Welcome to the North American Subaru Impreza Owners Club Sunday February 25, 2018
Mid Atlantic Impreza Club
Old 02-17-2018, 01:22 AM   #4101
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Default What did you really do to your car today? V3.1
Worked on my tune a little bit earlier while it was still warm out. Made some small adjustments to WGDC and a few other tables. The constantly changing weather has me backtracking, but its back to hitting my 20 psi target and holding 20 steadily up top.
Also set things up to get some more progress on my spare engine build this weekend. Gonna finish disassembling a set of ej205 heads, and maybe slap a 2.5 pan and pick up on my spare shortblock.
Originally Posted by carnz-pj-410 View Post
EZ30 with 6MT in a 2nd gen LGT should be a hoot
Originally Posted by Patrick Olsen View Post
That's my hope. Maybe someday I'll actually finish the project and find out!
Harness and ECU are on the way to iWire.
I agree. Sounds fun!
RavensFan7 is offline   Reply With Quote
Old 02-20-2018, 12:57 PM   #4102
Mr. Projekt
Member#: 240189
2018 WRX
does it count if I finally ordered my '18 WRX Limited today?
Mr. Projekt is offline   Reply With Quote
Old 02-22-2018, 06:43 PM   #4103
weenerdog3443
Member#: 395225
Oil change time
weenerdog3443 is offline   Reply With Quote
Old 02-22-2018, 07:56 PM   #4104
tramp
Member#: 459629
2017 WRX base
WR Blue
Fresh air filter.
tramp is offline   Reply With Quote
Old 02-23-2018, 12:41 AM   #4105
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Sexy skid plate^^
Never heard of them - looks like a fairly niche company.
Decided I didn't need these window motor things anymore. Bolted the window holder to secure glass in up position - thinking about how to rivet down lexan and still be able to open the door without critical window flopping at speed.
I have 52lbs more I can lose, not much cash left, and a new angle grinder..
corona672 is offline   Reply With Quote
Old 02-23-2018, 06:52 AM   #4106
weenerdog3443
Member#: 395225
Originally Posted by corona672 View Post
Sexy skid plate^^
Thanks. Tbw I believe, ordered off Amazon for like 150 or something silly cheap
Old Yesterday, 11:37 PM   #4107
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Picked up a used set of 328x28mm Stoptechs for the Legacy, reflecting my newfound optimism that it will someday live again.
- Heli-coil'd one of the mounting holes on one of the Stoptech brackets. Other than those buggered threads, everything appears to be in good shape.
- Did a quick test fit:
(Stoptech vs WRX rotor)
- Got the Impreza towed home after it died suddenly while out running errands. I'm thinking maybe fuel pump or fuel pump relay? I was doing ~60mph when it died. Coasted to a side road and onto the shoulder. Tried to re-start it as I was coasting, no joy. Once I was on the shoulder I tried again and it did run for a couple seconds, but as soon as I tried to get moving it died again. It would crank over just fine, but wouldn't fire. Of course this all transpired as it was getting dark, so I'll do more troubleshooting when I have some daylight to work with.
