Welcome to the North American Subaru Impreza Owners Club Sunday October 6, 2024
Old 07-20-2004, 11:26 AM   #1
PJ311
Member#: 41077
2002 Impreza WRX
Question Helix DP with Borla Catback
Didn't know if I should put this here or in the Aftermarket Forced Induction. I'll try here first. My present setup is a Helix up and down pipe and I have a Borla Hush catback to install with it. The only problem is the Borla Hush is made to bolt onto the stock downpipe with a donut flange. The Helix downpipe has a flat surface.
Anyway I was just wondering if anybody has this same setup and if they do, how did they go about connecting the two.
Thanks
PJ311 is offline   Reply With Quote
Old 07-20-2004, 11:50 AM   #2
mrbigisbudgood
Member#: 54378
2023 WRX
#1 Do a search.
#2 I mounted the same setup on my car using the stock doughnut gasket. I also used a double thick flange gasket with a steel insert on the face of the downpope and trimmed everything so the lip of the doughnut gasket interfaced perfectly with the gasket. Basically it goes....downpipe flange -> flange gasket with insert -> stock doughnut -> Borla round flange. Copper spray is also your friend. I have zero leaks in about 13000 miles.
mrbigisbudgood is offline   Reply With Quote
Old 07-20-2004, 01:21 PM   #3
Rickyh
Member#: 40453
Bolted mine together without any gasket and it doesn't leak.
Rickyh is offline   Reply With Quote
Old 07-20-2004, 04:45 PM   #4
JJD92
Member#: 39360
2016 Forester XT
Dark Grey
Hello,
I have the borla Hush and order the Helix downpipe. So it bolt on without any adapter? Do you have photos? I believe that it would need some kind of fabrication. If it fit rigth away would be very nice. How about the restriction?
how does it sound?
LAter,
JJD92
JJD92 is offline   Reply With Quote
Old 07-21-2004, 12:02 PM   #5
PJ311
Member#: 41077
2002 Impreza WRX
JJD92....I don't have it connected yet, still trying to figure out how to do it.
Rickyh.....But you don't have a Borla Catback correct?
mrbigisbudgood......Do you have any pics of your setup?
Cheers and Thanks
Old 07-21-2004, 02:35 PM   #6
Rickyh
Member#: 40453
I have the Borla Hush catback connected to a Helix dp. I bolted everything up as is right out of the box.
Old 07-22-2004, 09:44 AM   #7
PJ311
Member#: 41077
2002 Impreza WRX
Rickyh, I've been trying to email you on this from another post with a similar topic, but think I've been emailin the wrong guy. Do you have any pics of this? I'm just wondering how you connected a 3 inch flat flange with a 3 inch donut gasket flange without getting any leaks? Appreciate the help guys, Thanks.
Old 07-22-2004, 03:14 PM   #8
Vector92
Member#: 40661
2002 Imprezza WRX
WRX Blue
Have a muffler shop weld on a flat 3" flange
Vector92 is offline   Reply With Quote
Old 07-22-2004, 11:52 PM   #9
PJ311
Member#: 41077
2002 Impreza WRX
Default Thanks
Thank you all for your advice and help. Had a 3 inch pipe added in and a 3 inch flange welded on, all works perfect. Cheers!
Another question now though:
HKS up and down pipe with a Borla Hush Catback.
Why am I not seeing performance gains????
The car doesn't seem to have the pull it did before, throttle response seems slower and the turbo seems to take longer to spool up.
Other then being louder I'm a little disappointed. Am I getting turbo lag? I keep hearing that people re-flash the ECU in their cars.....is there something I should have done in order to get the performance gains that I expected from a 3 inch turbo back?
Old 07-23-2004, 09:19 AM   #10
sonicblue
Member#: 25227
2012 Escape
Without a re-tune, you won't get anywhere near the max gains from your TBE. Get Cobb's AccessPort and be happy-happy........
sonicblue is offline   Reply With Quote
Old 07-23-2004, 12:57 PM   #11
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
can anyone take pics for me? i can't decide between the catted helix or the maddad "metal" and 3ce. what do you guys think?
Bishop is offline   Reply With Quote
invidia v3 dp with borla hust catback methinkadoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-06-2006 07:11 AM
PDE DP WITH Borla catback SilWrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-06-2005 11:59 AM
Helix dp with borla 2.5 catback cobb st II Pimpson Car Part Reviews 2 05-29-2005 04:44 PM
helix dp with borla hush crosta21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-29-2005 08:50 PM
FS: Helix DP and Borla Catback - turboback solution ludecrous Private 'For Sale' Classifieds 25 02-20-2005 11:54 AM
