Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Old 10-06-2017, 01:57 PM   #11451
salvi
Member#: 188132
Samurai Jack - I've tried every possible way to reset the system according to the instructions, but no go.
I'll have to drain and fill with the proper ATF fluid for the Power Steering.
We have only driven it about 5 miles after swap.
salvi is offline   Reply With Quote
Old 10-09-2017, 04:01 PM   #11452
ubaldeboi
Member#: 475754
2005 Saabaru
Just got my saabaru with v8 ej207 swap at a steal price. Problem is my area does emissions testing via obd2 port. Now i have to go through some pain to get it to pass inspection
ubaldeboi is offline   Reply With Quote
Old 10-09-2017, 04:19 PM   #11453
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
just swap Ecus with an emissions friendly tune on a wrx ecu
Gigs90 is offline   Reply With Quote
Old 10-09-2017, 09:35 PM   #11454
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
In NY your ecu and vin numbers have to match, in the case of a new ecu the dealer has to encrypt it to match the vin. I hope you got the original ecu also when you purchased the car. The original ecu can idle the car but not so well due to the different fuel injectors on the STi motor. If you need a stock 05 wrx ecu let me know, I have a good spare I can sell you for $100, pm if you want the ecu or have questions.
D-Rodman is offline   Reply With Quote
Old 10-10-2017, 09:47 AM   #11455
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
yes emissions are a tricky battle because they vary immensly from state to state and country to country. apparently people near me have told me they passed with a jdm ecu & catless. they just had all the readiness monitors set to force pass. plugged in, everything was a-ok, away he went.
Titter is offline   Reply With Quote
Old 10-10-2017, 11:15 AM   #11456
PHruska
Member#: 214589
2002 V8 wrx wagon
Has anyone had any issues with running Learningview/Romraider/EcuFlash on windows 8.1?
I tuned the car back in 2013 (02 w/ v8. Tuned by Ron @phatbotti).
The car recently has been getting wonky AFR's at cruising/idle. Bouncing from 14.1 to 15.3 and such. Its about time for spark plugs/timing belt etc. but wanted to hook up a computed and read a random CEL that came on briefly yesterday.
I no longer have the windows 7 laptop i used to tune the car but do have one running windows 8.1.
I downloaded Learningview and got nothing. I downloaded ecuflash and romraider and got a little. Romraider logger doesnt show a com port connection BUT was reading off the ECU for a few minutes before it automatically stopped.
I have java updated (i think only 64bit?), enabled .Net 4 or whatever that enables .Net 2.0.
Computer is running windows 8.1, 64 Bit. Using Tactrix 2.0
Any ideas?
PHruska is offline   Reply With Quote
Old 10-10-2017, 11:17 AM   #11457
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Windows 8 is just pure trash
I have only done logging on a windows 7 laptop for that reason and licences are only like $50 now for 7 Pro
Old 10-10-2017, 11:21 AM   #11458
PHruska
Member#: 214589
2002 V8 wrx wagon
I do not disagree. I unfortunately only have the one computer running 8, and is also running Solidworks so i dont want to go back to 7.
I am ready to throw my entire laptop out the window if i cant figure this out.
Old 10-10-2017, 11:42 AM   #11459
Bansheeboy11
Member#: 182415
1999 RS
Yeh 8 is trash, i bought one of those cheap netbooks and threw Win 7 on it for use with the cars, its been great so far.
Bansheeboy11 is offline   Reply With Quote
Old 10-10-2017, 12:08 PM   #11460
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Agreed. Have a base tune put on your ECU so the car will run & pass emissions.
- You won't have AVCS
- You will have minimal boost, like 6 - 8 psi
Once you pass emissions, just swap in the JDM ECU with the proper tune for the engine. It only takes a few minutes to do the ECU swap
Samurai Jack is offline   Reply With Quote
Old 10-10-2017, 01:07 PM   #11461
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I'm about to do this as my admin machine for my home lab and ecu logging as well
Old 10-10-2017, 03:04 PM   #11462
PHruska
Member#: 214589
2002 V8 wrx wagon
Edit:nvm, Getting 0 degrees of VVT on either side. Guessing that the reason is something other than the wire shielding being compromised. Going to have to dig a bit deeper. Wonder if crank sensors failed or AVCS solenoids both failed. Between the fluttering AFR, the not stable idle RPM and 0 degrees of AVCS Id say I have some work cut out. Going to start with IACV gasket then keep digging. Its almost time for plugs and a timing belt anyway.
Old 10-17-2017, 04:10 PM   #11463
08OBS
Member#: 274397
2005 WRX V9 207
1992 Legacy SS
My most recent UOA. A lot better than my last analysis.
08OBS is offline   Reply With Quote
Old 10-17-2017, 04:29 PM   #11464
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
That looks way better
Old 10-17-2017, 07:21 PM   #11465
jdm05
Member#: 180155
05 Jdm Sti 2.0
Very nice
jdm05 is offline   Reply With Quote
Old 10-24-2017, 03:59 PM   #11466
shaunbyrne
Member#: 458937
great thread guys. over here in the uk I have 2003 spec c ltd with the ej207 motor and love it. keep up the good work
shaunbyrne is offline   Reply With Quote
Old 10-25-2017, 10:42 AM   #11467
86Dreams
Member#: 385256
V7 S204
So about 2 months ago I was lucky enough to find an S204 Motor on Ebay. I bought it since I had killed my 205 and needed a replacement.
I am extremely happy with this motor. I elected to tune it myself and have been running E85. I finally got to put it on a Dyno this past weekend and was able to make 350 Torque and 350 Hp.
https://i.imgur.com/o8vFrLu.jpg
So Im wondering if any of you other guys with an S204 would be willing to compare some logs. I was able to get 25 psi briefly from the turbo but it looks like it likes to run 20 down to about 16 with a steady airflow of about 245 g/s once its spooled. Im still looking at a couple different ways to control it. Right now Im trying a solid 80% waste gate from about 4k-6k rpm, but boost still seems to trace the same way.
86Dreams is offline   Reply With Quote
Old 10-25-2017, 01:48 PM   #11468
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I am still on stock injectors and probably will be going flex fuel next spring , Good to see what E85 can do.
I don't think I am going to spin mine much over 22psi or so as its just hot air at that point
Old 10-25-2017, 02:28 PM   #11469
86Dreams
Member#: 385256
V7 S204
Ive got ID1ks and have seen about 70% as the max idc. This is also with a catted 3" downpipe (a tomioka with a vp cat welded in) and a catback.
How do you know it will be hot air over 22 psi?
Old 10-25-2017, 02:42 PM   #11470
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Spinning a small turbo that hard , Look at the VF turbos compressor maps you get way off the efficiency chart doing that.
I too have a Tomioka catless with a full exhaust
Old 10-25-2017, 02:50 PM   #11471
86Dreams
Member#: 385256
V7 S204
Ive never had luck finding any of them.
Old 10-25-2017, 03:35 PM   #11472
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Here is one for a VF24
Old 10-25-2017, 04:09 PM   #11473
86Dreams
Member#: 385256
V7 S204
Thanks!
heres a hypothesis im going to try to test:
The VF42 can run 270g/s and 25 psi.
Consider that map against the info in this thread.
https://forums.nasioc.com/forums/sho....php?t=1141476
The thread claims 425cfm at 18 psi for the VF24. On the graph's axis thats about 12 m3/min and a 2.25 pressure ratio. So that 425 in the turbo list is an over estimate. The TD04 is also over estimated. So Im going to assume that everything in the list is a little over the top.
It says the VF42 is like a VF22 with better spool up and top end due to it being a twin scroll. The VF22 is listed at 490cfm, which is close to 300g/s (incidently also the air flow limit in the 16 bit ecu). And, 18 psi. The VF42 comes with a stock target of 20.
On my TD04 I was never able to push it past about 21 PSI, and not for long. I could get 216 g/s out of it but it got HOT So I ended up limiting it to 200. I also noticed that the difference in flow and HP between 18 and 20 psi wasnt much.
So with all that said I want to believe the VF42 could run 25psi (it was running 22 for me no problem today) and maybe even out to something like 270g/s / 460CFM.
Adding onto this. Fuel cut for the V9 EJ207 is just under 25 psi. The TD04's fuel cut was just under 18 psi. This is not a statement to try to compare the two turbos but to try to establish a theme in Subaru's Control strategy. Knowing TD04's fuel cut and what it can do, can you figure out what the VF42 can do knowing its fuel cut?
Old 10-25-2017, 05:15 PM   #11474
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Thanks!
iirc 21psi is stock on the S204 rom , I would take a look at it if you have not yet as its pretty aggressive.
I don't think the car made only 320ps , I think it was more and under rated.
Old 10-26-2017, 10:21 AM   #11475
86Dreams
Member#: 385256
V7 S204
Yes. Everything Ive done is based off of the stock rom. I am still using stock timing. If you compare to a standard V9 the s204 ignition timing is actually lower in several places. I spent some of my dyno time confirming that the stock timing would not be too much.
Even though the stock boost targets are 20, the max wastegate duty cycle didnt seem to be enough to reach them, atleast not in my case, It took me ALOT more wastegate to get there.
I THINK This was using the stock wgdc settings https://i.imgur.com/V3sPNQU.jpg
This is the stock boost target and Max wastegate
https://i.imgur.com/KCjatAH.png
Searching some more I ran across this
http://ken-gilbert.com/wrx/vf22compmap.jpg
So airflow of 250g/s (12.6) is definitely doable 260(12.85) is possible and 270(13.2) may not be achievable.
Boost I still want to target 25 peak.
https://i.imgur.com/dQ5r4K2.png
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
