Welcome to the North American Subaru Impreza Owners Club Thursday October 3, 2024
Old 03-08-2004, 05:44 PM   #1
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Default What is the max Hp the stock WRX internals have been known to hold?
Thanks, Micah
Old 03-08-2004, 05:57 PM   #2
Kegger
Member#: 12024
'03 Cobra
700 rwhp 720 rwtq
Seriously though, are we talking at the crank or wheels?
Kegger is offline   Reply With Quote
Old 03-08-2004, 05:59 PM   #3
pfhlipwrx
Member#: 19319
Big Turkey here in TX, got 399.5 AWHP, with a Forced performance Green. So far he has only blown the factory 5 speed......
pfhlipwrx is offline   Reply With Quote
Old 03-08-2004, 06:00 PM   #4
Homemade WRX
Member#: 33782
96 3MI Racing
either works...I guess whp would be easiest to tell
so just state whp or bhp when telling.
Thanks, Micah
Old 03-08-2004, 06:00 PM   #5
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I have heard of 400+whp and 120 traps....
Triple X's car on a stock longblock.
mr2guru is offline   Reply With Quote
Old 03-08-2004, 06:01 PM   #6
T-WREXX
Member#: 40835
2002 Impreza WRX
For Sale Silver
Originally posted by Kegger
227
LOL
Actually I have a TBE and a intake so I know they can handle at LEAST 235hp.
Seriously though, it depends on how the EJ20 is set up, and who has done the tuning. I have heard the bottom end can handle 400hp, now the top end, that's a different story.
T-WREXX is offline   Reply With Quote
Old 03-08-2004, 06:16 PM   #7
Homemade WRX
Member#: 33782
96 3MI Racing
thanks fellas
Old 03-08-2004, 06:17 PM   #8
Kegger
Member#: 12024
'03 Cobra
700 rwhp 720 rwtq
Thanks, Micah
Like mr2guru said, 400whp is definitely doable. But I would never run that much power as a daily driver. You can get that power from one of the larger turbos with 23+ psi and race gas. But as a daily driver, I would turn the boost down and run 93 octane and safely be around 330-350 whp (depending on the type of dyno used)
HTH
Craig
Old 03-08-2004, 07:45 PM   #9
rexaroo
Member#: 35732
2002 WRX Wagon
If you are interested in your engine lasting 100K mi., don't exceed 270-280 hp. That's at the crank, guys, not the wheels.
A simple Cobb Stage I and cat-back exhaust will put you right there with a little margin for safety.
The U.S. EJ205 WRX engine has cast pistons instead of forged and softer valve materials than the STi, which is why it's not good to take it up to 300+ like a lot of guys do.
Course if you are only interested in the engine lasting 10-20K miles before a major re-build, sure, pump the horses up as high as your wallet will allow.
You CAN get huge horsepower safely in the WRX, but you have to strengthen the internals with stronger pistons and valves.
Don't take my word for it--Mike Shields is the WRX expert and he says 260-280 crank horses is the upper safe limit on the stock engine. And believe me, he's re-built a LOT of them from customers that exceeded that. His site is at www.spdusa.com if you want to check it out.
rexaroo is offline   Reply With Quote
Old 03-08-2004, 08:22 PM   #10
mexicanpizza
Member#: 16779
2021 Toyota 4Runner
Is that the same Mike Shields that claims the WRX downpipe cat isn't restrictive?
mexicanpizza is offline   Reply With Quote
Old 03-08-2004, 08:40 PM   #11
forcefed
Member#: 38804
08 WRB/Gold STI
05 LGT Wagon (SOLD) :(
won't be too long before those connecting rods snap at that whp
forcefed is offline   Reply With Quote
Old 03-08-2004, 09:06 PM   #12
rexaroo
Member#: 35732
2002 WRX Wagon
He didn't say it wasn't a restriction.
What he said was "the downpipe cat is known to run a clear 300-320hp before it is considered a power constriction. It is just not a significant restriction at the power levels we can achieve on pump gas. Yes, if we eliminate the main cat there is a mild improvement in spool-up of the turbo, but not huge gains that justify turning your car into a pollution machine."
In other words, since the stock Rex engine can only be safely bumped to 260-280 hp on pump gas, there's no point in taking it out.
Old 03-08-2004, 09:22 PM   #13
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
400whp... on what dyno?
MB38 is offline   Reply With Quote
Old 03-08-2004, 10:00 PM   #14
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
don't forget that the opinions of SPDUSA may be reverse-biased.
Hey man, if you can't pay don't play.
That's all I have to say about modifying your car.
That being said, about the longetivity of the engine with high mods, the WRX is still pretty damn new. Let's see, InternationalB on i-club blew his stage 4 330-360 hp motor at like 90K miles or something for no reason.
I can't think of that many other examples but I think Mike Shields may be in the right range (perhaps a tad bit low but i mean only god knows for sure) for the amount of power this engine can reasonably hold for 100K miles.
verc is offline   Reply With Quote
Old 03-08-2004, 11:14 PM   #15
Homemade WRX
Member#: 33782
96 3MI Racing
yeah I plan on just doing simple bolt on that don't strain the engine...planning on about 210-240 whp for daily driver...when I get the money
don't need ALL that power like the GD WRX...I'm lighter
Old 03-09-2004, 01:24 AM   #16
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
I ran my car with 230 ftlbs of torque to the wheels for 20k miles plus before losing the radiator to a rock killed the engine. I'll be running it at 270whp here soon as a daily driver and I'd be happy to bet you I get another 20-30k miles with no issues. It's all in how well you maintain the motor and whether you got a good motor from the factory. Use good oil, spend the money to get proper fuel additives, oil additives, etc... and you'll be able to run a 250whp-290whp wrx for a LONG LONG time. Don't expect to run over 290-300whp on 93 octane though.
crazyhorse is offline   Reply With Quote
Old 03-09-2004, 04:30 AM   #17
HighWayDrifter
Member#: 8908
2012 Ford Raptor
snapped a cam in my 02 motor after an overboostfest (over boosted 3 or 4 times) and it finaly went, head gasket, cam and god only knows what else. Word to the wise, DO NOT OVER BOOST. haha
tends to blow **** up.
oh and i have one tranny under my belt so far.
HighWayDrifter is offline   Reply With Quote
Old 03-09-2004, 09:42 AM   #18
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Default tuning to 250 whp
250 whp is me all the way, i wish to tune my car to that point. i have a perrin short ram and a tuboxs axle back to start. an up pipe and down pipe are next, along with a utec. what other mods are most necessary? tmic? bigger turbo? injectors? fuel pump?
slowgenius is offline   Reply With Quote
Old 03-09-2004, 11:11 AM   #19
robvas
Member#: 17466
Might be a better idea to post a thread
"Who's making over 275 wheel hp, and how long have you been doing it? How many dyno pulls/quarter-mile runs?"
robvas is offline   Reply With Quote
Old 03-09-2004, 02:04 PM   #20
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I made 411 whp at 27 psi before I chickened out on a stock 2.0. I have trapped as high at 118 on a stock engine and that engine is still running by the way.
I also snapped at rod at 405 ft/lbs so I would say 400 whp is pushing the limits of those rods.
It's all in the tuning boys and girls!
Phil (motoxphil)
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 03-09-2004, 02:40 PM   #21
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
You can get your car into the very high 12s/very low 13s and be "safe" for quite a long time. This'll put you at the USDM STi level, power wise. Depending on dyno, that's anywhere from about 220awhp to 260-270awhp. That's good enough for a lot of people.
Old 03-09-2004, 03:13 PM   #22
Homemade WRX
Member#: 33782
96 3MI Racing
ok so if I went with that method I should expect low 12's then?
sounds great!!!
500 lbs makes a lot of difference
Old 03-09-2004, 03:24 PM   #23
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
SlideWRX is offline   Reply With Quote
Old 03-09-2004, 03:54 PM   #24
Prestige Motorsports
Member#: 13158
2002 Impreza WRX
Sedona Red
It is all in the tuning and in how it is treated. Yes you can make 400 whp on a stock USDM EJ205 engine and do it for a long time. You can also blow one up at stock power levels.
As far as taking the word of SPD, I wouldn't listen. This is the same man who claimed several years ago that you would gain no power from adding an intake to a 2.5. He kept claiming this after numerous dynos showed hp increases of 10-15 wheel horsepower. Mike is a good guy, but has always been a naysayer as far as what can and can't be done. If the DSM community had a bunch of guys like that in it they would all still be happy running low 14 second quarter miles.
Prestige Motorsports is offline   Reply With Quote
Old 03-09-2004, 04:06 PM   #25
bryan carbon
Member#: 34060
Phil (motoxphil)
Back when you were at TurboXS or with your new gig?
bryan carbon is offline   Reply With Quote
Max hp with stock internals JC951T Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 08-15-2005 06:19 PM
What is the MAX HP on a Stock Block WiredWRX Proven Power Bragging 10 04-19-2004 05:03 PM
what is the max boost the sti can hold 4 banger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-22-2003 11:44 PM
max boost on stock wrx internals fastwrx1 Proven Power Bragging 1 03-22-2003 02:09 AM
What is the max HP and Torque the automatic 2.5RS and WRX can take? Sugar T General Community 2 11-01-2002 03:30 PM
