09-21-2003, 03:59 PM | #1 |
Member#: 37651
what is the max boost the sti can hold
just got my blitz boost controller and I wanted to know what is the max boost the stock turbo can hold with no problem.
09-21-2003, 04:42 PM | #2 |
Member#: 16696
MWSOC
Vehicle:2002 WRX Sedan Stg2 2013 OBW roll'n at 30+mpg |
Hmmmmm... new 2.5l in untested new form...
two words. |
09-21-2003, 05:02 PM | #3 | |
Member#: 717
NESIC
09-22-2003, 08:54 AM | #4 |
Member#: 39462
Tri-State
Vehicle:04 STi Type R Spec Broken Wallet |
Try 25 psi.........
You should be fine. Ka BOOM!!!!!! |
09-22-2003, 02:02 PM | #5 |
Member#: 37205
RMIC
Vehicle:2004 STI WRB |
Actually, it sounds like the stock turbo has trouble holding stock boost, so turning it up with a MBC probably won't get much anyway.
09-22-2003, 04:14 PM | #6 |
Member#: 18384
Vehicle:2004 STi: 580 AWHP Java Black Pearl |
I set mine to 16psi and it creeps to 18psi+ on long straights at the track.
It settles back down to 15psi or so as revs increase towards redline. I should do some DeltaDash logging. Russ |
09-22-2003, 06:01 PM | #7 |
Member#: 38550
Vehicle:2004 Impreza WRX STi WR Blue |
I read somewhere that the stock turbo is about maxed out, though the rest of the engine will hold. To be honest, with how fast it spools, I wouldn't be surprised that it can only push a little bit more.
RN |
09-22-2003, 11:44 PM | #8 | |
Member#: 18602
Vehicle:2005 Moller Skycar glow in dark purple |
STI can hold 100psi for bout .1 second. More if less pressure, less if more pressure..... |
Similar Threads | ||||
What is the max Hp the stock WRX internals have been known to hold? | Homemade WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 76 | 10-30-2019 02:47 PM |
What is the max boost for the VF48? | Tuned200 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 14 | 02-17-2009 04:59 PM |
what is the max boost on a vf39? | Arts | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 04-03-2007 05:18 AM |
what is the max boost for the sti | 4 banger | Tri-State Area Forum | 1 | 09-23-2003 07:24 PM |
What is the MAX boost for a VF30 | fatray | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-16-2003 02:21 PM |
