Welcome to the North American Subaru Impreza Owners Club Monday June 16, 2025
Old 12-21-2002, 10:54 AM   #1
noob
Member#: 26030
2003 WRX Sedan
Default Max Boost & HP on Stock WRX Tubro
So, i know that the stock turbo has a maximum boost of 14-15 psi, pumping about out 227hp.
If one were to keep the same turbo setup, what is the max boost allowable (safe) by use of a boost controller? And the approximate corresponding HP?
noob is offline   Reply With Quote
Old 12-21-2002, 02:40 PM   #2
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Where did you get this 14-15psi stuff from?
I thought it was 13.5 stock
most people set it at 15.5psi for best results
M3sum is offline   Reply With Quote
Old 12-21-2002, 04:29 PM   #3
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
14.5 is stock psi i had thought?
03WRX83 is offline   Reply With Quote
Old 12-21-2002, 05:13 PM   #4
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 17 FoST
Everyone is getting different boost. Some people get 13.5, some are getting 15psi. I got spiking to 15.5 and it would settle on 14.8. Most people agree that the stock turbo runs out of steam around 16-17psi. I have my mbc set to 16.5psi. I see less spiking than with my fbc. Do a search and you'll see that some people think it's bad to run anything higher than15-15.5psi. Read their posts, then learn how to read your boost guage to find out what is dangerous and what's not, then decide if you want to go run higher boost.
Good Luck,
Marcel
scrappydoo is offline   Reply With Quote
Old 12-21-2002, 06:19 PM   #5
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
It really depends on your location. People at sea level can see higher boosts. I have seen upwards of 14.7 psi (.1MPa) on cold, dry days, and I'm at 300ft, I think (whatever Dallas is). Naturally, people in higher elevations can't see as high a number, so your mileage may vary when it comes to boost.
gjhsu is offline   Reply With Quote
300+ hp on stock wrx trans. BugeyePB Rex South West Impreza Club Forum -- SWIC 40 10-27-2009 06:31 PM
Highest hp on stock wrx 5 speed? Flatline86 Transmission (AT/MT) & Driveline 5 11-15-2008 10:04 PM
Most Hp on stock wrx heads 13secwrx Proven Power Bragging 56 07-20-2005 10:49 AM
Max WHP on stock WRX turbo wRxbeater11 Proven Power Bragging 35 02-28-2004 01:48 AM
I want to port & polish a stock wrx turbo myself any tips? cky211 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-13-2004 12:50 PM
