Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 07-17-2018, 11:18 AM   #2501
1qukSti07
Member#: 326585
2007 STi
I've had the EFR7163 for a little over a year and have had put 14k miles on it. I have not noticed any leaking of oil around the turbo at all. I have not added anything special for the oil feed or return. I occasionally get some smoke on start up, I just attributed it to a bit of oil getting past the rings as a result of the flat motor. Maybe that smoke is from excessive oil supply? But its not consistent, happens 1 of 10 start-ups.
A little more info about the motor:
Built block (Darton sleeves, Manley pistons and rods)
Rotated EFR7163
Botti tuned @28psi on E
FMIC with rotated intake mani, (had a Spearco TMIC before and the heatsoak was too much)
Old set-up:
Current set-up:
Aside from the smoke I couldn't be happier with this turbo! Spool and transient response is amazing for the power it makes. Its a little big for the smaller AutoX courses but I stick to the bigger events. I'll do some pulls tonight and post the VD, but the car is easily in the 500s. We had planned on getting to the strip this week but the local track is closed till August for resurfacing
1qukSti07 is offline   Reply With Quote
Old 07-17-2018, 11:53 AM   #2502
Waddlz
Member#: 395275
2012 STi
I really wanted to keep TMIC with my 7163, seeing that im in a cooler climate than you in Florida. but Im super happy with the response with ETS FMIC.
Waddlz is offline   Reply With Quote
Old 07-17-2018, 11:56 AM   #2503
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
My car puffs smoke at start-up every once and awhile. It'll got 20+ starts, then sometimes it'll be every few starts. It has done it since I put in forged pistons (Manley Graded drop-ins are too loose), even with my 20G.
yamahaSHO is offline   Reply With Quote
Old 07-17-2018, 12:56 PM   #2504
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
How does you IAT sensor perform there? I have mine in the manifold opposite the TB but will be moving it to right before the TB where you have it. I wanna trend the difference in readings due to manifold heat soak. My location sucks.
Rotated EFR7163
Old set-up:
Current set-up:
Old 07-17-2018, 07:40 PM   #2505
PDXREALTOR
Member#: 468393
2017 STI
Originally Posted by yamahaSHO View Post
I purchased the oil return flange from Full-Race last year and hadn't put it in yet. However, I ordered a flanged -10AN fitting from Treadstone last night as the Full-Race setup still seems restrictive/undesirable. I used the Treadstone fitting on my 7064 on my S2000 and haven't noticed anything of issue yet.
I'll start with that, clean up the turbo and see if it continues to leak.
I'm assuming you got this flanged setup from FR? If so, I used it and it a side from a very minor kink it seemed to fit perfect.
PDXREALTOR is offline   Reply With Quote
Old 07-17-2018, 07:47 PM   #2506
1qukSti07
Member#: 326585
2007 STi
Even in the cooler months the TMIC struggled to keep up. I would see 145 temps on highway pulls. When dynoed the car last year with the topmount, I saw IATs of 175! It was July and the shop had a terrible fan set up, and the ambient temp was 95ish. I was still able to make 455wph, even with a ridiculous amount of timing being pulled.
Going to FMIC was a night and day difference. It picked up a lot of power, and heat soak isn't even close to an issue now. I have noticed no difference in spool either.
Old 07-17-2018, 07:53 PM   #2507
1qukSti07
Member#: 326585
2007 STi
Funny you ask that, on the FMIC set-up, its not ideal. The air that contacts the sensor goes through the 200 degree radiator. This heat soaks the sensor and the charge pipe. So what I did to combat this is use my intercooler sprayer! I have a nozzle on each side of the pipe, it drops to 2-3 degrees above ambient all the time. I might move it to the charge pipe in the bumper, right after the intercooler. But for now the sprayer does an amazing job at cooling it down.
Old 07-18-2018, 03:46 AM   #2508
sergey2007
Member#: 304910
2004 LGT ej207 7163
Alternative air cooling solution (but much more difficult to manufacture).
sergey2007 is offline   Reply With Quote
Old 07-18-2018, 11:59 AM   #2509
Waddlz
Member#: 395275
2012 STi
I am using that setup on mine, didnt buy a Full race kit, and it works fine. Like you said I have a very minor kink but I've noticed no issues with it.
Old 07-18-2018, 12:02 PM   #2510
Waddlz
Member#: 395275
2012 STi
interesting. I wanted to go with maximum spool so i figured a bigger TMIC, ETS, would be sufficient enough on E85.
but once I actually drove the car with the FMIC, i agree. I don't have any noticeable lag compared to my last fail turbo.
Old 07-18-2018, 03:00 PM   #2511
Xtea
Member#: 395734
Im using a legacy/wrx style grimmspeed tmic. For the 6758 it hit 440 on e85 without issue. It will be a couple months before my 7163 goes in, but I plan to keep the tmic.
Xtea is offline   Reply With Quote
Old 07-18-2018, 05:56 PM   #2512
1qukSti07
Member#: 326585
2007 STi
I would suggest going FMIC, if possible. I thought the Spearco TMIC would be able to handle it but it couldn't. Seeing as the top mount sits inches away from a 2000 turbo, it just can't shed the heat efficiently in that hot area.
Old 07-18-2018, 06:16 PM   #2513
Xtea
Member#: 395734
I won't be doing that. The hassle isnt worth the benefits in my mind. My tuner hasnt yet said my tmic is holding me back and the 7163 is only 50hp better then the 6758. The grimmspeed is rated for upto 500hp and thats where I plan to stop.
Old 07-18-2018, 07:15 PM   #2514
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Do you track your car at all?
Old 07-19-2018, 09:41 AM   #2515
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Yes, that's it. I couldn't find the flange in the places I though it could be, so I ordered the flanged -10AN that won't neck down. We'll see how it goes.
Waddlz FMIC setup on his 7163 is a lot more impressive than I thought it would be, especially here at altitude (the graphs I posted earlier were of his car).
I've been happy with the performance of my TMIC, however, I haven't tapped in to log temps. I do understand that it's not only on top of a hot engine, but doesn't get the best airflow either. As I have my car down now, I will be putting a turbo blanket on the hot side and putting a boost pressure switch in series on my intercooler sprayer. Both of those should help, however, when winter comes around, I am planning on getting Inconel shields made for my header and uppipe. Both are already ceramic coated, but I'd like to do better at retaining heat where it belongs.
Old 07-19-2018, 04:41 PM   #2516
PDXREALTOR
Member#: 468393
2017 STI
You can buy those in tons of different configurations. I know Raptor Superchargers out of Austrailia likes to use that type of cooler. I used them a lot in my supercharged jetskis. Water pressure is key - too much and they swell like a balloon.
Old 07-19-2018, 04:50 PM   #2517
Xtea
Member#: 395734
I did some logs of my grimmspeed post intercooler temps and the things works pretty well. I just really don't like the idea of messing with piping all over my engine bay and I don't want to spend more on it. I'm not tracking right now. Maybe in the future i'll do a few auto x events but ill probably never to quarter mile.
Old 07-20-2018, 02:14 AM   #2518
PDXREALTOR
Member#: 468393
2017 STI
Went for a short drive tonight for the first time since install.
1) I have an oil leak already, and it's not at the supply OR drain line from what I can tell.
2) I have the high load actuator and it cracks exactly as the tech sheet says it will 19 psi and change with a 10mm preload. However, the one time I looked up at my boost gauge close to redline it was at 15 PSI. I need to check my log and see for sure. I did have a hose pop off on me so it could have been loose already.
They supplied these clamps that barely fit around the turbo outlet. Took me for-ever to get that bastard on there. I like to buy them on the larger side so they are easy to put on. I mean, is that much more to supply the next size up? Or am I completely missing something.
Those two issues a side and, I can tell this is going to be a blast to drive. Completely different than my FP Green. And, I was only out getting data for the VE table with 3* pulled on wastegate pressure.
Old 07-20-2018, 11:34 AM   #2519
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Get some Murray Clamps
T-37 is offline   Reply With Quote
Old 07-21-2018, 06:07 PM   #2520
subaru_gc8
Member#: 29292
2004 WRX wagon
Originally Posted by T-37 View Post
nascar huh?
subaru_gc8 is offline   Reply With Quote
Old 07-21-2018, 10:33 PM   #2521
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Originally Posted by subaru_gc8 View Post
nascar huh?
Wut
45
Old 07-24-2018, 02:41 AM   #2522
PDXREALTOR
Member#: 468393
2017 STI
For the guys pushing this turbo 28psi + - what size injectors are you running? Pump gas, no E
Old 07-24-2018, 12:03 PM   #2523
PDXREALTOR
Member#: 468393
2017 STI
Originally Posted by eqlized_aero View Post
id1300's.
My id1000's at 60 PSI base are maxed out on e85.
My ID 1050s are at 80+ percent with a 55 base pressure. My pump runs out of juice and throws me lean on spool up.... This is on pump.
Kinda funny to adjust the ve table for more. Fuel and have the result be a mega rich dip at spool onset and a bit less lean spike at pt. In a round about way I just figured out how to manipulate the built in rich dip on spool.
Old 07-24-2018, 12:28 PM   #2524
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
I don't know anyone pushing an EJ past 28 psi on pump gas. That's pretty much race gas territory or E85.
subydude is offline   Reply With Quote
Old 07-24-2018, 12:37 PM   #2525
PDXREALTOR
Member#: 468393
2017 STI
I run a just over 100 octane using Torco and 92 pump. 3oz of Torco for every gallon of fuel.
If anyone wants it I get it for cheap and can pass along the deal.
Still wondering though, if 1050s would do it with the FP back down at base pressure of 43.5.
Sounds like the next jump is 272 cams - and - if that's the case I plan to do so.
