Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 06-20-2018, 08:02 PM   #1
whitrzac
Member#: 229105
Default FB vs EJ transmissions?
I'm looking at using a transmission out of a newer FB engined car in my baja.
FD ratio is the same, both are push clutch, etc. I want the gear ratios of the newer trans.
The cases look like the same casting, but the FB for sure doesn't have the speed sensor hole drilled out, are there any other differences between them?
There doesn't seem to be a lot of information out there on the differences...
whitrzac is online now   Reply With Quote
Old 06-20-2018, 08:34 PM   #2
whitrzac
Member#: 229105
Comparing PNs a bit...
What changed from the 1997-2011 clutch to the 2012-2018 clutch?
The disc and pressure plate are different PNs, but I can't find any info on what changed.
Old 07-11-2018, 04:16 AM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
I think you need to go to a shop that has one and find out the actual length of the trans, Im assuming that you want the 6 speed instead of your 5 in there. I would assume that it would bolt to the engine fine, but its the other little stuff that might be little off. just a little FYI there is a legacy out there that came with a 6 speed that was a clamshell design as well. you can find it on rallispecs trans page
subaru_gc8 is offline   Reply With Quote
