Welcome to the North American Subaru Impreza Owners Club Thursday January 24, 2019
Old 07-16-2018, 10:53 PM   #1
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
Default 2013 WRX 578hp Flexfuel Holset HX40 (Pics, Video, and Dynosheet inside)
Car: 2013 Subaru WRX
Facility: PSIPROFORMANCE
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: 220-230whp/wtq
Boost: 21psi on 93oc/ 27psi on E-85
Fuel: 93oc/e-85 Flexfuel
Target AFR: 11:5
Ambient Temperature: 95 degrees
Peak HP at RPM: 447hp on 93oc and 578hp on e-85
Peak Torque at RPM: 385trq on 93oc and 485trq on e-85
Engine mods:
Semi closed deck case halves
King main and rod bearings
Brian Crower sportsman rods with ARP2000 rodbolts
Nitrate coated crank
Manley Turbo Tuff 2618 Pistons Stock compression
Factory D25 heads with stock valves and no porting
Brian Crower 280 cams, titanium valve springs and retainers
ARP 625 Headstuds
Cosworth headgaskets
2.5i long runner big plenum intake with TGV delete and no portwork
Air pump delete
Aeromotive A1000 regulator
-8 Feed/-6 return lines
ID2000 injectors
IAG fuel rails
Radium surge tank with dual 044 bosch pumps and a 255lph intank.
BNM Equal length header
BNM Rotated kit
Turbo XS GT Series
Tial 38mm EWG
Holset HX40 with Bullseye Billet drop in wheel and .70AR T3 vband housing
Grimmspeed 3port EBCS
4bar MAP sensor
AMS front mount kit
Tial Q BOV
IAG Street Series Air Oil seperator
Speed Density tuned
Cobb Flexfuel and fuel pressure setup
KillerB baffle, pick up, and oilpan.
KoyoRad Aluminum radiator
Mishimoto radiator hoses
Denso IKH24 plugs (2 step colder)
Tuned on a Cobb V3
Driveline:
05 STI 6speed swapped with R180
DSS Carbon Fiber driveshaft
Stock 6spd flywheel
ACT 6puck Extreme single disc
MAPDCCD Controller
Perrin Solid motor mounts
Perrin Solid Trans mount
Perrin Reverse lock out
Suspension:
ISC Race Coilovers
Whiteline front and rear swaybars
Whiteline Adjustable endlinks
Cusco Rear adjustable control arms
Whiteline rear diff positive power bushings
Kartboy front and rear shifter bushings
Enkei RPF1 17x9 +45 wheels and 275/40/17 Nitto NTo5R Drag Radials
Ghostlystang is offline   Reply With Quote
Old 07-17-2018, 12:02 AM   #2
albersondh
Member#: 196882
08 WRX
Very nice! Crap, I only did 420whp at 22PSI on a HE351CW.... I don't see that extra 5PSI giving me an extra 158whp. That BEP drop in wheel and hot side are doing work!
albersondh is offline   Reply With Quote
Old 07-17-2018, 12:06 AM   #3
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
I was very impressed also for a junkyard turbo that I cleaned up lol. We could have pushed the car more but did not want to chance anything with the ARP2000 rodbolts and semiclosed deck. The 93oc and e85 was done at 17deg base timing also. I was tempted to just tell him to keep making power but the adult in me told me to chill and just drive the car and have fun. Im extremely happy that it made those numbers on 27psi also.
Old 07-17-2018, 11:35 PM   #4
albersondh
Member#: 196882
08 WRX
Great setup... Did they fab that up-pipe in frame? Wonder if they made a jig? I spent days getting the 351 to fit and Im still not in love with it.
What are you doing for an oil drain back? I fought with crappy hose forever, now I tap the head, and weld up CSST with fittings. Working around the angles between the CHRA and compressor/turbine have been challenging.
Old 07-18-2018, 12:07 PM   #5
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
It was fabbed up on a jig. Evan Carpenter started making rotated kits and headers a couple years ago when he was just starting off with fabbing through a group on facebook. He has since went professional and this is the website to check some of his work out. http://www.bnmperformancefab.com/. His work is top notch. I believe he uses full front clips of cars for fabbing also. Its also schedule 10 stainless.
It has a -10an drain off the bottom the turbo to a quick connect into the factory drain.
Old 07-22-2018, 05:24 PM   #6
wildt267
Member#: 161812
06 Wrx STi
CGM
By any chance did you do any testing with the factory wheel? I ask because I have a 7blade hx40 wheel on an hx35 and Iím trying to determine if it under performs at lower boost because because I have some hidden problem or just because the wheel wonít flow. I plotted it in the compressor map and where Iím running it it doesnít look at bad. Just left of the main efficiency island.
wildt267 is offline   Reply With Quote
Old 07-22-2018, 06:27 PM   #7
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
Originally Posted by wildt267 View Post
By any chance did you do any testing with the factory wheel? I ask because I have a 7blade hx40 wheel on an hx35 and I’m trying to determine if it under performs at lower boost because because I have some hidden problem or just because the wheel won’t flow. I plotted it in the compressor map and where I’m running it it doesn’t look at bad. Just left of the main efficiency island.
No sorry. I made the jump due to the results I saw on my fathers 7.3 powerstroke with a BEP drop in wheel. I know thats comparing apples to oranges but I figured it couldn't hurt. I know some DSM guys actually see less target boost with a drop in wheel but substantially lower EGTs. There is not a lot of information out there for holset subarus so I was rolling the dice for results. BEP advertises 10lb/min increase in flow over the stock wheel.
Wicked Wheel2 is another option for an impeller wheel drop in. I have heard good opinions on that one as well in the diesel world.
What hot side are your running? Have you smoke tested your system for boost leaks?
Old 07-25-2018, 10:45 PM   #8
wildt267
Member#: 161812
06 Wrx STi
CGM
Have been considering the wicked wheel 2. Substantially lighter than my cast wheel. Been talking to diesel people and no one seems to have any good data on an hx 40.
Did leak test. Injector 4 leaked at 30psi of air pressure. Got a second set of orings in there as per Iagís advice as I have their rails. Couldnít get them to deal with second oring. Called id, they said they should leak unless I have fuel pressure behind the injector. Took out second o ring. I got a custom t3 in, vband out .63 hotside that I swaintechíd. That bep wheel is interesting but thatís some $$$ for a wheel. Iíve seen where an improved setup will run less boost but equal or more power. Boost can be considered a measure of restriction. Kinda thing that sets my brain on fire.
Old 09-03-2018, 05:20 PM   #9
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
Is the .63 a Tims housing? My buddy is going to be using that on a hx40 on a 2.35L.
I got the BEP on black Friday sale. Just to put it in perspective...
I bought 2 used HX40s from a caterpillar dealership used for $125. I then kept the better one and sold the other for $100 to a buddy. I then bought a rebuild kit for $20 and rebuilt it on a bench. The stainless BEP exhaust housing was $375 and the BEP impeller wheel was $350. IMO its not too shabby for a $770 fresh legit Holset. This turbo has surpassed what I thought it would make and I cant wait to actually push it. The temps are dropping around here and I will soon have some dragstrip data to back this combination up.
Old 09-08-2018, 02:20 PM   #10
wildt267
Member#: 161812
06 Wrx STi
CGM
Yup, itís one of Timís. Itís built tighter than any other journal bearing turbo Iíve felt. I have a good feeling about itís durability thatís for sure. I paid a little over $700, just not sure if I wanna out another $700 into it. Iím currently having my motor built with some bigger cams so Iíll see how well the turbo performs when it can breathe. I told my builder I wanted to step down into something smaller but he insisted I stay with it and see what it can do.
Old 09-09-2018, 08:19 PM   #11
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
Yup, it’s one of Tim’s. It’s built tighter than any other journal bearing turbo I’ve felt. I have a good feeling about it’s durability that’s for sure. I paid a little over $700, just not sure if I wanna out another $700 into it. I’m currently having my motor built with some bigger cams so I’ll see how well the turbo performs when it can breathe. I told my builder I wanted to step down into something smaller but he insisted I stay with it and see what it can do.
Have the heads ported while you are there. I didn't and regret it now that its all together. I would run the .63 housing since you have it already and would get one of the wicked wheels to save some cash.
Old 09-09-2018, 10:51 PM   #12
wildt267
Member#: 161812
06 Wrx STi
CGM
Heads are getting done too. I was considering the wicked wheel because like you said it is a good chunk cheaper than the batmo, and seems significantly lighter than stock. Still havenít found any real world info on how the hx40 wicked wheel flows. Thank you for the advice, Iíll give it a second look
Old 09-12-2018, 05:37 AM   #13
rexblake
Member#: 178426
2010 S4
Gray
That’s some impressive power, very nice.
Old 09-14-2018, 03:35 PM   #14
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
Originally Posted by rexblake View Post
Thatís some impressive power, very nice.
Thanks!
Old 09-17-2018, 07:41 PM   #15
Jaceracer
Member#: 440615
2013 WRX
Wow that is a lot of work done in 5 years. My 2013 is getting tuned for ~350whp today. This build makes that seem like nothing lol
Jaceracer is offline   Reply With Quote
Old 09-18-2018, 12:19 AM   #16
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
Yes.. definitely a lot. A lot of blood, sweat, and tears from me and 2 buddies in this car. The car sat for 3 years while I built everything and acquired parts. The body only has 26k miles on it right now.
Old 10-22-2018, 09:29 PM   #17
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
So I was able to get some shakedown runs of the setup on sunday at the Mitsubishi vs Subaru event at Cecil County Dragway. This is my first time on a pro tree for the heads up class I was in. I will get the pictures of the timesheets and video added in a couple days.
1st pass of the trailer:
1.8 60ft and went 11.2 at 127mph. LC set at 5800. I was trying to ready myself for the pro tree light and was only able to get on the 2 step for a fraction of a second. Once back in the pits I found that the car needs like 3-4 seconds to get 10-12psi from LC. I also found a boost leak at the compressor housing and fixed it.
2nd pass:
1.5 60ft and then I missed 3rd and 4th.... still went 12.8. I raised the LC to 6800rpms on this pass and the car reaallllllyyyy liked this out of the hole.
3rd pass: (first round eliminations)
1.6 60ft and went 11.2 at 120mph. LC was still set at 6800rpms. I blew a charge pipe off in 4th gear hence the lower trap speed. This pass the car was an animal and could have been my 10 second pass if it didn't blow a coupling off. I still ended up winning this heads up pass.
Cecil eventually just shut the event down due to time and the purse was split between all first round winners.
Old 11-20-2018, 12:13 AM   #18
Ghostlystang
Member#: 338515
2013 HX40 Flexfuel
578hp/485trq
Cant wait to get through the winter weather and try again.
Old 11-26-2018, 12:39 PM   #19
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Yeah, get that 60' down and get yourself securely into the 10's.
