Welcome to the North American Subaru Impreza Owners Club Saturday June 14, 2025
Old 04-07-2006, 08:24 PM   #1
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
Default Can i put an STi engine into my 03 wrx?
i have an 03 wrx and i was thinking how much of a sleeper it would be if i could put a newer STi motor in my car. Would i have to swap transmissions as well? How much money would the swap cost (engine and trans)?
Also, can someone tell me the names of the diferent engines in subarus? Like ls1, ls2, l67, lt1 for GM but for Subaru?
thanks
affinity1 is offline   Reply With Quote
Old 04-07-2006, 08:28 PM   #2
trbo-4
Member#: 105455
2004 WRX Wagon
Cobb Stg. 2
A cheaper alternative would be to just swap the block for a STI 2.5 liter.
trbo-4 is offline   Reply With Quote
Old 04-07-2006, 08:31 PM   #3
greysave
Member#: 62395
2005 STI
Yes you can put an STI engine in an 03 wrx without swapping the transmission. Your power will be limited though because the wrx tranny can support only around 300 hp. I would recommend doing kaaz gears. The swap cost would depend on whether you were going to keep the stock wrx cams and heads or go with the sti cams which have avcs subarus version of variable timing. It also would depend on where you got the motor and whether it was new or used of course. Finally the subaru family of motors are ej. The 2.0l are ej207 for the jdm, I am not so sure of the usdm wrx and ej257 for the sti. the 20 and 25 state the displacement.
greysave is offline   Reply With Quote
Old 04-07-2006, 08:34 PM   #4
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
cant i just pull my motor and put in an STi motor? will that motor mate up to my 03 manual trans?
what is the 2jz motor?
also, the guy above said something about the block, does that refer to the entire motor?
edit: motor motor motor
Old 04-07-2006, 08:36 PM   #5
WRXVT
Member#: 17979
335i Blue
thanks
a wrx with a wrx sti engine does not equal a sleeper !
WRXVT is offline   Reply With Quote
Old 04-07-2006, 08:38 PM   #6
23b_Rex
Member#: 79394
02 gda
wrb
23b_Rex is offline   Reply With Quote
Old 04-07-2006, 08:48 PM   #7
CatfaceType-R
Member#: 81102
2jzgte or whatever is the toyota supra engine...
if you wana reserach this more..use the search button...a lot of people have done swaps..it is a long and tideous process unless someone else(a shop or skilled mechanic who knows jap wiring) is doing the job... it is also a pretty expensive project
u have to decide how much you want to swap out of your wrx to make it have what the usdm STi has
use the search button..search for usdm STi swap into wrx/bugeye/02-03 whatever..plenty of info on this on the board
CatfaceType-R is offline   Reply With Quote
Old 04-07-2006, 08:49 PM   #8
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
nice find....thanks!
Old 04-07-2006, 08:52 PM   #9
CatfaceType-R
Member#: 81102
i don't know much about swapping, but there have been a lot of thread on here lately...the worst part is wiring..the new engine just drops right in on the same mounts
Old 04-07-2006, 08:53 PM   #10
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
2JZ FTW..
-Kevlar- is offline   Reply With Quote
Old 04-07-2006, 09:21 PM   #11
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
from what ive read so far it looks like not many people have swapped an STi engine into their wrx but the engine would match up just fine. its just a big wiring hassle?
dollar for dollar would i be better off just modifying my wrx?
Old 04-07-2006, 09:24 PM   #12
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
dollar for dollar youd be better getting a v7.
Old 04-07-2006, 09:25 PM   #13
Evol
Member#: 109621
I Heart my
Ekonobox.
Just buy an STi and put a wrx wing on it and paint your brembo's red.
Or better yet, buy an STi, get a front mount, and put a 2.5 rs hood and trunk on it.
-Chance
Evol is offline   Reply With Quote
Old 04-07-2006, 09:39 PM   #14
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
que? what is a v7?
Old 04-07-2006, 09:40 PM   #15
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
-Chance
if i could afford an Sti, i would have one
Old 04-07-2006, 09:45 PM   #16
speedDman1
Member#: 103756
do a built internals on the 2.0...upgrade the gears, then put a ball-bearing turbo on it, and get a good dyno tune. Money well spent...
speedDman1 is offline   Reply With Quote
Old 04-07-2006, 09:47 PM   #17
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
que? what is a v7?
sorry.... jdm 2.0L sti engine
Old 04-07-2006, 09:50 PM   #18
LastResort
Member#: 99289
If you couldn't afford to purchase an STI, you really cant afford to assemble an STI.
LastResort is offline   Reply With Quote
Old 04-07-2006, 09:51 PM   #19
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
not necessarily....
Old 04-07-2006, 09:59 PM   #20
w0rx4me
Member#: 64574
2004 WRX Wagon
Why not build a better car and drop it into a Marauder?
w0rx4me is offline   Reply With Quote
Old 04-07-2006, 10:02 PM   #21
dj_booduh
Member#: 70861
2005 Scoobie WRX
The cost difference between the two initially would probably easily pay for the swap.
dj_booduh is offline   Reply With Quote
Old 04-07-2006, 10:04 PM   #22
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
im sorry, what are you saying?
ps. i love marauders. ls2/ls7 marauder would be sick
Old 04-07-2006, 10:10 PM   #23
veightkiller
Member#: 78967
2011 335i
wait gie yourself a break and do some more readings in this website..i think within a month you'll learn something..about subaru's
veightkiller is offline   Reply With Quote
Old 04-07-2006, 10:14 PM   #24
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
post a thread about the marauder in the OT. they love them also. good advice down there.
Old 04-07-2006, 10:16 PM   #25
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
yeah, i came from a grand prix gtp (L67). when i came into that community (www.clubgp.com) it was fairly small and only a few key people were starting to make go fast mods for the L67. i spent 3 years learning about the GTP and basically following the come up of the L67 aftermarket. im having a really tough time learning about the wrx because the community has soooo many members and there seems to be sooooo much to learn about the impreza. searching has its limits because there are sooooo many topics and its hard to find exactly what i need but im trying
Can I put a sti turbo on my 04 wrx? obxtoy Subaru Conversions 8 03-09-2025 11:31 PM
Can UTEC run an 06 sti engine in my 02 wrx w/ AVCS? breathinez UTEC 2 02-13-2010 10:15 AM
trying to swap an 05 sti engine into my 02 wrx chinpocoman Subaru Conversions 8 02-11-2009 09:25 AM
Can I put an STi cat-back on my 06 WRX? LXguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 07-27-2007 05:20 PM
Swapped a Complete 06 STi Drivetrain into my 03 WRX this weekend TROLL Subaru Conversions 20 04-26-2007 10:04 AM
