Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Old 08-29-2007, 12:22 PM   #1
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
Default Boost controllers and other mods... how do they affect the car?
I am looking at buying a used 04 WRX.
The car is currently stock but has had the following mods:
a helix catless downpipe, a greddy e01 boost controller, a greddy turbo timer, a turbo xs rfl bov, a injen cai intake, and 2.5in straight piping w/ muffler.
The car has around 70k miles so I am curious what problems there could be, or if there is anything I should be looking for?
From what I understand the car has never been raced/tracked or rallied...?
Comments?
ScoobyDrooler is offline   Reply With Quote
Old 08-29-2007, 01:09 PM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Originally Posted by ScoobyDrooler View Post
Comments?
Two comments:
(1) It's an '04 with a MBC, TBE, intake, BOV, turbo timer and no apparent EM/tune. Basically, this car couldn't have been modded any more incorrectly.
The car is a disaster waiting to happen, and probably runs like poo.
(2) Read THIS. All of it.
Spenk is offline   Reply With Quote
Old 08-29-2007, 01:14 PM   #3
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
Comments?
2.5in piping?!?!?! ditch the pea shooter and run 3in. Also get an EM asap to tune for the parts that are already installed. Get rid of the E01 and buy an EM, sell the turbo timer and get an up pipe.
B00st3dWRX is offline   Reply With Quote
Old 08-29-2007, 01:23 PM   #4
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
The EBC was only on for about 10k miles... All the mods have been taken off, except the exhaust pipeing...
And by EM you mean get an engine management system? What will that set me back?
Old 08-29-2007, 01:29 PM   #5
Spenk
Member#: 7164
2000 Miata LS
Old 08-29-2007, 01:52 PM   #6
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
Sorry maybe a dumb question but what is MBC?
And I've read about the 04/05 WRX's having an issue with boost controllers or something...
something about the open/closed loop delay???
what is this?
Old 08-29-2007, 02:00 PM   #7
Spenk
Member#: 7164
2000 Miata LS
MBC = Manual Boost Control: it bypasses the ECU's boost control, which can either be a very good thing or a very bad thing, depending on the tune and the self-control of the user.
MBCs and DPs are a big no-no on '04+ WRXs due to a delay in fueling when the car gets into boost (emissions control bullcrap). If you increase the boost or breathing of the engine without the ability to add more fuel quickly enough, you're going to have trouble.
Old 08-29-2007, 03:52 PM   #8
Foska Oats
Member#: 144081
2003 WRX
There is no problem with that. As long as your fuel and most importantly, your timing is also being adjusted accordingly.
Foska Oats is offline   Reply With Quote
Old 09-10-2007, 05:20 PM   #9
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
So just to be clear... Currently the car is stock except the 2.5 pipe and Magnaflow exhaust.
i want to add a DP and do the AP reflash for stage 2... anything else I'm missing? Will I need bigger injectors or anything else?
Old 09-10-2007, 05:30 PM   #10
AllAWD
Member#: 17079
Cobb has very detailed notes on what works for their off-the shelf maps check their website to verify.
Also the Enginuity is becoming more popular and much cheaper option ($90 for the cable, free software + your laptop) and you can tune it yourself or buy maps.
I'm in the market for a UTEC personally. Beyond stage II it has more abilities that can't be matched by flashing the stock ECU.
AllAWD is offline   Reply With Quote
Old 09-10-2007, 05:31 PM   #11
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
Enginuity? Is this like an AP?
Where can you get it?
Old 09-10-2007, 05:54 PM   #12
AllAWD
Member#: 17079
If you want to take the risk of doing it yourself. Enginuity is an open source (free) software that allows you to flash your ECU and do your own tuning. Off the shelf maps are available for sale and you can find some free.
You only need a Tactrix ODBII cable (get the one with reflash connectors) and a laptop.
http://www.enginuity.org/
This will not give you all the features/safety of UTEC or conveinence of AP. No gaurantees, but many happy users. Do your research in the engine management section of NASIOC and the enginuity site. It may save you a lot of money.
Old 09-10-2007, 07:04 PM   #13
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
take the car to a subaru specialist and have them check over the car with a fine tooth comb, checking compression, leakdown, etc etc. They will be the ones to tell you what the condition of the car is.
jigga is offline   Reply With Quote
Old 09-10-2007, 07:11 PM   #14
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
I had the compression done, but not a leakdown?
compression came back all mid 150's one was a little lower but still within the 10% margin.
How much for this leaktest?
I assume it checks all fliuds and seals... what about the turbo... will it check for a boost leak?
FS(CT)-5zigens, boost controller, and other stuff Dfence410 NESIC Private Classifieds 8 08-08-2008 08:01 PM
Question for people in the snow belt...how do they clean the snow in your area? GooseMan Off-Topic 32 03-19-2007 11:50 AM
DAKAR-How do they follow the route? rallynutdon Motorsports 9 01-09-2004 11:18 AM
How do they print the white "m" on m & m's candies? chill105 Off-Topic 18 02-12-2003 02:45 AM
Cusco strut tops....do they lower the car? Red Rocket Brakes, Steering & Suspension 7 10-07-2002 12:59 AM
