12-21-2002, 10:54 AM | #1 |
Member#: 26030
Vehicle:2003 WRX Sedan Silver |
Max Boost & HP on Stock WRX Tubro
So, i know that the stock turbo has a maximum boost of 14-15 psi, pumping about out 227hp.
If one were to keep the same turbo setup, what is the max boost allowable (safe) by use of a boost controller? And the approximate corresponding HP? |
12-21-2002, 02:40 PM | #2 |
Member#: 18226
Vehicle:2001 M3 Laguna Seca Blue |
Where did you get this 14-15psi stuff from?
I thought it was 13.5 stock most people set it at 15.5psi for best results |
12-21-2002, 04:29 PM | #3 |
Member#: 30246
Vehicle:0394 WRX/Supra WRB/White |
14.5 is stock psi i had thought?
12-21-2002, 05:13 PM | #4 |
Member#: 23630
Vehicle:97 v4 STi RA Feather White, 17 FoST |
Everyone is getting different boost. Some people get 13.5, some are getting 15psi. I got spiking to 15.5 and it would settle on 14.8. Most people agree that the stock turbo runs out of steam around 16-17psi. I have my mbc set to 16.5psi. I see less spiking than with my fbc. Do a search and you'll see that some people think it's bad to run anything higher than15-15.5psi. Read their posts, then learn how to read your boost guage to find out what is dangerous and what's not, then decide if you want to go run higher boost.
Good Luck, Marcel |
12-21-2002, 06:19 PM | #5 |
Member#: 12329
TXIC
Vehicle:2o15 WRX Ice Silver |
It really depends on your location. People at sea level can see higher boosts. I have seen upwards of 14.7 psi (.1MPa) on cold, dry days, and I'm at 300ft, I think (whatever Dallas is). Naturally, people in higher elevations can't see as high a number, so your mileage may vary when it comes to boost.
Similar Threads | ||||
300+ hp on stock wrx trans. | BugeyePB Rex | South West Impreza Club Forum -- SWIC | 40 | 10-27-2009 06:31 PM |
Highest hp on stock wrx 5 speed? | Flatline86 | Transmission (AT/MT) & Driveline | 5 | 11-15-2008 10:04 PM |
Most Hp on stock wrx heads | 13secwrx | Proven Power Bragging | 56 | 07-20-2005 10:49 AM |
Max WHP on stock WRX turbo | wRxbeater11 | Proven Power Bragging | 35 | 02-28-2004 01:48 AM |
I want to port & polish a stock wrx turbo myself any tips? | cky211 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 01-13-2004 12:50 PM |
