08-15-2002, 07:57 PM | #1 |
Member#: 6072
SCIC
Vehicle:01 Silver 2.5 RS 04 Silver WRX STi |
pulley torque spec
What is the torque spec for the crank pulley on my 2001 Subaru Impreza RS?
While we are at it, if you have a kind heart, would you please post the torque specs for the other two pulleys, so that others can find this information all in one place when they search? Thanks. Chieh
08-16-2002, 02:03 PM | #2 |
Member#: 4423
Vehicle:'04 08 Tribeca, SVX Gold, Maroon |
2.5L Crankshaft Pulley Torque:
Apply engine oil to bolt seat and threads Tighten to 33 ft-lb, then further tighten to 130 ft-lb ensuring that the angle of the bolt changes 65deg or more (referring to the gauge on the timing cover). This is to ensure the bolt has not stretched or the hole is not blocked. P/S Pump Pulley Torque : 38ft-lb Alternator Pulley Torque : 47ft-lb |
08-26-2002, 01:10 PM | #3 |
Member#: 6072
SCIC
Alternator Housing/Idler Pulley Torque Specs | TaurusMcRae007 | Service & Maintenance | 2 | 05-12-2009 12:02 PM |
Crank pulley torque spec. | NRTmotorsports | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 04-21-2005 03:29 AM |
Vishnu main power & alternator pulley torque specs | FreeBSD_WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 02-19-2003 05:57 PM |
Pulley Torque Specs | DDMan | Normally Aspirated Powertrain | 5 | 06-09-2002 01:37 AM |
Another pulley torque spec question. | Corn-Picker | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-08-2001 09:08 PM |
