Old 09-11-2005, 01:59 PM   #1
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Default Legacy GT 380whp and 389ft/lbs with STi TMIC
Well most of you have seen my post about my 2005 Legacy GT that has basically been converted so that I can run STi type turbos. We finally got it on the dyno with the FP3065R and I got some numbers that I am proud to post up. Took me about an hour to get it all dialed in with the UTEC, we probably could have gotten more out of it but we ran out of time. I am also not so keen on going too much higher with the stock Version 7 STi TMIC.
Here is the chart:
The lower curve is what it put down on the very first pull at 17psi. The final tune was at 24.5psi of boost. The turbo started to spool up a bit slower after we had it on the dyno for a bit and I wasnt sure if it was due to having too many fans on the car or what. Once we took it for a road tune then I found that I had an exhaust leak at the manifold to uppipe connection. I just replaced that gasket prior to putting it on the dyno, and that was the forth one. Other than that issue, the car is absolutely insane!!!
Pictures and more info can be found here:
http://www.suby-performance.com/ProjectL/ShaggyGT.htm
Engine Mod List:
-STI JDM Version 7 Top Mount Intercooler
-STi JDM Version 7 Intake Manifold
-GodSpeed 650R Spec Kit
-GT35R (FP3065) Rotated Mount (.70AR Compressor Housing, .7x turbine Housing, 65lb wheel)
-GTSpec Modified Exhaust Manifold w/ uppipe (both wrapped)
-Tial 44mm Wastegate V-Band (15psi spring)
-Wastegate Loop Pipe (Dumped Back into Downpipe)
-Catless V-Band Flanged 3” Downpipe
-3.5” Intake w/ MAF Housing (AEM Type Filter)
-Stainless Steel Braided Oil line and Fittings
-Power Enterprise 850cc Injectors (Side Feed)
-Custom Fabricated Fuel Pump Assembly (Walbro 255lph Pump)
-TGV Delete Housings (Ported and Polished w/ bar still in place)
-Magnus Motorsports Intake Manifold (Removed Temp.)
-Hondata Intake Manifold Gaskets
-TurboXS STI UTEC
-TurboXS New Type-H BOV
-AVO 3” Cat-back exhaust system
All Comments and Questions are welcome.
-Matt
ShaggyGT is offline   Reply With Quote
Old 09-11-2005, 02:02 PM   #2
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
very impressive. is this pump or race fuel tune?
how much longer do u think ur tranny will hold up?
stickman is offline   Reply With Quote
Old 09-11-2005, 02:08 PM   #3
ShaggyGT
Member#: 19221
Pump. Tranny should be fine. The clutch did slip one time on the road tune.
-Matt
Old 09-12-2005, 01:16 AM   #4
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
Good job. Nice to see some non-rex's being built
wrxskier18 is offline   Reply With Quote
Old 09-12-2005, 02:08 AM   #5
singsing
Member#: 36991
2003 Liberty B4
blue
how much do you think the TMIC would have held you back by? im interested in converting my FMIC back to a bigger TMIC
singsing is offline   Reply With Quote
Old 09-12-2005, 02:14 AM   #6
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
^_^ Add an alcohol injection kit?
Chi_San is offline   Reply With Quote
Old 09-12-2005, 07:30 AM   #7
ShaggyGT
Member#: 19221
With a FMIC it would have been over 400whp easy. That is pretty much the limit on the Version 7 STi TMIC.
With an upgraded TMIC there may have been more power, but with a rotated 35R a FMIC is really the only way to go. I also dont have room to fit anything bigger than the STi TMIC, so the only option is to go FMIC.
Thanks for the compliments!!
-Matt
Old 09-12-2005, 08:18 AM   #8
WRseX
Member#: 83534
06.5 VW New GTI
That's awesome Matt! I hope to see you some time to go for a ride!
WRseX is offline   Reply With Quote
Old 09-12-2005, 08:19 AM   #9
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
I know someone who sells a frontmount that's custom fitted to a Legacy GT...
def
dug-e-fresh is offline   Reply With Quote
Old 09-12-2005, 08:21 AM   #10
dmross
Member#: 2818
2000 2.5RS
I want your car.
Seriously, very nice car. She must be a treat to drive.
dmross is offline   Reply With Quote
Old 09-12-2005, 09:03 AM   #11
ShaggyGT
Member#: 19221
Thanks guys!!!
Yeah I know who makes a FMIC for my car with a rotated GT3x setup. PDX/GPMoto. I am working on that now.
-Matt
Old 09-12-2005, 04:25 PM   #12
WRXsponge
Member#: 79621
Bug Waggy
3.0 PNP
Right on Matt. Congrats.
-matt t.
WRXsponge is offline   Reply With Quote
Old 09-12-2005, 06:56 PM   #13
CatfaceType-R
Member#: 81102
car is insane....
Old 09-12-2005, 07:23 PM   #14
mno
Member#: 59322
2004 STi WRB,09 G8GT
08 G6, 06 CTS, 2010 Prius
Good to see some Leg on the board. I think with some Alk injection you can make more power and still be safe.
mno is offline   Reply With Quote
Old 09-12-2005, 08:00 PM   #15
ShaggyGT
Member#: 19221
I agree that with Water Injection I could have made more power. I would rather have a FMIC plus water injection evenutally.
Thanks for the compliments!!!
-Matt
Old 09-12-2005, 08:03 PM   #16
gmanwrx
Member#: 53871
08 e92 m3
space grey
look at the size of your turbo. u should make those number with no problem . but good tuning...... great job........
gmanwrx is offline   Reply With Quote
Old 09-12-2005, 08:13 PM   #17
ShaggyGT
Member#: 19221
Yeah its slightly large.
Here is the turbo next to a FP18G with 8cm^2 hotside:
-Matt
Old 09-12-2005, 08:23 PM   #18
gmanwrx
Member#: 53871
08 e92 m3
space grey
what does the 35r start making boost... i see sti at the track with that 35r, and if they don't come out of the hole correct there times suck.... not just on sti but civics also.. that is why i ask..... but that turbo is bigggggggg.
Old 09-12-2005, 08:26 PM   #19
ShaggyGT
Member#: 19221
FULL boost, 25psi, at 4000rpms.
-Matt
Old 09-12-2005, 08:39 PM   #20
gmanwrx
Member#: 53871
08 e92 m3
space grey
thanks cool... good luck and tear it up. drive it like u stole it......
Old 09-12-2005, 08:41 PM   #21
CatfaceType-R
Member#: 81102
got any more vids coming shaggy?
Old 09-12-2005, 09:01 PM   #22
ShaggyGT
Member#: 19221
Yep. I got a MiniDV cam coming and I will get some dyno vids as well as some in car videos.
-Matt
Old 09-12-2005, 09:07 PM   #23
MyScoobie28
Member#: 59185
2014 Impreza WRX
-Matt
holy crap, that is a great amount of boost and horsepower at that RPM. i think that this is a great set up. ever planning on to take it to the track?
MyScoobie28 is offline   Reply With Quote
Old 09-12-2005, 09:24 PM   #24
CatfaceType-R
Member#: 81102
-Matt
sweet...craziest legacy gt on the forums
Old 09-12-2005, 09:37 PM   #25
ShaggyGT
Member#: 19221
Thanks Guys!!
Yeah, eventually I will get it to the drag strip as soon as I can convience a few other locals to go with me.
-Matt
forester xt with legacy GT wheels and bridgestone re-01R's JasonLI25T Member's Car Gallery 9 07-28-2009 01:41 AM
FS: (VT) 2005 Subaru Legacy GT 380WHP/412TQ LRM1981 Private Vehicle 'For Sale' Classifieds 19 05-23-2009 05:15 PM
WRX fronts and old Turbo Legacy rears VS. 2.5 Legacy GT Front and Rears keirnna Brakes, Steering & Suspension 7 03-27-2005 12:34 AM
Just test drove JDM 2.0L new Legacy GT wagon and WRX STi in Tokyo: impressions JDM addict General Community 36 02-18-2004 04:32 PM
301 whp and 312ft lbs with simple mods bigb_9_99 STi Forum Archive 54 06-02-2003 03:16 PM
