 AM   #3
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Yeah remove the pin and hold the fork up while separating the engine and transmission. Remove the big allen head cap, then use a bolt from the timing cover to thread into the clutch fork pivot pin to pull it.
T-37 is offline   Reply With Quote
Old 02-18-2019, 10:26 AM   #4
freshazphuk
Member#: 494082
2003 wrx
you guys are awesome!!!!! thanks for the info!!!!
Old 02-18-2019, 09:49 PM   #5
jamal
Member#: 71875
You can also use a long pick or flathead screwdriver to pop the TOB off the clutch without removing the pin but it can be a little tricky and annoying to do sometimes.
jamal is online now   Reply With Quote
Old 02-19-2019, 11:15 AM   #6
freshazphuk
Member#: 494082
2003 wrx
I got her out and new 1 in now only had a couple hours free time yesterday so i got the drivetrain handled new rear diff 1 piece DS new poly shifter bushings clutch flywheel done all new axles in new heliex 3'' TBE on, today after work i will bleed the clutch ( new steel braided line ) put the new GS intercooler on and the perrin cold air on see how she runs.....found a bunch of bs from PO that didnt seem right like some crap grounds janky wiring bunch of dry rotted vac lines and cracked tubes on turbo inlet system, So I am stoked to see how she runs now......time for accessport now lol
Old 02-20-2019, 08:50 PM   #7
freshazphuk
Member#: 494082
2003 wrx
update: I LOVE the 4.44fd!!!! this car feels totally different like it should have came with 4.44 from the factory lol I must have knocked my power steering return line loose tho....its all sorts of choppy and noisey so i think a new o ring is in order lol
Old 02-21-2019, 12:31 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Congrats on the work you did, glad it worked out.
Thanks for the update.
Based on what was posted, anything else you can think of as a tip or hint, throw it in here for the next guy.....ya know?
Old 02-22-2019, 07:04 AM   #9
freshazphuk
Member#: 494082
2003 wrx
honestly its a pretty straight forward swap over....aside from the obvious i did find that the knuckles do not have to come apart to move the cv axles out of the way just slide them back nor does the shifter need to be taken apart from interior of the car just pop the linkages......also use a block of wood to angle the engine back for easy removal and install i did the trans by myself all in all took maybe 4 hours start to finish, i lined up the trans on the lower bolts set the TOB at 3 and 9 o clock went up top stuck the fork in then slid the DS into trans rotated to get splines right into the engine and shoved her on in there....real straight forward trans swap minus the clutch fork pin ( never done a pull type before ) oh and dont be me and install starter before the slave lol
