Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 09-10-2002, 11:57 PM   #1
Gman094
Member#: 14092
2005 Legacy GT
w blue
Default TXS Stage 2 in 1/4 mile?
what kind of results are you getting with the stage 2 for TXS? Im thinking about getting it really soon and am eager to see the results. this punk has been talkin **** about how his father's cl600 is soo much faster then everything and it only runs a 14.2 in the quarter.
Gman094 is offline   Reply With Quote
Old 09-11-2002, 02:51 AM   #2
MINO
Member#: 12841
My experience with a TXS stg2, up pipe, pulley, colder plugs, 100 octane (full tank- i totally zoned out at the pump thinking I was filling up for the week), 14 psi, 230 lb driver and 2700 ft above sea level at LACR:
13.6 @ 94 mph. (mph too low for ET so I doubt it's validity)
the following run:
So, I'd say yeah, you can beat him...most likely from a stop.
MINO is offline   Reply With Quote
Old 09-11-2002, 09:29 AM   #3
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
Default Re: TXS Stage 2 in 1/4 mile?
My best 1/4 mile with the stage 2 setup was 13.33 @ 100mph. An important thing is use Turboxs high performance manual boost controller ($129) with the stage 2 setup. You will get much better peformance using the hpmbc vs the abc bleeder valve that comes with the kit.
SGOSWRX is offline   Reply With Quote
Old 09-11-2002, 09:52 PM   #4
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Space Gray with Coral Red
the following run:
Why and how are you running stock boost with a stage 2??
I'm also a bit confused why you say "13.6" when the slip shows "13.97"...so 14.
ezatnova is offline   Reply With Quote
Old 09-12-2002, 03:03 AM   #5
MINO
Member#: 12841
Sorry, should've been more clear.
I was too lazy to look for the 13.6 slip and scan it. Especially because I think it's incorrect. Look at the numbers and compare it to the 13.9. They just don't look right.
I had the ABC completely opened and that was all the boost it could squeeze at that elevation and temperature. I spoke to Mark at TXS about the low boost and was told it was normal.
Old 09-12-2002, 09:23 AM   #6
is2scooby
Member#: 19851
02 WRX
Aspen White/[email protected]
Holy smokes! You ran a 13.6 with a 2.1 60'?!? Wow! Imagine what that thing would do with a trans-smashing launch! Yeeeehaaaa!
is2scooby is offline   Reply With Quote
Old 09-13-2002, 07:54 AM   #7
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
Yeap. And as soon as you cut down on that reaction time, you'll be in the low 13" !!!
Ti-REX is offline   Reply With Quote
Old 09-14-2002, 11:43 AM   #8
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
what does reaction time have to do w/ ETs?
HS WRB-rex is offline   Reply With Quote
Old 09-14-2002, 11:43 AM   #9
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
Old 09-14-2002, 12:12 PM   #10
is2scooby
Member#: 19851
02 WRX
I'm thinking/hoping that the meant he was being facetious. :-)
Old 09-14-2002, 05:58 PM   #11
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Talking
heck, just leave on the first yellow and you'll be in the 11's.
Old 09-17-2002, 02:31 PM   #12
metoo
Member#: 4764
2004 STi sold :(
forizzle
First yellow,
Last yellow,
or 5 seconds after the green.....
your trap time and speed won't be affected.
For those in confusion, 60' and reaction time are 2 different things. 60' let's you know how well you got off the line. Reation time is how quckly you broke the lights after the green.
metoo is offline   Reply With Quote
Old 09-17-2002, 02:35 PM   #13
nmyeti
Member#: 4980
I've driven 2 different stage 2 cars.
In Mark's wagon i managed a [email protected], and in my sedan i went [email protected]
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 09-17-2002, 04:47 PM   #14
BluSuby
Member#: 12154
04 Sti
99 Outback
This past weekend I consistantly ran low 14's with a TXS stage 2(with a CAT), uppipe and MBC set at 16 psi. I pulled a 13.9 at 94 also. I know my car is faster than that though. It was my very first time ever drag racing, I was running with an Off the shelf map with my unichip, it was hot outside, and I probably didn't let my car cool down enough at times. I was having too much fun to wait
Bryan
BluSuby is offline   Reply With Quote
Old 09-18-2002, 04:21 PM   #15
ezatnova
Member#: 10877
2007 BMW 335 Coupe
-Nathan
www.turboxs.com
Nathan,
Were these with the ABC that comes with the stage 2 kit, or did you fool with an MBC. I think we'd be interested in hearing ABC times since it's the way the kit comes and is the safe way to run a daily driver. I suppose since you're there at TXS the unichip was tinkered with a bit to get more HP?
Old 09-18-2002, 04:31 PM   #16
nmyeti
Member#: 4980
Nathan,
I used an MBC on both of those runs. The programs were totally stock off the shelf maps, as the 13.2 run was before i even worked here.
-Nathan
Old 09-18-2002, 06:24 PM   #17
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
With just a Turbo XS Hp MBC and a drop in air filter i ran 13.5 @ 97mph
Thats a nice car he is talking about, but from a stop you should be able to get him easily.
I DO NOT reccomend trying your luck on the highway tho.
~v6
V6TurboTA is offline   Reply With Quote
Stage 2 WRX 1/4 mile time ftnjun2x Proven Power Bragging 33 03-16-2014 10:07 PM
05 stage 2 lgt 1/4 mile times AWDxBOOST Legacy Forum 11 11-04-2005 07:56 PM
Car is slow for stage 2 in 1/4 mile vortectoy Proven Power Bragging 20 09-04-2005 02:29 AM
MY 02 Red WRX TXS Stage 2+ In PA beefyib123 Private Vehicle 'For Sale' Classifieds 0 12-02-2004 10:13 AM
What are Stage II average 1/4 mile times? mightbewrx Proven Power Bragging 2 04-24-2003 02:00 PM
