Welcome to the North American Subaru Impreza Owners Club Thursday October 10, 2024
Old 12-28-2006, 10:59 AM   #1
Chapel
Member#: 3496
1995 Roadmaster
Beige
Default Any wiring gurus? 05 STi cluster into an 02
The official and FINAL fix has been done
Click that for the answer.
I'm gonna save this stuff just for trouble shooting.
here's what I'm working on right now
here's my car's interior about a week before I bought it.
I had the original cluster put back in for registration purposes.
The previous owner had the STi gauges in and working and had to reverse the procedure to get the OEM gauges working.
From what I know, he's taped some butt connectors inside the loom to put the STi Cluster back in.
When I simply plug the cluster in I get a buzzing, ABS light, R-diff temp light and I blow the fuse for the radio.
I'm trying to understand the instructions the previous owner sent me. He said all he did was use some wiring and NO PCB board mods or any soldering to get it to work.
here's the thread he linked me to for the fix but this just outlines the rear-diff light problem, not the buzzing and blown fuses
Chapel is offline   Reply With Quote
Old 12-28-2006, 11:02 AM   #2
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
I think there might be a forum for this.
Sideshowbob is offline   Reply With Quote
Old 12-28-2006, 11:02 AM   #3
Chapel
Member#: 3496
1995 Roadmaster
Beige
yeah, there is
I'm wondering if there's anyone local who can help me...
Old 12-28-2006, 11:08 AM   #4
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Oh, well you might want to put that in the OP.
Old 12-28-2006, 11:17 AM   #5
Chapel
Member#: 3496
1995 Roadmaster
Beige
done.
Old 12-28-2006, 02:50 PM   #7
o2sys
Member#: 43842
200? WRX STI
good searching....my situation is kinda weird...i have a 04 STI with 06 STI cluster and it doesnt work properly either. THe BRAKE light doesnt go off no matter what
o2sys is offline   Reply With Quote
Old 12-28-2006, 03:06 PM   #8
Chapel
Member#: 3496
1995 Roadmaster
Beige
i've heard that one too.
here's the fix for blown fuses.
Still trying to find the fix for the buzzer.
They say 'C9' on the righthand side... but C9 is a left side plug.
Trying to get clarification
Old 12-28-2006, 03:21 PM   #9
Chapel
Member#: 3496
1995 Roadmaster
Beige
02 cluster on left, 05 on right. Notice the top plug has 2 extra pins. this makes counting the pins a bit difficult.
now it's just a matter of determining if it's C9 or A9 for the buzzer.
The buzzer is on the right side (A plug) and both the C-plug and A-plug have a pin-9
I'm waiting to talk to the guy that fixed his.
Old 12-28-2006, 03:29 PM   #10
Chapel
Member#: 3496
1995 Roadmaster
Beige
Originally Posted by Chapel View Post
threads I found
http://forums.nasioc.com/forums/showthread.php?t=965990
it seems like there's two ways to do it:
remove the buzzer
or
cut the proper wire.
In that they say the wire is C9, but I'm curious if C9 on the 05 cluster is different from C9 on the 02 harness
see how both the A-plug and the C-plug have at least 9 pins?
he says that the C9 on the RIGHT side is what fixes the problem.
The problem is, C9 when looking at the cluster opening would be on the LEFT side. Not to mention, plug C9 is different on the 02, the C9 on an 02 is 14 pin. on an 05 it's a 16 pin. C9 WOULD be the third pin on the right side from the top on an 02 cluster but the SECOND pin on the right side from the top on the 05 (or the top wire on an 02 Harness to match)
The BUZZER is on the RIGHT side of the cluster (under the speedo)
So, the big question is if it's actually A9 or C9...
Old 12-28-2006, 06:38 PM   #11
Chapel
Member#: 3496
1995 Roadmaster
Beige
got the solution
cut the orange/white wire 9 on the 10PIN (A-plug) and the buzzing stops
pictures coming to illustrate everything I just did.
Old 12-28-2006, 07:21 PM   #12
o2sys
Member#: 43842
200? WRX STI
nice job~ help me with my BRAKE LIGHT!
Old 12-28-2006, 07:37 PM   #13
Chapel
Member#: 3496
1995 Roadmaster
Beige
04 WRX non-STi cluster into an 02? wigglesxjr Electrical & Lighting 3 03-17-2011 12:43 PM
Sti cluster into an 02 WRX - What year Sti cluster is the best to get?? madmax02 Interior & Exterior Modification 1 03-09-2009 11:41 AM
05 sti cluster into an 04 problems? nixgame22 Electrical & Lighting 22 01-10-2008 02:35 PM
05 wrx cluster into an 02? Superorb Interior & Exterior Modification 16 01-30-2007 04:26 PM
04-05 STi interior into an 02 WRX? designfate Interior & Exterior Modification 6 11-14-2006 03:10 PM
