02-17-2010, 02:44 PM | #1 |
Member#: 166126
South East
Vehicle:03 WRX WRB |
PLEASE HELP clutch and flywheel combo not working
i have a fidanza aluminum flywheel HERE its in good shape but needed to replace the clutch. i had the fidanza 3.2 HERE before but wanted to go a less aggressive this time so i order a stage one ACT clutch kit HERE . the guy thats installing it says he has done subaru clutches before. so i get a call from the guy today and he tells me this combo will not work that the pressure plate is scraping the bell housing. could this be?? or has it just been installed wrong??
Car is a 03 WRX
02-17-2010, 08:19 PM | #2 |
Member#: 222089
South East
Vehicle:2010 Satin Pearl White |
are you sure you got the right parts shipped to you?
02-17-2010, 08:26 PM | #3 |
Member#: 166126
South East
02-17-2010, 08:27 PM | #4 |
Member#: 222089
South East
do you have the flywheel from the other car that you got the clutch from?
02-17-2010, 08:30 PM | #5 |
Member#: 166126
South East
no but i could get it
02-17-2010, 09:25 PM | #6 |
Big Ron
Super Moderator Member#: 18062
You did read the Clutch & Flywheel FAQ where it says to buy all of your clutch/flywheel crap from ONE MANUFACTURER right? Research is what separates the men from the boys...research starts with the sticky threads, use them next time.
02-17-2010, 09:32 PM | #7 |
Member#: 222089
South East
02-17-2010, 09:43 PM | #8 | ||
Member#: 166126
South East
as i stated before i got the whole clutch kit from ACT |
02-17-2010, 09:47 PM | #9 |
Member#: 222089
South East
Like I said, load the car on a flat bed, secure everything and take it to a shop that is used to working on Subies specifically.
02-17-2010, 09:55 PM | #10 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
You have one of the mythical strange thickness Fidanza flywheels. Went through the exact same thing with a customer a few months back. Fidanza has two different thicknesses listed as they swear there are two different flywheels for 02-05 wrx's. The thickness of the one you have is about .25" thicker than normal and with some pressure plates causes a problem.
Tony |
02-17-2010, 10:04 PM | #11 |
Member#: 222089
South East
hey, here we go..... dude has an answer for you....
But I thought you had said on the other forum that this setup came out of another car. maybe I misread. |
02-17-2010, 11:10 PM | #12 | |
Member#: 166126
South East
this clutch and pressure plate came out of one car. the flywheel was in my car to begin with. |
02-17-2010, 11:44 PM | #13 |
Member#: 222089
South East
idk man, if it was working in one car and now it's not working in your car there might be something up here.
02-18-2010, 09:14 AM | #14 |
Member#: 238755
Vehicle:2006 IMPREZA WRX STI BLACK ON BLACK |
hey man i ran in to that prob with my 95 impreza suabru could have changed the clutch and you could have gotten the first flywheel design and maybe like the 2 gor 3rd clutch design it took me forever to figure that out but call subaru and see if they made changes to your year on the clutch and if so then thats propbly your problem you quiet possibly have 2 defferent designs on you clutch kit.. if you have any questions call me at 253-579-2267
03-03-2010, 12:58 AM | #15 |
Member#: 65576
Vehicle:2002 WRX WRB |
Hey OP (or anyone else can chime in). I've got a 2002 WRX. I'm about to buy a steel Fidanza flywheel p/n 210001 because it says for 6/01-07, but there is also p/n 210221 for up to 6/01. Is the 6/01-07 the production date of the tranny or the car itself? I want to be sure I don't run into this thickness problem.
Also should mating this with Exedy KSB01 be ok? |
03-03-2010, 01:46 AM | #16 | ||
Member#: 202146
SCIC
Vehicle:2018 Crosstrek Crystal White |
Re: PLEASE HELP clutch and flywheel combo not working
03-03-2010, 01:58 AM | #17 |
Member#: 166126
South East
i ended up putting a stock flywheel back on and it is working fine. i would not try to mate this flywheel with any other clutch that its not made for. i will try and find a part number for my old one and post it up
03-03-2010, 11:05 AM | #18 |
Member#: 65576
The KSB01 is a factory replacement clutch so I would think the Fidanza should work no problem. I'd appreciate the p/n you had used. Thanks.
Clutch and Flywheel Combos ! Installed or Shipped! | Gruppe-S | Bay Area Impreza Club Forum -- BAIC | 0 | 11-15-2005 07:37 PM |
6 spds, 5spds, Clutch and Flywheel combos! | Gruppe-S | Drivetrain | 13 | 10-07-2005 10:00 PM |
ACT Clutch and Flywheel Combos for WRX/STi! Transmissions also! | Gruppe-S | Drivetrain | 12 | 09-13-2005 06:00 PM |
New 2.5rs Exedy clutch and flywheel combo f/s | greenemac2003 | Private 'For Sale' Classifieds | 33 | 05-01-2005 12:07 PM |
Clutch and Flywheel combo | Virgil | Transmission (AT/MT) & Driveline | 3 | 09-18-2003 10:07 PM |
