Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
Old 06-02-2010, 03:11 PM   #1
elucas730
Member#: 42714
'07 BMW 335i E90
Default IT Folks: having internet issues
I'm not super handy fixing computer issues, so I'm hoping someone here has some answers for me.
First: I can't connect to the internet. I have a cable modem and wireless router. They seem to work fine as I can access them via my cell. When I do ipconfig /renew, I get a "Cannot renew IP address" error. Last night I did the disconnect ethernet cable, turn off modem/router, restart PC, turn on modem/router, reconnect ethernet and still nothing. Ipconfig returns IP address of 169.254.0.0 and subnet mask 255.255.255.0.
Maybe coincident, maybe not: Last time I was on, I couldn't reach a web page and got the webpage not found error and I think I accidentally clicked "work offline". Then come to find out, this is no longer available with IE 8, so not sure how I was able to do it. I definitely can't find a way through IE 8 to "work online".
Second: Before this happened, I was having some issues with my modem where it would just "drop out" every once in a while. If I went and disconnected the external TV cable and plugged it back in, it would come back. I'm thinking this must be a modem problem from getting old, not sure what else it could be.
Any help on these issues would be appreciated.
elucas730 is offline   Reply With Quote
Old 06-02-2010, 03:15 PM   #2
sebtarta
Member#: 82883
2006 2.5i Wagon 220k
'72 LSx Nova Turns&Stops
modem brand
router brand
are you accessing the internet via your phone now?
sebtarta is offline   Reply With Quote
Old 06-02-2010, 03:18 PM   #3
Speedinticket
Member#: 76596
Assuming you are online through the router and cable modem on your cell, it's probably a bad ethernet card on the PC. Could also be a bad cable from the PC to the router. Cheap USB ethernet or USB wireless card should be less than $50 at the nearest Bestbuy or similar.
An IP of 169.x.x.x is generated by Windows when the computer asks the network for one and doesn't get an acceptable offer back.
Speedinticket is offline   Reply With Quote
Old 06-02-2010, 03:18 PM   #4
wrxlvr
Member#: 10788
2016 F150
What is your default gateway? If you don't have one of those, you aren't getting signal from the modem (check the cable). Your internet could be out at the carrier also.
wrxlvr is offline   Reply With Quote
Old 06-02-2010, 03:19 PM   #5
sebtarta
Member#: 82883
also light status on the cable modem
Old 06-02-2010, 03:19 PM   #6
r0bman
Member#: 87015
Another possibility: DHCP (service that provides your computer with an IP address) on the router might be turned off.
r0bman is offline   Reply With Quote
Old 06-02-2010, 03:26 PM   #7
jumpinjusty
Member#: 239829
08 QSM Spec.B
pr0n red 745TiC
could be some spyware.
Go into tools/internet options/connection tab/LAN settings.
Make sure your first box is checked (auto detect settings) and make sure your proxy and use auto config script boxes are cleared.
Second, right click my network places/properties then right click local area connection/properties. Scroll down to TCP/IP, highlight and push properties button. Make sure Obtain IP Auto is selected, as well as Obtain DNS Automatically is selected. OK, OK.
Third, reboot cable modem using the reset button on the back. When it powers back on power cycle your router.
jumpinjusty is offline   Reply With Quote
Old 06-02-2010, 03:33 PM   #8
elucas730
Member#: 42714
'07 BMW 335i E90
Originally Posted by sebtarta View Post
modem brand
router brand
Don't have these at the moment
No, I am at work. Will be home in a couple hours.
I was thinking this may be the case, but wanted to see if there is anything else I could try before spending the $50. It just seemed like too much of a coincidence that I would have a hardware failure at the same time I did the "work offline" thing.
The lights all look "normal" (as in, they look the same as when everything was 'working'). I'll have to wait to get home to write it up.
Is there a fix?
Ok, haven't done this.
Did this yesterday.
Does the 'order' matter as far as turning off the router and the modem? Or should I wait for the modem to be back up and running before plugging in the router?
Old 06-02-2010, 03:35 PM   #9
UberWilhelm
Member#: 80937
In IE, go to File/work offline. If there is a check mark next to it, uncheck it again try again. Otherwise, get a cheap NIC and replace yours. Costs $15 and takes about 15 minutes to swap out.
UberWilhelm is offline   Reply With Quote
Old 06-02-2010, 03:38 PM   #10
Jessie James
Member#: 2072
Suggestions:
1. Turn off modem, router, computer.
2. Turn on modem. Wait 1-2 minutes until the status lights appear to be "normal". In the case of my modem, that means the "data" light starts to blink after about 2 minutes.
3. Turn on router. Do as above in #2 again.
4. Turn on computer.
5. Go into the network settings. Click properties. Poke around until you find the part that says "Obtain an IP address automatically" for the IP address and "DNS server".
6. Check internet.
7. If that does not work, click Start - Run. Type in "CMD" or "Command" and press Enter. In the box that appears, type in "ipconfig /all" and look for the "gateway". It should be something like 192.168.0.1.
If that does not work, paste the ipconfig results here for us (if possible?) or type it up for us (basically.) We are looking for your default gateway, IP address, and name servers.
You may also be able to connect to your router. It is the "gateway" so open your browser and go to http://192.168.01 or whatever the IP is. If you know the admin password, you may be able to troublshoot it that way.
If you do not know the password, look for a recessed "reset" button on the back. Unplug it, hold down the button, plug it in, hold the button for 10-30 seconds, then release. With any luck you've just reset the router to the defaults and can start over. You may want to Google the default admin password PRIOR to doing this so you can get in later, if needed, and to change it (wise).
Jessie James is offline   Reply With Quote
Old 06-02-2010, 03:39 PM   #11
jumpinjusty
Member#: 239829
08 QSM Spec.B
pr0n red 745TiC
It does actually. First Cable Modem reset and when it's running it's tests reboot your router
this is also sound advice if the software side is in good order.
Old 06-02-2010, 03:54 PM   #12
elucas730
Member#: 42714
'07 BMW 335i E90
If it's this, I'm going to beat myself in the head with a steel rod. I'm sure I went into Help, typed in "Work Offline" and it said that it is no longer supported, so I couldn't figure out a way to undo it.
Thanks for the help guys. Off to a meeting then heading home to try the fixes.
Old 06-02-2010, 04:19 PM   #13
saint_foo
Member#: 64364
Did you first try ipconfig /release THEN ipconfig /renew ?
saint_foo is offline   Reply With Quote
Old 06-02-2010, 04:21 PM   #14
elucas730
Member#: 42714
'07 BMW 335i E90
yes..
Old 06-02-2010, 04:22 PM   #15
Jaredwhamilton
Member#: 195550
2017 Subaru WRX STi
Crystal White Pearl
If you manually assign an IP, does everything work okay?
Jaredwhamilton is offline   Reply With Quote
Old 06-02-2010, 04:23 PM   #16
sebtarta
Member#: 82883
does your modem have a standby button?
maybe you pressed that? I did that with my motorola, drove me nuts for 30min
Old 06-02-2010, 04:39 PM   #17
Manarius
Member#: 106258
2005 Subaru Outback
DHCP on router turned off, drivers on NIC or Wireless, or dead NIC/Wireless.
Check router's settings by plugging in. If you can check settings, sounds like drivers/busted Wireless card.
Lack of assigned IP leaves one of the five options available as the only possible solutions.
Manarius is offline   Reply With Quote
Old 06-02-2010, 07:32 PM   #18
elucas730
Member#: 42714
'07 BMW 335i E90
Son of a bitch, it was the damn Work Offline. I swear to God I used IE's Help, searched for Working Offline, and it came back and said this feature is no longer available with IE8. Time to hit myself in the head with a steel rod.
Now if someone can help me with problem #2...
My internet sometimes goes "out". The cable modem I have is a Motorola SBV5220. It has 9 lights down the front like this:
POWER
DS
US
ONLINE
LINK
TEL 1
TEL 2
BATTERY
STANDBY
"Normal" operation is: Power, DS, US, Online are solid green. LINK is solid orange. TEL 1 is sometimes solid, sometimes blinking green. The other 3 are off.
"Bad" operation is: Power and DS solid green. US blinking green. All others off. Although I think at times, they all go off except for power.
The best way I have figured out for fixing this is to disconnect the external TV cable (the one coming into the house), wait a couple seconds, then reconnect. It almost always fixes it immediately. If I don't do this, it either takes a really long time to come back or doesn't come back at all. Based on absolutely no knowledge at all, my ideas are that there is a weak signal or the modem is wearing down and needs to be replaced. Had it at least 8 years, if not 10.
Old 06-03-2010, 02:04 PM   #19
infox
Member#: 140413
simple way to narrow down the problem, power off the modem and disconnect it from the router. Plug it into your computer and power it on, and wait a few mins and see if this works.
infox is offline   Reply With Quote
Old 06-03-2010, 02:06 PM   #20
infox
Member#: 140413
POWER
DS
US
ONLINE
LINK
TEL 1
TEL 2
BATTERY
STANDBY
First of all, setting IE to work offline will not give your computer an 169.x.x.x IP address (which is the default, unusable IP windows assigns when it can't reach a DHCP server). So there was some other issue with your cable that apparently fixed itself by the time you were able to undo this.
Second it sounds like you have some sort of interference/noise on your cable line interfering with your cable signal.
I would call your cable co and tell them how you are able to fix the issue by unplugging the tv and that should be enough for them to send someone out to test your lines.
Old 06-03-2010, 02:10 PM   #21
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
You aren't getting an IP from the router.
a) your wireless settings are wrong. Delete the wireless profile and re-add it.
b) try connecting hardwired. If it works, get into your router and make sure someone hasn't jacked with it somehow (don't say "not possible") and make sure the wireless settings, etc. etc. etc. are correct.
c) that's all I care enough about this thread to post...
-=C=- is offline   Reply With Quote
Old 06-03-2010, 02:10 PM   #22
UberWilhelm
Member#: 80937
What has two thumbs and is awesome?
<------------ This guy!
Old 06-03-2010, 02:43 PM   #23
infox
Member#: 140413
not so quick there pal, you were suggesting IE is the problem (when he was getting a 169 ip addy) and to replace his nic.
Old 06-03-2010, 02:59 PM   #24
UberWilhelm
Member#: 80937
Here, let me just help you with your reading.
This was his initial issue which has been resolved:
His current issue which I haven't suggested anything for yet is:
To which I would suggest replacing his 8-10 year old router.
Soooo yeah. I win.
Old 06-03-2010, 03:01 PM   #25
alloutSTI
Member#: 241552
2015 GMC Sierra Z82
Subterranean Metallic
hmm to fix this i will need your SSN, DOB, and full name please.
alloutSTI is offline   Reply With Quote
Anyone having internet issues? aerostar Off-Topic 12 04-05-2008 12:56 PM
Ok, I have the issue with the GF... and I don't know what to do about it MattSEG Off-Topic 86 08-24-2006 12:37 PM
Ok, I have the issue with the GTF... and I don't know what to do about it 24 Off-Topic 1 08-23-2006 05:35 PM
Vote to have mods issue warning points for stupid internet speak! doubledribble Off-Topic 19 05-17-2004 03:26 PM
42 offset 17x7 rims. Anyone running it? Have any issues? SinhCredible Tire & Wheel 5 04-04-2004 12:05 AM
