Welcome to the North American Subaru Impreza Owners Club Sunday July 25, 2021
Old 07-26-2018, 11:30 PM   #1
withoutt790
Member#: 488793
Default Misfire Cylinder 1
I know there is tons of posts about this, but I want to see if I am missing something.
16 sti, blouch turbo dominator, tomei headers, cobb downpipe, short ram, invidia n1 exhaust, 1000cc injectors, aem fuel pump, fuel rails, flex fuel set up, process west FMIC.
I am now throwing a misfire cylinder 1 on e85. I swapped all spark plugs, gapped down more, swapped coilpacks, stayed misfire cyl 1, replaced coilpack, still throwing it, did a compression test, was good, swapped injectors positions, still misfire 1, pulled the injector while running to see if it would run rougher or the same, ran rougher, which tells me its not a true miss. Did a wet compression test with scope, all good.
Is there anything else I am missing, or is it tune related?I did give the data logs and tune over to Cobb, but in the mean time seeing if I missed any other parts to check. I did put 93 back in and still misfiring so its not a bad batch of gas.
withoutt790 is offline   Reply With Quote
Old 07-27-2018, 12:10 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You have only scratched the surface of what could be causing a P0301 CEL.
You've done the basics but now you have to look deeper.
Google P0301 and you will see the L-O-N-G list of possible problems.
When was the last time you changed your fuel filter?
How do you know it's not a bad batch of gas? Just because you "switched back" to a 93 grade does not mean you do not have a bad batch of gas.
And if it was a bad batch of gas, the CEL would not just automatically disappear like magic just because you went up to a higher grade fuel.
Old 07-28-2018, 12:12 AM   #3
withoutt790
Member#: 488793
Because it popped with e85 and not 93, and we sucked the e85 out and put 93 in, cleared the code, and it came back on after 2 seconds once we started the car again. Magic would be nice
As for fuel filter, never, its a 2016 with 10k miles.
Old 07-27-2018, 12:20 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Was this a OTS tune or ProTune? I am not aware of a COBB OTS tune for some of those parts. You could be borderline on all cylinders but only cylinder 1 is tripping.
Old 07-28-2018, 12:13 AM   #5
withoutt790
Member#: 488793
Its protuned, it tuned on 93 first perfectly fine, and then on second pull on e35 it hiccuped and now has the misfire, but everything mechanically is good.
Old 12-30-2020, 06:50 PM   #6
atliensubie
Member#: 514019
any updates?
atliensubie is offline   Reply With Quote
Old 01-05-2021, 04:03 PM   #7
604bugeye
Member#: 521477
Maybe give fuel filter a try?
604bugeye is offline   Reply With Quote
