Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 02-25-2018, 04:09 PM   #1
TakeFlight138
Member#: 475321
Default Smoking and burnt oil smell coming from turbo area. PLEASE HELP!
Ok so I was out driving around in my 08 wrx one day and i started to notice a burnt oil smell so i said hmmm thats weird so i pulled off and popped the hood and there was a light white smoke coming from around the turbo area. all levels are good no i temp on the gauge and oil is level is full. Funny thing is is that thatwas about a week ago so today i decided to warm it back up and see if the problem continued sure enough i started to smell the oil smell and see slight smoke as it warmed up. Pulled off again right as the temp hit when its warm and i notced the smoke was about the same so i drove back home and popped the hood and the smoke appeared to have died off a little bit... really weird wondering what i should do.
TakeFlight138 is offline   Reply With Quote
Old 02-25-2018, 04:42 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Look for oil leaks?
Could be a feed fitting into or out of the turbo, could be a hose leak, could be leaking from somewhere close and spraying onto the turbo.
WHen the turbo is cool, look for stains on the turbo, it may give an idea on where it's leaking.
Old 02-25-2018, 07:53 PM   #3
Tc51
Member#: 451515
2017 WRX & 2003 WRX
CWP
Valve cover gaskets gone bad? I get a little smoke and the smell of burnt oil. I know my gaskets are on the way out had some oil on a spark plug when I changed them out a few months ago. Might be worth checking.
Tc51 is offline   Reply With Quote
Old 02-25-2018, 10:07 PM   #4
C0rt3x
Member#: 357632
2014 WRX Hatch
I had the passenger axle boot wear out and leak on my 04. It caused a spectacular amount of smoke because it was spewing onto the exhaust. Valve cover gasket and turbo connections are the obvious ones I would check first.
C0rt3x is offline   Reply With Quote
