Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2024
Old 06-28-2004, 09:32 AM   #1
HerculesPeanut
Member#: 35421
W R Blue
Default What Works with Borla Hush?
Like the title says, what mates to a Borla without problems?
Fore example, I've read several reviews of people using Helix and having problems with the flange.
I just looked at the Ingen and suspect similar problems. Same for Autospeed.
Short DPs seem to be the logical choice. Are there any other Short bell mouth DPs besides ScoobySport?
If you have a hush, what have you used?
HerculesPeanut is offline   Reply With Quote
Old 06-28-2004, 10:39 AM   #2
sur4die
Member#: 42377
2016 WRX
white
I have a hush, and i had to ditch my helix.
now i'm putting on a bosal twindump shorty. as soon as i can break this stubborn turbo bolt!
most long DPs have a flat flange, and they wont fit the hush (without a torch that is)
sur4die is offline   Reply With Quote
Old 06-28-2004, 10:43 AM   #3
mrbigisbudgood
Member#: 54378
2023 WRX
I have a Helix and it mated up with zero problems.
mrbigisbudgood is offline   Reply With Quote
Old 06-28-2004, 12:37 PM   #4
suganuma2
Member#: 54273
BLACK
how did your helix bolt up but these guys had prob? just wondering before i take any further steps into buying things.
suganuma2 is offline   Reply With Quote
Old 06-28-2004, 12:43 PM   #5
mrbigisbudgood
Member#: 54378
2023 WRX
I used a copper spray treated flat flange gasket on the DP side trimmed to match the lip of the factory donut gasket. Everything went together first time with no leaks and haven't had leaks in 10k miles.
Old 06-28-2004, 12:46 PM   #6
Vector92
Member#: 40661
2002 Imprezza WRX
WRX Blue
The design of the Borla hush makes it easy to fabricate a small slip-fit adapter with a flat flange to mate up with a downpipe with a flat flange.
Use a 12 cm long section of 3-inch pipe, and weld on a 2-bolt flange to match your downpipe.
Use the search function to find more detailed discussions of this.
I have a Borla hush mated to a Random Technologies catted down-pipe, and I love the combination. (all stainless)
Vector92 is offline   Reply With Quote
Old 06-28-2004, 12:56 PM   #7
suganuma2
Member#: 54273
BLACK
do you know of any other dp that will work rather than fabricating something (which i know is the fun part) but im just looking at my options im a vw guy dont know too much about the subies yet.
Old 06-28-2004, 03:20 PM   #8
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
stromung dp + stromung high flow 3rd cat mounts fine my hushback
Jeff_DML is offline   Reply With Quote
Old 06-28-2004, 03:23 PM   #9
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
here is a picture I took of the way the hush mounts
stromung high flow cat, stock 3rd cat mounts the same
Old 06-28-2004, 04:21 PM   #10
HerculesPeanut
Member#: 35421
W R Blue
did you install the DP or the CB first?
So how much louder is your car after adding the Helix?
Thanks,
Hidden hitch and bike rack on sti with borla hush atc5 Interior & Exterior Modification 28 06-18-2005 02:59 PM
helix dp with borla hush crosta21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-29-2005 08:50 PM
Any issues with Borla Hush and trailer hitch clearance? whtlegacy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-08-2004 04:27 PM
What dp to get with Borla Hush muffler txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-25-2004 11:58 AM
Helix Downpipe mated with Borla Hush Catback sonicblue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2004 06:17 PM
