Welcome to the North American Subaru Impreza Owners Club Friday August 19, 2022
Old 06-28-2022, 04:34 PM   #1
soundquest
Member#: 468926
Default PLEASE HELP - Cyl. #2 Ignition coil not getting signal after changing spark plugs
Just got done changing spark plugs and coils on my 2010 Outback 2.5L (EJ253 AVLS) and now my #2 ignition coil is not firing (new SUBARU OEM coils too). What are the possible culprits for this fault? I have tried multiple new coils on it and swapped things around to confirm it is not getting signal. Appreciate the help in advance. Thanks.
soundquest is offline   Reply With Quote
Old 06-28-2022, 08:31 PM   #2
soundquest
Member#: 468926
BUMP. Anyone?
Old 06-28-2022, 08:34 PM   #3
ronemus
Member#: 124146
'17 Outback 2.5i
Premium Tungsten
Sometimes a connector pin will not be captured properly and gets pushed back so it no longer makes contact; check both the plug on wiring loom and on the coil.
ronemus is offline   Reply With Quote
Old 06-29-2022, 02:39 PM   #4
soundquest
Member#: 468926
I was able to do some more checking and digging around. With the engine running (on 3 cylinders), I was pulling 5.5 - 6hz duty cycle on a working coil from the trigger/signal wire. On the non-working coil plug I was pulling ZERO HZ on duty cycle. But... the trigger/signal wire is getting voltage. So either I have a short somewhere in that wire somewhere going back to the ECU... or the ECU itself is bad.
Any other ideas or possibilities???
Old 06-29-2022, 03:01 PM   #5
benflynn
Member#: 515308
Did u verify the pins were pushed all the way in? Then ohm the wire from both ends(other I assume comes in at the main engine connector. Id also bet a pulled pin would be only cause associated with plug change, or broken wire. Both u check by homing out wire
benflynn is online now   Reply With Quote
Old 06-29-2022, 08:30 PM   #6
soundquest
Member#: 468926
Both of these were checked -- I also back-probed from other locations on that circuit other than at the coil plug. I did back-probe check the ECU signal wire for #2 cyl and it came back with 000 hz duty cycle. Starting to look more and more like the ECU is toast. Any other suggestions?
