Welcome to the North American Subaru Impreza Owners Club Sunday June 24, 2018
Old 02-19-2002, 06:19 PM   #1
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
Question ludespeed stage 3: when is it spooled up
I am running the stage 3 at only 4 psi right now, but itsnt at max boost until 4000 rpm. im pretty sure that is way late. any one with this or a similar kit have any info for comparison?
tydon is offline   Reply With Quote
Old 02-20-2002, 01:16 AM   #2
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
What is your turbo trim? The bigger the turbo, the longer it takes to spool.
Marcin is offline   Reply With Quote
Old 02-20-2002, 02:08 AM   #3
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I'm running about 5.5psi on my stage three and it spools up almost instantly!!! Did you get the ball bearing turbo? Is you blow off valve bleeding off the boost........
LVSUBARU is offline   Reply With Quote
Old 02-20-2002, 10:31 AM   #4
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
ive got the t3/to4b turbo. the ludespeed site says that it should be spooled by 3000 rpm, and it mentioned running 9psi just before that.i would think that 4psi should be reached by about 2500rpm
it seems like i may have a small exhaust leak, so maybe that is the culprit. ill get that taken care of this weekend and see from there, unless anyone has any other suggestions.
i think the bov is ok. it was when the kit was installed, but maybe it has been broken in, and needs more adjustment.
thanks for the help
Old 02-21-2002, 01:48 AM   #5
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
The exhaust leak will effect lag time. Do you know what spring is in your wastegate? I had a weaker spring to start with, and when I turned my boost up and switched to a heavier spring I noticed a difference with the spool time. Did you call Tom and ask him? He's a great guy to deal with. I'm sure he'll what to help you out!
Old 02-21-2002, 08:33 AM   #6
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
but remember lag can be caused by both the exhaust track and the intake track... check your intake.. small pipes?
HOK is offline   Reply With Quote
Cobb Stage 3: Where is it? disque71 General Community 12 10-12-2004 02:02 AM
When is it going to rain? remarcable South East Region Forum 8 05-14-2001 06:03 PM
when is it too late to pre-order? whiteWRX WRX Forum Archive 5 02-11-2001 10:42 AM
When is it too late to add a turbo? Scooby-Z Normally Aspirated Powertrain 7 01-21-2001 12:40 AM
Autox at Carlisle? When is it? Dobes General Forum Archive 0 05-20-2000 12:15 AM
