Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2024
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-04-2009, 11:45 PM   #1
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Tuned @ FAT by Snail Perf
Default 300+ hp on stock wrx trans.
I've done the reading and all that good stuff all over the forums and wanted to know personally how many guys here in swic have setups around 300whp on the stock wrx trans (late 03 to 07) and are not having issues. My trans has not seen any serious mods aside from my recent cobb stage 2 and I will be switching to a vf48 here fairly soon. Generally speaking, will the trans take the power provided I shift conservatively? Also concerned about the clutch needing to be replaced too. Current mileage is around 40k on it. Thanks in advance for input.
- Ryan
BugeyePB Rex is offline   Reply With Quote
Old 10-05-2009, 12:16 AM   #2
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
Honestly is all in how you drive, use your clutch as a fuse for the system and you'll be fine. You wont make crazy power on a VF48 dont beat on it and you'll be fine. . .
and thats from someone that swapped to a 6spd lol. I just like the feel of the 6mt better.
ChandlerWRX06 is offline   Reply With Quote
Old 10-05-2009, 12:49 AM   #3
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Hah, comforting knowing you went to a 6mt. And apparently 300whp is an attainable goal according to Clark Turner. When I asked him how much this system had the potential to put down with the supporting mods I'll have that's the figure he claimed. What about the stock clutch...? Think it'll hold or should I expect to replace it with a new one pretty soon?
Old 10-05-2009, 01:45 AM   #4
Evil Imports
Member#: 14732
i used to have a 02 wrx with 289whp on the 5 speed and no problems
Evil Imports is offline   Reply With Quote
Old 10-05-2009, 01:47 AM   #5
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Don't try and shift like you're driving a mustang and chirping 2nd, and you should be alright.
PS PM KahunaKing and ask him his thoughts on 5 speed strength. And ask him how many launches he's put through his.
KP is offline   Reply With Quote
Old 10-05-2009, 11:23 AM   #6
v8eaterWRX
Member#: 108547
2017 Tundra 1794
Lifted, Armored, Muddy AF
I ran over 300whp on a stock 05 5mt for a few years without any issue. In fact that same tranny is now in another car with over 300whp with still no issue. Its all in the driver to some extent.
v8eaterWRX is offline   Reply With Quote
Old 10-05-2009, 01:10 PM   #7
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
yeah, the 5mt in the foz that had the same vf turbo your going to be running handled the power just fine on and off the track. though im not sure how much difference there is btw the foz 4.44 gears and the wrx gears
SubeSTIle is offline   Reply With Quote
Old 10-05-2009, 04:50 PM   #8
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Awesome info everyone thanks for the input. I'm not an autoxer but I've been told my shifting is rather smooth so I don't think the shock to the trans will be much of an issue. Stock clutch ok for the power then.... or should I plan on changing it out soon?
Old 10-05-2009, 05:07 PM   #9
furryfootstool
Member#: 200526
all depends on your driving. i've heard people dropping their trans just getting on the highway. who knows, but there are plenty of people with 300hp with stock trans. i have my stock trans and clutch at 127k with a 16g. if you don't dog it too much, it could survive, but if you want piece of mind, go with a 6spd
furryfootstool is offline   Reply With Quote
Old 10-05-2009, 05:12 PM   #10
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
oe clutch should be fine.
Old 10-05-2009, 06:50 PM   #11
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
I would be suprised to see 300whp on a VF48 with pump gas to be honest.
Clark Knows his stuff, but I would expect to see close to 300 but on a 2.0L and a vf48 (which is a 39 with a bigger hotside) 280 to 290whp is a closer to top HP. I made a little over 280whp with my vf39 on AZ91oct on my 2.5L.
Regardless, your trans should be fine so long as you dont drive like an R-tard
oh PS: OEM clutch would be fine, but if youre at 40K on it I would plan to replace it soonish.
Old 10-05-2009, 07:29 PM   #12
Role Reversal
Member#: 191885
2000 Forester
i am running 366 awhp on an 05 5mt
Role Reversal is offline   Reply With Quote
Old 10-05-2009, 09:15 PM   #13
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
i put 370whp to my old 04 wrx with the stock trans. it was fine but when i replaced the clutch with a race clutch it blew up. then i got a full RA drivetrain
AWDshenanigans is offline   Reply With Quote
Old 10-05-2009, 09:43 PM   #14
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
.... Brandon did it on a Cobb AP Stage 2 map on FAT's last dyno day. Not saying it's common, but saying it's possible
Old 10-05-2009, 10:03 PM   #15
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
I thought 300 was a bit high myself... but hey if he can pull it off then great! I know I've seen these numbers from the 2.5's but I'm curious to see how high he can get the 2.0. Hoping for a bit better spool though as the 48 is a bit more free flowing (minimal I know, but eh, everything helps). I'll get some numbers posted once I have everything set up. NAU autoclub is having a dyno day down at Goodspeed on Nov. 17th so I'll know exactly what I'm putting down by then.
Old 10-05-2009, 10:19 PM   #16
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
The only difference in the 2.5 and 2.0 is going to be spool. The heads flow very close to the same and it's still the same turbo.
Old 10-06-2009, 12:05 AM   #17
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
And the 48's bigger hotside should help on the topend. . . like i said, Clark knows his shyte to say the least lol.
Im interested in seeing my new set-up's numbers, i might have to dyno again
(then again after Goodspeed's new software on the maha ill probably net lower than my first 363whp with a frontmount, ewg, and higher boost now lol)
Old 10-06-2009, 02:07 AM   #18
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Dyno on a Mustang so you can accurately compair numbers to Ken, Mark, and Erik.
Old 10-06-2009, 02:35 AM   #19
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Do Eet!
Old 10-06-2009, 04:26 AM   #20
sh1ftn
Member#: 166645
02 WRX
is there any difference between the '02 wrx tranny compare to the later wrx models?
sh1ftn is offline   Reply With Quote
Old 10-07-2009, 01:04 AM   #21
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Yes. The 02's and early 03's have weaker gears. The late 03's and up got the wider RA style gears. Less prone to grenading. I double checked my VIN and made sure I had the late year 03. Woot!
Last edited by BugeyePB Rex; 10-07-2009 at 01:04 AM. Reason: I can has capital letters...?
Old 10-07-2009, 02:07 AM   #22
AWDboostADDICT
Member#: 196257
02 wrx 354 whp RIP
10' genesis coupe
- Ryan
I am vf30 + supporting mods, definantly making 300-320 whp.
my stock EARLY 02 trans lasted 180k, 60k of that was on the current 300-320 whp setup, if you treat it nice, it will treat you nice.
AWDboostADDICT is offline   Reply With Quote
Old 10-07-2009, 02:25 AM   #23
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
+1
my early 02 trans was nearly perfect before sold it at 100k+, every mile past 3k saw 300-350 whp ..i hear its still running in PA. The stock exedy disc was forgiving enough to keep everything intact, anything with more grip would have killed it.
fastnoypi is offline   Reply With Quote
Old 10-07-2009, 02:33 AM   #24
AWDboostADDICT
Member#: 196257
02 wrx 354 whp RIP
10' genesis coupe
Originally Posted by fastnoypi View Post
+1
I think mine finally gave way becuase of my quite unforgivable act 6 puck
Old 10-07-2009, 10:27 PM   #25
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
only speaking on behalf of the possible clutch upgrade...I replaced my worn out clutch at 80k, stock trans w/ updated gears. I have an act clutch w/ the heavy duty pressure plate, oem-ish street disc (spring) and lighter flywheel (14lbs). Its actually a modified exedy clutch, regardless. I love it, but most would hate it. Feels like an old muscle car when using clutch, but my left leg is now buff and I am used to it. The flywheel is weird daily driving but I got used to it and adapted. I think it was worth it but most curse me for it. I would prolly look into exedy next time around.
I have never smelled the disc when I launch it after the upgrade.
DerickRyoung is offline   Reply With Quote
Highest hp on stock wrx 5 speed? Flatline86 Transmission (AT/MT) & Driveline 5 11-15-2008 10:04 PM
fastest 1/4 mile times on stock wrx trans kalescustom Transmission (AT/MT) & Driveline 2 09-07-2008 05:21 PM
Most Hp on stock wrx heads 13secwrx Proven Power Bragging 56 07-20-2005 10:49 AM
300 hp on a 04 WRX, What mods are needed to get those numbers? dubba you are ex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 06-10-2004 09:23 PM
Max Boost & HP on Stock WRX Turbo noob Newbies & FAQs 4 12-21-2002 06:19 PM
