Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2024
Old 08-08-2009, 11:47 PM   #1
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Default 04 STI 6 speed into 03 WRX and vice versa
This mightbe the stupides question ever but here it goes. I want to put a 5 speed ppg tranny into my sti and I want to put my 6speed from my sti into my 03 wrx. will i need anything extra or will all parts swap over? Can I use my sti axles with the 5 spd? can i use the wrx axles with the 6 speed? rotors etc?
Thanks in advance
I'm Slow is offline   Reply With Quote
Old 08-09-2009, 12:00 AM   #2
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
why??
Thom is offline   Reply With Quote
Old 08-09-2009, 09:38 AM   #3
Spiider
Member#: 13680
Well, knowing that the PPG 5 speed is a good option for some needs and the 6 speed is better others....maybe the reversal of the two is better for this guys needs.
I don't think its a stupid question at all.
Spiider is offline   Reply With Quote
Old 08-09-2009, 01:20 PM   #4
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Originally Posted by Thom View Post
why??
the reason is because my wrx is a nice dd with a vf22 and my sti has a hta 35r @ 513 whp.......I take the sti to the drag strip, for me the ppg's would have much better gearing for the strip. My only concern is the factory 5 speed case .
Old 08-09-2009, 01:29 PM   #5
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
i hear ya... well cool, i believe it is just the reverse of putting an sti trans into a wrx. sorry i dont know specifics.
Old 08-09-2009, 01:37 PM   #6
Beam
Member#: 29742
2011 STI
15 S1000R
Maybe call a dealership and get the specs /differences? If the length and spline count are the same, than you should be able to use them.
Beam is offline   Reply With Quote
Old 08-09-2009, 02:09 PM   #7
JSarv
Member#: 163445
l33t *******
[email protected]
They will swap over..
You will need a 3.90 (06-07) R180 rear for the sti. You will need a your wrx driveshaft (I think you can use it with an adapter for the R180)
You will need the mount for the trans and that is it... Your DCCD is going to be all jacked up and your WRX won't be able to use the DCCD unless you have an aftermarket controller.
I'd be concerned with that power and a 5 speed, not the gears the case..
-Jerod
JSarv is offline   Reply With Quote
Old 08-09-2009, 02:41 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
-Jerod
Wrong on the R180. The 2006-2007 R180's are 3.54 (39:11) because the 2006-2007 6MT has a 1:1.1 center diff. 1.1x3.54 = 3.9 final.
It's the 2004-2005 R180's that have a 3.9 (39:10) rear diff and a 1:1 center diff.
Old 08-09-2009, 04:40 PM   #9
JSarv
Member#: 163445
l33t *******
[email protected]
Sorry I meant he needs the 06-07 STI R180 to match his 5mt PPG box for the STI. Like you said the 5mt will have a 1.1:1 center needing a 3.54 rear..
Should have worded it better...
-Jerod
Old 08-09-2009, 05:42 PM   #10
kpluiten
Member#: 120273
06 WRBWRXWGN
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
I guess it depends on the year of the PPG box doesn't it? If it's a 2006-2007, it will need a 3.7 rear diff and I don't know of any R180 with that...
Old 08-09-2009, 09:43 PM   #11
JSarv
Member#: 163445
l33t *******
[email protected]
His WRX is an 03... I would make a educated guess its a 1.1:1 or 3.54 rearend...
Old 08-09-2009, 10:48 PM   #12
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Wrx is stock 03 trans and stock rear
Old 08-09-2009, 11:37 PM   #13
JSarv
Member#: 163445
l33t *******
[email protected]
Then you will need a 3.90 RP for your R160 on the wrx... Rallispec or similar can do that or you can pick up an older 3.90 LSD R160.
You will need a 06-07 STI 3.54 R180 rearend for your STI to match the 5 speeds 1.1:1 center ratio.
Then your done. Most likely since you have an 04, axles will swap right over as the fronts should all be female. If not, swapping front axles from car to car would do the job.
-Jerod
When your done you will have a spare 3.90 FD R180 that is not being used unless you want to convert your wrx to fit the R180 (hubs and brakes.)
Old 08-10-2009, 10:04 AM   #14
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Awesome info guys thanks. So at what power level does the case become an issue? Right now I'm making 513 whp and 488wtq but when I build the motor I'll be looking at 700-650whp
Old 08-10-2009, 07:52 PM   #15
JSarv
Member#: 163445
l33t *******
[email protected]
Call andrewtech...
'02 JDM sti 6 speed into '07 wrx auto mbelitsk Subaru Conversions 8 05-07-2009 04:42 PM
FS: IN: 04 STi 6 Speed With Center Diff And Rear Diff STiGuy46554 Drivetrain 5 09-20-2008 12:10 PM
04 sti wheel bearings into 03 wrx Lazyxturb0 Brakes, Steering & Suspension 9 04-09-2008 10:47 AM
Swapping 6 speed into 03 wrx Jpizzzle Transmission (AT/MT) & Driveline 6 04-24-2007 11:29 AM
USDM STI 6-speed into USDM WRX? hobbzz Transmission (AT/MT) & Driveline 12 01-12-2003 03:26 AM
