Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Old 11-08-2008, 08:22 PM   #1
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Default TD04 Parts on VF43 Turbo. Help Needed
I am upgrading the little TD04 to a VF43. I got the turbo without any of the hard lines. I have a few questions before I off running to the dealership to buy a bunch of parts I dont need. Can I reuse what I have circled in red from my TD04 or do I have to order everything for a vf43.
WagonGGA is offline   Reply With Quote
Old 11-08-2008, 08:45 PM   #2
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
I know you can reuse the oil feed line [don't need to remove it from the car] and the coolant lines [though you will need to break the piece that binds them as one unit instead of two]. I'm not 100% sure about the oil dump line.
MB38 is offline   Reply With Quote
Old 11-09-2008, 02:21 PM   #3
DanBelford
Member#: 30516
2003 WRX
The oil return line is different in the way it mountsto the turbo, My 43 came with the return and coolant lines. I read around here somewhere that the return line must be modified from the TD04 to work with the VF43, but it should work.
DanBelford is offline   Reply With Quote
Old 11-09-2008, 11:35 PM   #4
WagonGGA
Member#: 134481
08/4 Subaru
I am going to order the return Tube and the rubber hose. Everything else should bolt on. Thank for the info.
Old 03-06-2013, 05:49 AM   #5
Rexxy2sexxy
Member#: 345263
Sorry to raise a thread from the dead.. but I am encountering this problem that I can't get the turbo and oil feed line to match up.. if its true that the td 04 line can be modded how do I go about doing that? Thanks
Rexxy2sexxy is offline   Reply With Quote
Old 03-06-2013, 06:38 AM   #6
jebjkey
Member#: 73884
Chapter/Region: HIIC
2016 STi
Hyper Blue
Have you tried to bend the oil feed line to make it line up. Be very careful to not kink it though.
jebjkey is offline   Reply With Quote
installing a wrx stock turbo, help needed! azncandyman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-04-2005 05:30 PM
Urgent turbo help needed lotusTT New England Impreza Club Forum -- NESIC 18 08-14-2003 10:13 AM
TURBO help needed! Haase14 Mid West Subaru Owners Club Forum -- MWSOC 3 02-07-2003 02:56 AM
S-afc install help on a 95OBS! Help Needed!! Bahumut Normally Aspirated Powertrain 24 06-03-2001 12:26 AM
Twin Turbo help needed byb555 Technical Forum Archive 1 10-12-2000 04:08 PM
