Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 02-24-2018, 01:14 AM   #1
blitzinq
Member#: 335825
2003 Subaru WRX
Default VF43, wastegate crack too big?
Hello all,
I am in the process of upgrading my td04 on my baja xt to a VF43. I recently purchased a used one off here, and the seller mentioned it had "typical wastegate crack". This is my first time dealing with any VF series turbo, and I know the 39/43/48 commonly have a "hairline" crack, however this seems to be a bit bigger than a hairline. Does this look safe to run? It appears bigger than almost any documented crack I could find, (most have been removed photos from imageshack or other online galleries). I know most VF series work just fine with the crack, but there has been reports of non-typical cracks causing issues.
I will be running an ewg setup if that means anything.
Should I file for a refund? I don't want to throw this on and have issues with it. The seller claimed it functioned and held boost fine when previously installed, but you never truly know. I have outlined the crack with red to highlight the areas. Pictures to follow:
blitzinq is offline   Reply With Quote
Old 02-24-2018, 04:07 AM   #2
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
It's fine.
mrsaturn7085 is offline   Reply With Quote
Old 02-25-2018, 10:48 PM   #3
blitzinq
Member#: 335825
2003 Subaru WRX
Anyone else have more insight?
Old 02-25-2018, 11:12 PM   #4
91 RS RA
Member#: 457410
1991 Legacy RS RA
You could always get the big one welded.
Does look reasonably typical, a bit bigger than the ones Ive seen though.
91 RS RA is offline   Reply With Quote
Old 02-26-2018, 05:47 AM   #5
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
Another baja turbo owner, I am looking to upgrade mine soon also. But you can buy a new exhaust housing for not too much if you are worried about it.
https://www.ebay.com/itm/Subaru-Impr...9aC~-O&vxp=mtr
bobjr94 is offline   Reply With Quote
Old 02-26-2018, 04:20 PM   #6
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
That's pretty normal. Our VF43 looked about the same and we reinstalled it.
car_freak85 is offline   Reply With Quote
Old 02-26-2018, 05:48 PM   #7
blitzinq
Member#: 335825
2003 Subaru WRX
Awesome, thank you all for the input! Appreciate it. I think I will have it touched up and run it then!
Old 02-26-2018, 06:35 PM   #8
mrsaturn7085
Member#: 375462
WR Blue
Honestly, I think trying to have it repaired is more likely to cause you issues than leaving it alone... just make sure your wastegate still closes when they're done welding on it.
Old 02-27-2018, 12:17 AM   #9
blitzinq
Member#: 335825
2003 Subaru WRX
Im going ewg, so it shouldnt be an issue!
