Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 07-14-2018, 10:46 PM   #1
mrgf8sti
Member#: 410300
Default jdm 4.44 r160 help
hey guys, I have a ver4 impreza wagon STi with the r160 rear diff.
From searching on this site and other subaru sites its a 4.44 Viscous (4kgf) Open.
Some threads state that any usdm r160 axle seal is the same as the seal in my jdm rear diff. What i dont know is if its a 93-2001 r160, or a 02 wrx+ r160, unless they are the same as well?
Also when changing the axle seal, do I need to remove the plate in order to replace the seal? Or I just use a small pick and carefully pry it out, and use a mallet to put it back?
mrgf8sti is offline   Reply With Quote
Old 07-14-2018, 11:11 PM   #2
Jackntu
Member#: 487444
First
Jackntu is offline   Reply With Quote
Old 07-16-2018, 11:27 AM   #3
mrgf8sti
Member#: 410300
Ok thanks....
I found 2 different pairs of part numbers with different size.
806732210/806732220 (32x50x11) and 806732200 (32x52x11) not sure which one to get.
Is there anything else I can change since I'm changing the seal?
Old 07-23-2018, 03:50 PM   #4
mrgf8sti
Member#: 410300
Originally Posted by mrgf8sti View Post
Ok thanks....
Bump, anyone can chime in?
Not sure which one is the correct one.
