03-31-2007, 05:25 PM | #1 |
Member#: 140335
PRSIC
Vehicle:2003 03 WrX Aspen White |
what is the max boost on a vf39?
hey guys I have a 03 wrx with a vf39 and other supporting mods... I wanted to know... what is the max boost on a vf39??? ??
03-31-2007, 09:04 PM | #2 |
Member#: 37719
Vehicle:2003 WRX |
You got that right!
03-31-2007, 11:16 PM | #3 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
The VF39 can get up to about 21-22 psi of boost but that is as far as it will go. This will depend on the pressure drop across your intercooler however.
03-31-2007, 11:30 PM | #4 |
Member#: 92003
SCIC
Vehicle:04 bicycle! |
weld the wastegate shut and tell us; i'd say about 50 psi
04-01-2007, 12:36 AM | #5 |
Member#: 103645
NESIC
Vehicle:2011 Subaru Legacy White |
im running 21 on my vf34...i know they arent the same turbo though, and not sure if will help with info on the 39 but its worth a shot
04-01-2007, 09:48 AM | #6 |
Member#: 94131
Vehicle:08' SRT Caliber Hard to keep clean black! |
really it's gonna depend on your tune, but probably in the low 20's on most setups, higher if your running water/meth.
04-01-2007, 10:22 PM | #7 |
Member#: 140335
PRSIC
i HEARD OF SOME BOOSTING UP TO 25 PSI ON C16 VP FUELS... U THINK IT COULD BE DONE?
04-02-2007, 12:14 AM | #8 |
Member#: 65065
Vehicle:2004 EJ205 STi 2007 Forester STi |
^clever use of the caps lock
04-02-2007, 12:28 AM | #9 |
Member#: 61197
Vehicle:2004 WRX vf39 + goodies... |
i'd say low 20's, above that and the turbo won't last long..
04-02-2007, 12:42 AM | #10 |
Member#: 145084
NWIC
Vehicle:1995 Impreza LSTI |
04-02-2007, 03:32 AM | #11 |
Member#: 48219
Vehicle:. Always drive the race line . |
My VF39 usually runs at about 1.7bar. I have gotten it to hit 2.0bar when ambient temps were around 25F. But for everyday street driving I set the boost to 25psi. This is on straight 93 octane.
Of course this is in the low to mid range. At high rpms it has trouble holding more than 19psi at 45F and about 18psi at 75F. |
04-02-2007, 10:01 AM | #12 |
Member#: 85990
Vehicle:2003 WRX 240hp/240tq WRB |
Low 20's with a proper tune sounds about right.
04-03-2007, 12:19 AM | #13 |
Member#: 140335
PRSIC
how many hp's can I make with this 21-22psi?
04-03-2007, 12:27 AM | #14 |
Member#: 64466
Vehicle:05, STI on green |
As many hp's as you want. LOL......what does it say under your user name besides Scooby?
04-03-2007, 01:09 AM | #15 | |
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
300/300 should be attainable on high octane or water/meth.
I'm using a VF39/FMIC on 92 pump and run 19psi through peak, tapering to 17psi at redline. I've pushed it as far as 24->18 on high octane (100+). Quote:
http://forums.nasioc.com/forums/showthread.php?t=972189 |
04-03-2007, 03:24 AM | #16 |
Member#: 100520
Vehicle:2003 wrx wrb/aspw |
yeah cause i was runnin 21 psi on third and 24 on 4th and 5th and guess what?? i blew the turbo kinda. rite now my turbo wont boost past 10 and when it does it drops below 0 and major power loss. but before that it was runnin like a champ. i hit 260whp and 280 tqe w/o meth or alk inj so to put it on safe grounds go under 21. now im getting a evo3 16g im still waiting for to come. good luck
04-03-2007, 05:18 AM | #17 |
Member#: 54213
Vehicle:2013 Impreza STi Silver |
... I'd like to see someone try that just to see what they'd run. Their engine would probably blow up before making it down the track once.. You never know though..i've seen stock Civic engines take huge shots of Nitrous and still pull a few times before dying.
What is the max boost for the VF48? | Tuned200 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 14 | 02-17-2009 04:59 PM |
AP V.1, What is the max boost psi it will read? | Bruce Wayne | AccessPort | 2 | 01-10-2008 11:28 PM |
what is the max boost for the sti | 4 banger | Tri-State Area Forum | 1 | 09-23-2003 07:24 PM |
what is the max boost the sti can hold | 4 banger | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 09-22-2003 11:44 PM |
What is the MAX boost for a VF30 | fatray | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-16-2003 02:21 PM |
