02-15-2006, 12:31 AM | #1 |
Member#: 53069
Vehicle:1998 Legacy 2.5GT Spruce Pearl Green |
For Sale: 1998 Subaru Legacy 2.5GT Wagon
For Sale:
1998 Subaru Legacy 2.5GT Wagon 5 Speed Spruce Green Pearl VIN# 4S3BK675XW6305101 All Wheel Drive 2.5L 4 cylinder 16 Valve DOHC Phase I 5 Speed Manual Transmission, 4.11:1 Gear Ratio Dual air-bags Anti-Lock Brakes, 4-channel ABS Power windows, door locks, and outside mirrors Height Adjustable Driver's seat, with lumbar support Wood Trim package GT Performance Exhaust Halogen Fog Lights, projector beam Fold down 60-40 rear seat Cargo area retractable cover Sunroof Keyless Entry Security System Upgrade Rear Spoiler Rear Cup Holder Tweeter Kit Add Ons K&N Air Filter 14lb Lightweight Flywheel EXEDY Clutch Kit Sylvania SilverStar Headlights Subaru Anti-Slip Mat Info 179,000 miles (mostly highway miles) Only 2 owners, me and my brother New front CV Axles New head gaskets, valve job, heads re-shimmed recently Body in excellent condition with only a few small dings and rock chips NO RUST Paint is still shiny always garage kept Engine leaking something onto exhaust Kelley Blue Book Value is $4,475 Only Asking $3,975 Will Deliver within 100 miles of Sioux Falls, SD 57105 or local pickup. Cash or Money Order only. PM me with your email address for pictures upon request. |
02-15-2006, 12:35 AM | #2 |
Member#: 53069
Service History
Date Work Performed Mileage
7/1/1999 Recharged AC 23,001 7/23/1999 Replaced bent antenna, fixed leaky sunroof, replaced exp. Valve, recharged AC 23,713 9/30/1999 Replaced brake master cylinder (recall) 25,797 10/7/1999 replaced radio, bleed brakes 25,798 1/12/2000 replaced broken cup holder 35,994 2/21/2000 installed new tires, plugs (Bosch Platinum +4) 39,124 3/24/2001 replaced broken left mirror/touch up paint in area 73,336 7/13/2001 replaced alternator (recall) 75,507 8/15/2001 installed K&N air filter 77,481 11/29/2002 replaced timing belt, idler pulley, belts, front oil seal 98,102 1/14/2003 installed new tires 106,462 7/30/2003 replaced front brakes, rotate tires 118,567 10/4/2003 all wheel alignment, rotated and balanced tires 124,576 1/24/2004 Purchased From Paul 131,363 6/17/2004 replaced water pump, timing belt, radiator hoses, plugs (Bosch Platinum +4) and thermostat 140,168 8/9/2004 replaced front right hub assembly and lower ball joint 142,883 10/23/2004 swapped engine with used Phase II DOHC (105k) temporarily, replaced rear disks and pads 146,702 10/27/2004 installed new tires (9/32 tread) 147,524 11/3/2004 all wheel alignment 148,190 12/31/2004 had heads planed, valve job, reshimmed, replaced exhaust valve, head gaskets, head bolts, cam seals, front crank seal, oil o-ring, exhaust gaskets, rear main seal, valve cover gaskets, thermo gasket, installed Exedy clutch (disk, pressure plate, throw out bearing) and 14lb flywheel. Swapped engines back 1/11/2005 installed SilverStar headlights 1/15/2005 installed OEM thermostat back in and seal 1/18/2005 installed new front O2 sensor and ignition wires 4/2/2005 installed updated aluminum rear cover, rear main seal and put OEM water pump back in and seal 4/20/2005 installed new OEM platinum spark plugs 4/22/2005 Had codes P0507, P1507 - Subaru fixed it by loosening the throttle cables 158,422 8/11/2005 replaced front right CV axle, lower ball joint, inner tie rod and boot 166,120 9/9/2005 rotated tires front to back (average 5/32nds tread) 168,712 10/19/2005 replaced front left CV axle 172,041 11/26/2005 Changed transmission fluid / front differential fluid 175,251 |
02-15-2006, 12:29 PM | #5 |
Member Sales Rating: (38)
Member#: 39569
MAIC
Vehicle:2024 Alphard V2 E-Wheels |
Looks really nice. Good price too. 2nd Gen green legacies will always hold a place in my heart. My first Subaru was a '99 L wagon.
02-20-2006, 11:18 PM | #7 |
Member#: 10471
TXIC
Vehicle:2000 BMW Z3 sold Outback & ForesterXT |
some inside pics would be nice... I'll ask around dallas if anyone wants to fly and drive back to get them a good deal...
02-21-2006, 02:42 PM | #11 | |
Member Sales Rating: (9)
Member#: 36735
MWSOC
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
02-21-2006, 06:59 PM | #13 |
Member#: 53069
not 100% on what it is leaking, but I have to top off the PS fluid once in a while, so thats probably it.
Here are some new pictures, mostly of the interior. http://www.subaru-svx.net/forum/show...6&postcount=11 http://www.subaru-svx.net/forum/show...6&postcount=12 |
Similar Threads | ||||
Stock 1998 Subaru Legacy 2.5GT parts | stargazerarizona | Suspension/Brakes/Handling | 6 | 11-04-2011 11:52 PM |
FS: 1998 Subaru Legacy 2.5GT Limited Edition $3500 | gforce | MAIC Private Classifieds | 15 | 11-24-2008 08:49 PM |
Want to buy a stop tech kit for my 1998 Subaru Legacy 2.5GT AWD | GotTurbo | Subaru Conversions | 7 | 08-25-2004 04:06 AM |
Want to buy a stop tech kit for my 1998 Subaru Legacy 2.5GT AWD | GotTurbo | Brakes, Steering & Suspension | 0 | 08-17-2004 04:43 PM |
