08-07-2011, 04:48 PM | #51 |
Member#: 284496
Vehicle:2011 Rex Rally Blue |
Thanks for the info, I was told a new BOV will hold more boost. Research was done and I guess it was wrong, but I live in Massachusetts
08-07-2011, 05:23 PM | #52 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
Your mods listed won't require anything to hold more boost....your turbo isn't capable of creating more boost. BOVs are notorious for leaking and if not adjusted correctly (or not adjusted at all), leaking in other ways.
08-07-2011, 06:46 PM | #53 |
Member#: 281992
NESIC
Vehicle:2021 AMG CLA 45 Mountain Grey Magno |
Please post what tuner you went to so I can NEVER go to them (and so other people from Mass steer clear).
Gl, sounds like you have bigger issues than the BoV. |
08-07-2011, 06:47 PM | #54 | |
Member#: 157348
Vehicle:I Thlammed My Penith in the Car Door |
08-07-2011, 07:19 PM | #55 | |
Member#: 255776
Vehicle:2010 LR WRX MPS powered. |
08-07-2011, 07:31 PM | #56 |
Member#: 289226
Vehicle:2002 wrx wagon silver |
i have a 100% atmo bov...i only get a lil white smoke on some start ups. i do not show off i barely rev it up high enough to really blow it off the guy i got the car from said it has a cobb stage 1 reflash on the bov should i get rid of it sounds pretty bad for the car from what you guys are saying......
08-07-2011, 07:43 PM | #57 |
Member#: 255776
^^^absolutely. and fill out your profile.
08-07-2011, 08:02 PM | #58 |
Member#: 289226
i read the sticky on them not tryna argue with you but how bad is it?
08-07-2011, 08:17 PM | #59 | |
Member#: 157348
08-07-2011, 08:22 PM | #60 |
Member#: 262760
Vehicle:2011 WRX Hatch Limtd Satin White Pearl |
Fasho! Look, the car is designed to have the boost returned to the system. Venting it away makes the car have to adjust...not good. You can upgrade, but go with a recirculating valve.
08-07-2011, 08:52 PM | #61 |
Member#: 289226
so what will i need to go back to stock besides the obvious?????
08-07-2011, 08:55 PM | #62 |
Member#: 157348
08-07-2011, 09:06 PM | #63 |
Member#: 289226
lol okay cool will it need a retune then??????
08-07-2011, 09:10 PM | #64 |
Member#: 157348
nope.
An ECU reset wouldn't hurt, though. Disconnect battery for ten minutes and pump the brakes a few times, reconnect, let car idle for ten-fifteen minutes, drive normally. |
08-07-2011, 09:12 PM | #65 |
Member#: 289226
ok thanks you wouldnt know off hand how much a stock one goes for at a dealership would you?
08-07-2011, 09:18 PM | #66 | |
Member#: 84823
NWIC
Vehicle:14 Evo 00 Outback |
Waits for update....... |
08-07-2011, 09:24 PM | #67 | |
Member#: 84823
NWIC
Double post!! |
08-08-2011, 10:54 AM | #68 |
Member#: 284496
OK........ PERRIN BOV VTA is a POS. The BOV was stuck, simple fix, I am a retard, and thats what was causing the issue. I guess the o-ring fell off, and it got stuck open. The tune shop put my OEM BOV back on and told me to contact perrin to get a non VTA and if I run into issues, they could call the shop. My oil change was done last week and they said it will be ok, but change my spark plugs in like 15,000k. MY Dealer said next oil change they will do a couple tests to make sure everything is ok. 2011 WRX 278whp 12,000 miles
08-08-2011, 10:56 AM | #69 |
Member#: 284496
I will not get another bov, going to see if they can give me credit for something else.
08-08-2011, 12:50 PM | #70 | |
Member#: 289554
Vehicle:2002 WRX WRB |
08-08-2011, 12:53 PM | #71 |
Member#: 262760
Wow...I Can't believe That was it. I'm really happy for you!
08-08-2011, 01:11 PM | #72 |
Member#: 265254
NESIC
Vehicle:2011 WRX OBP |
08-08-2011, 01:13 PM | #73 |
Member#: 263470
ME too, I was like what the hell, i am going with the HTA68 8cm and was double thinking this that the motor was gonna let go!!!
08-08-2011, 01:26 PM | #74 | |
Member#: 20442
NESIC
Vehicle:2022 WRX Limited WRB |
FS : Ga: 2011 Wrx Sedan Swp | Kontankerous | Private Vehicle 'For Sale' Classifieds | 3 | 09-16-2011 12:26 PM |
Used value of a 2011 WRX premium w/ accident | chiefchankton | General Community | 6 | 08-05-2011 09:54 PM |
Discovered some lovely rock chips on my 2011 WRX today. Help! | xabre1200 | Car Care & Detailing | 44 | 06-17-2011 04:02 PM |
Between a 2011 wrx and a 2011 5.0 mustang...need help deciding. 2.5 warranty issues? | r00st | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 254 | 03-12-2011 12:11 PM |
2011 WRX wheel help | thebigevilfoot | Tire & Wheel | 1 | 11-12-2010 12:27 AM |
