07-16-2009, 09:15 AM | #1 |
Member#: 42008
Vehicle:02 FIZZ GDA R.I.P. SQC #043 |
Is it possible to swap an 04 STi console into an 02 WRX?
Is it possible to swap an 04 STi console into an 02 WRX? The harnesses look as if they may fit, but the temp control on my 02 WRX has somewhat of a manual set-up- you turn the dial and it pulls on a "temp tube". With STi's "drive by wire," are the HVAC controls also monitored digitally?
07-16-2009, 09:34 AM | #2 |
Member#: 169914
NWIC
Vehicle:2017 WRX 2021 Onyx XT |
You must have not done any searching at all.
The console will swap over directly, the HVAC (temp controls) will not swap over without redoing your wiring harness for your car. |
07-16-2009, 11:42 AM | #3 |
Member#: 206350
E. Canada
Vehicle:2004 PSM WRX VF30 |
You can use the WRX Limited which has the same style manual HVAC controls as you do now.
Every other trim piece works okay |
07-16-2009, 02:28 PM | #4 |
Member#: 42008
/\ Thanks for the info.
I was considering the 05+ STi console swap but seems like more work than I care to do without buying a whole dash out of a wrecked car. http://forums.nasioc.com/forums/show...into+an+02+WRX |
07-16-2009, 02:37 PM | #5 |
Member#: 30907
SWIC
Vehicle:SWP GDB-G |
...or you could just pick up the shifter trim ring, install it and save yourself a lot of trouble.
Unless you really want the semi-auto climate control. |
07-16-2009, 03:05 PM | #6 |
Member#: 149730
Vehicle:2002 Impreza WRX PSM |
why no do this get a 2005 sti console expect the trim around the radio/climate controls and for that trim you can use the one out of 2006/07 wrx tr model??????
07-16-2009, 04:40 PM | #7 | |
Member#: 206350
E. Canada
Find whatever other parts you can uber cheap , but you only have to worry about the HVAC controls/trim from the TR PS is that an STi cluster in your picture or just a red WRX one |
07-16-2009, 06:07 PM | #8 |
Member#: 162932
NWIC
Vehicle:2020 Tacoma TRD Bro Super White |
05>04 (I have since painted the STi shift garnish a graphite color.) |
07-16-2009, 09:59 PM | #9 |
Member#: 149730
yes that is an sti cluster....i'm guessing its an 04 sti cluster since the center console trim is from a 04 sti....only thing is the steering wheel looks like its from a 2005 sti
07-16-2009, 09:59 PM | #10 |
Member#: 149730
07-17-2009, 03:53 AM | #11 |
Member#: 69370
E. Canada
Vehicle:2007 Legacy GT DGM |
I would actually suggest just buying the center vent part (a direct swap with the old center vents and useless excuse for a cup-holder) and swapping it in. You can leave the rest of the center console unchanged. I personally did this and I like the look much better than what the car was originally like, and the cost was very minimal (i got the part used). If you want to do the console swap, there are threads here about it, but it is very involved and involves lots of parts including moving the handbrake (which was the reason I didn't do it, I prefer the handbrake placement in the v7 and early v8; I don't like the late v8 and v9 handbrake placement).
07-17-2009, 09:13 AM | #12 | |
Member#: 169914
NWIC
If you do more searching (even under my past posts) you'll find quite a bit information on swaps, I've swapped a few interiors from 02-04 to 05+ interiors. I hate to say it, but this topic comes up in a new thread more often than it should |
07-17-2009, 11:36 AM | #13 |
Member#: 206350
E. Canada
Is the TR a black color or was that painted?
07-17-2009, 11:37 AM | #14 |
Member#: 206350
E. Canada
PS I just realized he wants the 04 STi console... not the 05+
07-17-2009, 11:38 AM | #15 |
Member#: 169914
NWIC
07-17-2009, 12:01 PM | #16 | |
Member#: 149730
05 04 |
07-17-2009, 12:32 PM | #17 |
Member#: 169914
NWIC
07-17-2009, 12:34 PM | #18 |
Member#: 149730
07-17-2009, 12:45 PM | #19 |
Member#: 30907
SWIC
Vehicle:SWP GDB-G |
07-17-2009, 12:48 PM | #20 |
Member#: 149730
07-17-2009, 03:45 PM | #21 |
Member#: 169914
NWIC
07-17-2009, 04:36 PM | #22 |
Member#: 149730
trying to swap an 05 sti engine into my 02 wrx | chinpocoman | Subaru Conversions | 8 | 02-11-2009 09:25 AM |
Is it possible to look up the IPs used by an AIM SN? | vision.dynamix | Off-Topic | 15 | 12-09-2008 02:37 PM |
is it possible to swap a front end from a saab?? | bereda | Interior & Exterior Modification | 31 | 12-05-2008 06:56 AM |
Is it possible to bridge 4 channels of sound into 2 for more total power? | Uber Wagon | Car Audio, Video & Security | 5 | 11-03-2003 07:05 PM |
Is it possible to create a direct plug in for an ipod? | Hope2BinWRC | Car Audio, Video & Security | 4 | 07-29-2003 09:16 PM |
