Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Old 02-19-2019, 03:34 PM   #1
WRXnick16
Member#: 447898
2019 STI
Crystal White Pearl
Default 2015+ WRX - STI solid steering joint swap?
Has anyone installed the solid steering u-joint/linkage from the STI (part# 34170VA030) in a 2015+ WRX?
I've seen a few posts that suggest that it's interchangeable, but I haven't seen anyone post firsthand experience. I understand that it's interchangeable on older models, but wanted to verify since the newer platform has EPS.
I'd prefer to go this route and completely eliminate the rubber dampener rather than installing the Perrin steering dampener lockdown on top of it.
Thanks!
WRXnick16 is offline   Reply With Quote
Old 02-19-2019, 06:21 PM   #2
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
Thanks!
Yes I personally have. Look at my build diary. I wrote a bit about install and effects.
uofime is offline   Reply With Quote
Old 02-19-2019, 07:45 PM   #3
WRXnick16
Member#: 447898
2019 STI
Crystal White Pearl
Thanks! Your post was very insightful. I mainly questioned the fitment because all of the pictures that I looked at comparing the two linkages showed that the pinches were clocked quite differently. Your post confirms this to be the case and that it still fits.
I didn't expect a drastic change in steering feel and feedback, but it sounds like the install may be more hassle than it's worth (in comparison to Perrin's steering dampener lockdown). I'd prefer to use the OEM STI linkage since it's a simpler design, eliminates the rubber bushing, and possibly saves a few ounces.. but the install sounds less than appealing.
Direct link to uofime's install and review:
https://forums.nasioc.com/forums/sho...&postcount=109
Old 02-19-2019, 08:10 PM   #4
Boggie1688
Member#: 165955
2015 WRX Base
If it's the right length and the right spline count, then you only have to deal with alignment. But as discovered it is a total bitch.
If your off by one spline, your total steering angle is now uneven side to side. For simplicity sake, imagine the wheel can only turn 360 lock to lock. This is one full turn. Center is at 180, full counter 0, full clockwise 360. Now imagine there are 36 splines on the shaft. That means each spline equates to 10 degrees.
Get the install off by one spline, and you steering shifts 10 degrees clockwise or counter clockwise.
There is a steering angle sensor in the car and you can read it easily via the can bus. But I don't know if it is on the rack on the column and ideally you want both as you connect the two.
Boggie1688 is offline   Reply With Quote
Old 02-19-2019, 09:50 PM   #5
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
I literally just ask and went through the same question except it was a 2014 WRX. The deciding factor was I didnít want to get an alignment after the install of the STI shaft if the steering wheel wasnít straight and to install the STI shaft was a more involved process. I installed the Perrin lockdown. It was super easy and the steering is much tighter and the steering wheel is perfectly straight. You can decide which way you want to go, I an very happy with the Perrin Lockdown
ROTORCRAFT230 is offline   Reply With Quote
Old 02-21-2019, 12:06 PM   #6
Jawsofire
Member#: 384316
2015 WRX Premium
Galaxy Blue Pearl
Install and alignment was easy and took less then 30 minutes. Helps when you learn from mistakes on someone else's car first . I noticed a good amount of difference in handling. I wouldn't even consider the Perrin lockdown if you can get a good deal on the OEM one.
Jawsofire is offline   Reply With Quote
