Welcome to the North American Subaru Impreza Owners Club Sunday February 25, 2018
Old 10-10-2017, 02:31 PM   #1
Animosity05
Member#: 432917
2005 WRX STi
World Rally Blue
Default 2005 STi Jewel Eye Retrofit?
I was just wondering if anyone has seen this retrofit before? Or maybe someone who's good at Photoshop could edit a blobeye Subaru to have Acura's Jewel Eye headlights? I've been seeing this retrofit more and more on the newer Subaru's but never on anything before the 08-14 or 15+ I'm very interested in it, and I just want to have an idea of how it would look like. I haven't been able to find any pictures on google. Here are some pics of the retrofit on newer Subaru's. I've even seen it done on a Evo 8. They seem to fit really well, but then again I think it might be because the headlights on these cars have a better shape overall for them. They're more slim, and longer than the fatter and shorter blobeye, so I'm unsure as to whether or not it would even look good, beyond that fact that it might not even physically fit inside the housing.
Animosity05 is offline   Reply With Quote
Old 10-10-2017, 05:00 PM   #2
Obviously Tyler
Member#: 395955
2016 WRX Premium
Rock Chip Metallic
First photo is 100% photoshopped, the other two are legit.
It's a cool mod, I'd like to see it done more.
Obviously Tyler is offline   Reply With Quote
Old 10-11-2017, 05:40 PM   #3
0411wrx
Member#: 474688
It might look cool but the output from those jewels are crap compared to properly retrofitted lamps using HID projectors. Don't ask me how I know, I just do.
Also, trying to align the jewel pods would be a PITA.
0411wrx is offline   Reply With Quote
Old 10-12-2017, 05:28 PM   #4
Animosity05
Member#: 432917
2005 WRX STi
World Rally Blue
So if I'm trying to increase my light output, which projectors which you recommend? I have the factory HIDs on the 05 sti, but I tinted my headlights, and now my lights are nowhere near bright enough, which is why I started looking into retrofits in the first place. I hardly ever drive my car in the night, but I'd still like to get brighter lights just in case. Thanks
Old 10-12-2017, 05:43 PM   #5
wrbrexx
Member#: 461037
2016 Subaru
World Rally Blue
Morimoto D2s 4.0, or the smaller morimoto mini h1 would be good. I think the 05ís have a pretty big reflector low beam bowl so the d2s should fit. Paired with some oem osram bulbs and it will be super bright, but the tint will restrict the light a little,
wrbrexx is offline   Reply With Quote
Old 10-12-2017, 06:37 PM   #6
Kinnikuman
Member#: 446214
Bug eye 4 life
Kinnikuman is offline   Reply With Quote
Old 10-13-2017, 09:19 AM   #7
Obviously Tyler
Member#: 395955
2016 WRX Premium
Rock Chip Metallic
Maybe start by removing the tint.
Old 10-13-2017, 04:07 PM   #8
Animosity05
Member#: 432917
2005 WRX STi
World Rally Blue
I RARELY ever drive the car at night, so I'm not looking to remove the tint, instead I'll look more into the Morimoto d2s set up. Does it make a difference with the wiring if I have the factory HIDs? Or would it hook right up, other than retrofitting the projector of course
Old 10-13-2017, 05:31 PM   #9
wrbrexx
Member#: 461037
2016 Subaru
World Rally Blue
Iím not sure, if the connections between the morimoto mini d2s bulb and oem sti ballast are the same (which I assume) then it should hook right up. If not you would need an adapter of some sort or to just get upgraded ballasts.
Old 10-13-2017, 05:55 PM   #10
amiexploited
Member#: 251061
2002 wrx sold
garage queen 2015 WRX
The 2005 STI should have a D2S connector. The D2S Morimoto kit will have a D2S connector. It should be brighter but you want to waste 200+ (with new bulbs) and crack open the headlights so you can see better with tinted headlights at night?
Better idea and same look. Bake your headlights and retrofit the projectors but paint the reflector bowl, shroud and anything chrome BLACK. Done.
amiexploited is offline   Reply With Quote
Old 10-17-2017, 01:00 AM   #11
Animosity05
Member#: 432917
2005 WRX STi
World Rally Blue
So the color of the reflector bowl doesn't change the light output at all? Like if I were to paint everything black on the inside? Ive already baked them before to remove the amber and paint the bezels black, but I left anything reflective/chrome completely alone
Old 10-17-2017, 02:44 PM   #12
amiexploited
Member#: 251061
2002 wrx sold
If you are retrofitting the HID projector (the circle glass fisheye looking thing) then the bowl color wont matter. You can paint the shroud for the projector (goes over the fisheye lens) to match the black painted reflector bowl. You leave the HID projector alone and you should be good.
Your turn signals output will be affected, better LED bulbs will help but ultimately will have less output than a chrome reflector.
