Welcome to the North American Subaru Impreza Owners Club Wednesday October 9, 2024
Old 12-02-2006, 12:32 AM   #1
suby25
Member#: 52822
2015 WRX
Default What Clutch and Flywheel for JDM STi RA Tranny? (EJ20G)
I got my EJ20G with STi RA DCCD tranny and the clutch and flywheel are totally shot so I need to replace them. This leads me to a few questions as I begin my research:
Can I run a stock USDM WRX flywheel? (If so what years?) If not, what flywheel will work. It's a push style transmission - first production STi RA, MY 94/95 will be running stock starter unless I have to switch to a WRX starter.
I'm also looking at clutches. I found a cheap Exedy OEM replacement that comes with everything needed that I was thinking of running - I just want to ensure it will handle the power of the 20G motor. I know a stock WRX clutch will hold ~350 ft-lbs no problelm, so I think it should be sufficient. The motor will be pretty stock with a turboback and upgraded intercooler.
Paging Jaxx and a few other gents.
suby25 is offline   Reply With Quote
Old 12-02-2006, 01:21 AM   #2
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
The same ones as USDM WRX.
I got a Ej20G engine and tranny and i just used a WRX flywheel, WRX pressure plate, and a WRX disk(i actualy got a ACT unit, but its for a usdm WRX).
Kirill
snowman4us is offline   Reply With Quote
Old 12-02-2006, 11:06 AM   #3
suby25
Member#: 52822
2015 WRX
Thanks! That's the answer I was looking for.
OEM WRX flywheel & Exedy OEM replacement clutch setup here I come.
07 sti clutch and flywheel for 02 wrx?????? Mustangdude20 Transmission (AT/MT) & Driveline 5 07-25-2008 02:42 AM
Used sti clutch and flywheel for sale peonslayer Private 'For Sale' Classifieds 1 07-05-2006 10:59 AM
What is the Best lightweight flywheel for the STI 6spd tranny? underground-mpyre Transmission (AT/MT) & Driveline 2 10-11-2005 10:02 PM
What Clutch and Flywheel if necesary Works Transmission (AT/MT) & Driveline 3 05-19-2004 03:29 PM
if i buy new clutch and flywheel for my 98 RS; will sti v4-6 tranny mate? Rallyspec Transmission (AT/MT) & Driveline 0 08-29-2003 09:19 PM
