Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 02-21-2005, 09:32 PM   #1
WRC-Go
Member#: 29917
2017 WRX
Default Little help - need 50 HP and quicker spool-up
I love my little WRX wagon, but I'm beginning to think about a little more oomph... Warranty goes out in six thou, I'm ready to do some mods. So far, all I've done is catback exhaust (Stromung), and handling mods. I've read the FAQs about turbos, but my eyes are crossing and glazing over with all the terminology and nomenclature. What would you recommend for an easy 50 HP? I think that's enough to brighten up this daily driver. If go with a P&P stock turbo, I'll get quicker spoolup but can I get the 50? Stock unit doesn't really come on until 3500. Does P&P help that much?
If I upsize the turbo, what else do I need to do? (Assume injectors and tuning of course, maybe additional plumbing work?) Really looking for a simple and easy solution. If I can get more HP (75 or 100) I'll not look that gift horse in the mouth either.
Any tips and info appreciated.
Thanks!
WRC-Go is offline   Reply With Quote
Old 02-21-2005, 09:33 PM   #2
jmanny152
Member#: 81573
2k5 Dubba U R X
cobb stage 2
BAM!
jmanny152 is offline   Reply With Quote
Old 02-21-2005, 09:35 PM   #3
jmanny152
Member#: 81573
2k5 Dubba U R X
cobb stage 2= accessport+downpipe (you already have the catback)
that will put you at 285 hp
if you want more get a VF34 turbo (that would make it cobb stage 2.5) then you would be at 320 hp
Old 02-21-2005, 09:37 PM   #4
hondaeater69
Member#: 60324
1998 RS
an upgraded turbo will get you 100+ hp, and cost anywhere from 2-4K and up. Cobb stage 1 is good for 20-30 HP, I would start there, you'll notice a good difference, and all you need is a DP for stage 2
and you WILL get stage 2.
Old 02-21-2005, 09:52 PM   #5
Timdog1650
Member#: 45516
MY04 STi
anything in the "Stage 2" category will work....Cobb, TurboXS. Basically, ditch a cat or two, get some engine management. The problem with a P&P is that it's not the most "noticeable" mod as far as performance goes, and requires having your turbo off to get sent out, which can be up to a week or two lag time.
Timdog1650 is offline   Reply With Quote
Old 02-21-2005, 09:59 PM   #6
omahasubaru
Member#: 1594
1999 2.5 RS
2002 Legacy
I'd start with the Cobb Accessport and run Stage 1, if that isn't enough, you can always upgrade to a stage 2.
You should really look into an up-pipe whether for stage 1 or 2 actually.
omahasubaru is offline   Reply With Quote
Old 02-21-2005, 09:59 PM   #7
WRC-Go
Member#: 29917
2017 WRX
Thanks, any good links to the Cobb stuff? Sounds like uppipe and downpipe plus access port and tuning... Think it will match up OK with the Stromung?
Appreciate all the responses.
Old 02-21-2005, 10:04 PM   #8
Timdog1650
Member#: 45516
MY04 STi
www.cobbtuning.com
Just need to find a vendor that has Cobb stuff in stock. It'll match up to pretty much any exhaust setup, make sure you ditch the up-pipe and get one without a cat.
Old 02-21-2005, 10:17 PM   #9
WRC-Go
Member#: 29917
2017 WRX
Thanks, guys!!
Old 02-21-2005, 10:28 PM   #10
goofywrx
Member#: 79078
2004 WRX
uppipe will help with spoolup too.
goofywrx is offline   Reply With Quote
Old 02-21-2005, 10:36 PM   #11
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
A word of advice would be to buy used parts or go all out on the upgrades. You will get bored with what ever you do as far as upgrades. You are already displaying the classic sympoms of someone who can't leave well enough alone. Buying used helps ease the pain.
Trust me I know. I am currently on my third turbo and the fourth is on it's way via FedEx.
Get the walbro fuel pump and some injectors that are at least 650cc. That will work for several turbo upgrades.
LiquidForce is offline   Reply With Quote
Old 02-21-2005, 10:43 PM   #12
WRC-Go
Member#: 29917
2017 WRX
Thanks, I'm thinking I'll be OK with around 280 hp for now, but you never know... This car is really my daily driver, but it would be really neat to have like 350 hp in it....
Appreciate all the good advice.
Old 02-21-2005, 10:57 PM   #13
speedemon9
Member#: 72279
2006 2006 STi
turboXS utec
downpipe and uppipe
vf34 turbo, injectors and a fuelpump
speedemon9 is offline   Reply With Quote
Old 02-21-2005, 10:58 PM   #14
PinnacleChronos
Member#: 64041
what type of average 1/4 miles are ppl running with a cobb stage2?
PinnacleChronos is offline   Reply With Quote
Old 02-21-2005, 11:00 PM   #15
jmanny152
Member#: 81573
2k5 Dubba U R X
i dont know where figures coming from. but i can get a vf34 with sti pinks and pump for 1200 installed.
Old 02-21-2005, 11:02 PM   #16
jmanny152
Member#: 81573
2k5 Dubba U R X
13.6 is what cobb says. 13.9 with stage 1
Old 02-21-2005, 11:06 PM   #17
sergeant launch
Member#: 81304
'03 WRX
aspen white
i have the vf-34 turbo, STi injectors and walbro 255 lph fuel pump on the way...but i can say that COBB stage 2 package is really frekken tight man...i stayed up with an STi on 106 octane, and he NEVER PULLED!
thats just me,
im outee,
nick
sergeant launch is offline   Reply With Quote
Old 02-21-2005, 11:55 PM   #18
ashumo
Member#: 51318
89 SVX Syncro
pass on cobb and their stage kits...get ecutek and build your own kit.
ashumo is offline   Reply With Quote
Old 02-22-2005, 12:38 AM   #19
Phil Jr.
Member#: 62221
Buy a cobb catted DP, used STi uppipe, AccessPort, and I/C hoses. You will have 285 HP and full spool under 3500rpm.
I just noticed you have a Viper so def get the Cobb catted DP, it is work the cash man. You wont be losing any power with the one hi-flow cat, COBB has stated this.
Phil Jr. is offline   Reply With Quote
Old 02-22-2005, 12:45 AM   #20
veightkiller
Member#: 78967
2011 335i
what's the website for COBB????
veightkiller is offline   Reply With Quote
Old 02-22-2005, 12:57 AM   #21
Phil Jr.
Member#: 62221
Old 02-22-2005, 01:11 AM   #22
veightkiller
Member#: 78967
2011 335i
^^^ thank's
Old 02-22-2005, 01:30 AM   #23
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
i picked up an ION turbo stage 1. lighter internals and bigger internal wheels. this may be your ticket. I have not put it on though since i stilll need EM, injectors, and an upipe.
Good luck though. Oh and thumbs up on cobb products, as i am looking into their tuner and upipe to finish my set up (plus modded injectors).
scoobdude is offline   Reply With Quote
Old 02-22-2005, 02:59 AM   #24
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
For +50 hp from stock and QUICKER spoolup, do not TOUCH that turbo. What you're asking for is a Classic Stage 2.
Up pipe. Turbo back (down pipe at least). Finally, engine management.
http://www.pdxtuning.com/images/dyno...Stage2-wrx.gif
Oh, here's a link to a Stage 4 (VF34 + Supporting Mods) on the same dyno. Decide for yourself if the trade offs are worth it
http://www.pdxtuning.com/images/dyno...Stage4-wrx.gif
fogdor is offline   Reply With Quote
Old 02-22-2005, 04:24 PM   #25
Phil Jr.
Member#: 62221
Hmmm besides the extra power from stage 2, the other thing I realized is how small the td04 really is. This turbo was picked pretty much as the smallest possible turbo to get 227hp stock. With stage 2 power REALLY drops off to nothing after 6000rpm. The td04 just runs out of breath.
want quicker spool up w/o aftermarket up/dp or ems djmic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 09-06-2005 03:59 PM
a little help needed on port and polishing Lordhowe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-19-2005 04:35 PM
Bigger I/C in WRX, increased lag and later spool up? JIM THEO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-26-2005 03:01 PM
Just a little help needed...... WRX_02_227 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-28-2001 09:05 PM
Scooby mechanics: little help needed taking apart my jspec Rex front clip... annointed Tri-State Area Forum 32 11-19-2001 08:46 PM
