Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 05-26-2002, 03:39 AM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default pe1820 spool up
if the power enterprise 1820 is ball bearing, then why does it still take till 4000 rpm for full boost.
STEALTH-WRX is offline   Reply With Quote
Old 05-26-2002, 09:31 AM   #2
Jan Shim
Member#: 6366
1998 WRX Wagon (Ret)
IHI VF turbos found in STi's are ball bearing too (except VF3x), why DO THEY also take till 4000 rpm to full boost ? Ball bearings alone have little impact on what RPM peak boost is achieved. Gas flow efficiencies, back pressure, size of turbine wheel, size of exhaust housing (P18, P20, P25) are all factors that directly affect boost characteristics. The smaller P18 housing as found in the PE1818 allows for quicker spool than the bigger P20 found in the PE1820.
Dare to even speculate how bad a lag the monster 650ps Apexi turbo with a P25 exhaust housing is going to perform ?
Jan Shim is offline   Reply With Quote
Old 05-26-2002, 01:04 PM   #3
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Life starts at 4,000 - - with 6 speeds - i never find myslef below 4,000 - - I just want more power above 4,000
alfriedesq is offline   Reply With Quote
Old 05-26-2002, 01:14 PM   #4
gossamer_monster
Member#: 3574
Blase' Yellow----R.I.P.
Jan I thought the VF34 was the ball bearing twin of the VF30?
*edit spelling*
Bill
gossamer_monster is offline   Reply With Quote
Old 05-26-2002, 08:45 PM   #5
Jan Shim
Member#: 6366
*edit spelling*
Bill
Perhaps it is, I wouldnt know as I hardly pay attention to factory fitted turbos these days (yawn!). Interestingly, the new Legacy B4 Twin Turbo I saw last week came fitted with twin VF33. Man, what a nightmare it must be if something goes wrong with that engine! Two VF33 hooked to one small intercooler - my god! disaster waiting to happen.
want quicker spool up w/o aftermarket up/dp or ems djmic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 09-06-2005 03:59 PM
How should the WRX spool up bingo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-04-2002 12:00 AM
PE1820 spool up - Injen Intake is superior 15 extra hp! Intake test alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 54 01-01-2002 05:47 PM
Turbo spool up sound...normal? IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-01-2001 01:55 AM
Turbo Spool Up Noise ninetalesnwf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-18-2001 05:27 PM
