Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 09-06-2006, 12:22 PM   #1
WoohooRX
Member#: 70296
04 WRX
rally blue
Lightbulb List of Turbo Spool + Whp characteristics (averages)
I've been researching turbos for the past few days, and realized there's no cohesive turbo spool + whp thread. I understand that it all depends on the TUNE and not all dynos are created equal, however, there seems to be an AVERAGE/COMMON spool/whp for most turbos.
I was hoping there could be a single thread, where newbies, like myself, could have a starting point, just so we don't see a million "____ turbo spool characteristics" or similiar type threads (which there have been a plethora of in the past few days)
This is what I've gathered going through the Factory 2.0L and PPB sections. Please keep in mind, these are all AVERAGES, there is a wide spectrum, absolutely dependent upon the tune.
I'll also need your help, please add anything I've missed, or correct me if I'm wrong in something.
The following is some of the more popular turbos which people ask about. A range of average spool times, and lastly, average Whp with accompanying basic mods (TBE, Injectors, Fuel Pump, IC if required), all data below is on 91-93 oct. pump gas.
Spool = The rpms listed below reflect the time where the turbo is fully engaged, ie the point where your head gets pushed back against the seat.
Turbo_____________Full Spool_____________Avg Whp_______Max Whp
Stock Td 04..........................2900 - 3100......................150 - 185
Td 04..................................2500 - 3000.......................210 - 230..............245
VF 23..................................3300 - 3500........................unsure
VF 34..................................3300 - 3500.......................250 - 270..............300
VF 30..................................3500 - 3700.......................240 - 270..............
VF 39..................................3750 - 4000.......................250 - 270..............
VF 22..................................3500 - 3800.......................265 - 290..............
Small 16g.............................3500 - 3700.......................260 - 280..............
Big 16g................................3500 - 3700.......................260 - 290..............
EVOIII 16g............................3500 - 3700.......................260 - 300..............
18g.....................................3750 - 4000........................280 - 310+............
20g.....................................3800 - 4200........................310++................. .
(The use of P&P, alky/meth, AVCS, etc. will usually decrease the spool times, and increase whp)
For the Max Whp line, keep in mind the following:
1. Dyno reading uncertainty
2. Highly modded, usually includes P&P, and may include alky/meth
3. Validated by atleast 1 person
Please don't bite my head off, I know spool times and whp threads usually end up in people arguing, but hopefully this can be a ROUGH guide.
Let me know if you want to add any other turbos to the list.
VF series turbos: Information taken from amukaoen (http://forums.nasioc.com/forums/show...highlight=vf23)
VF22:
This turbo has the highest output potential of all of the IHI VF series turbos and is the best choice for those who are looking for loads of top end power. The top end power however, does not come without a cost. The VF22 spools significantly slower than the rest of the IHI models due to the larger P20 exhaust housing and is much less suited for daily driving than some of the other models. Although the largest VF series turbo, the VF22 is not quite optimal for stroked engines or those who wish to run more than 20PSI of boost. The VF22 is best mated with the 2.0 block and in applications of 20lbs of boost or less.
VF30:
The VF30 is commonly considered the best bang for the buck turbo in the IHI VF series line. A relatively new model the VF30 features the the same exhaust housing as the VF24 but a larger compressor side similar to the VF22. The combination of these two parts results in increased output potential without the lag associated with the VF22. Although it doesn't offer the top end supremecy of the VF22, the VF30 is a great compromise between these unit and the quicker spooling models.
VF34:
The VF34 is nearly identical to the VF30, with the same exhaust housing and compressor. However the VF34 goes back to the ball bearing design, and in doing so achieves full boost approximately 500RPM sooner than the comparable VF30. The VF34 is the most recent IHI design and as such costs slightly more than its counterpart. Top end performance and maximum output are identical to the 30.
VF23
This turbo is considered a great all-around turbo. Like the VF22 it utilizes the largest P20 exhaust housing. This housing is mated with a smaller compressor housing of the of the VF24 for fast response and excellent low and mid-range performance. It does not have the same top end power of the VF22, but spools up significantly quicker. Standard ball bearing center section. Excellent bolt-on replacement for the standard WRX turbo on cars without any other major modifications. Expect flows around 430 CFM at 18 PSI.
Provided by Dark Rex (*Information was derived from many sources including NASIOC, MRT website, PPMotorsports website, clubwrx.net, scoobytech.net, WorldOne and Rallispec website.)
WoohooRX is offline   Reply With Quote
Old 09-06-2006, 12:30 PM   #2
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Im not biting off your head at all. This is a good idea. Well done.
Assassin4457 is offline   Reply With Quote
Old 09-06-2006, 12:37 PM   #3
shortys64
Member#: 74453
04 WRX-PSM
The following is some of the more popular turbos which people ask about. A range of average spool times, and lastly, average Whp with accompanying basic mods (TBE, Injectors, Fuel Pump, IC if required).
Turbo_______________Spool____________Avg Whp
Stock Td 04.........................2600 - 2800.......................200 - 220
VF 30..................................3500 - 3700.......................unsure
VF 22..................................3800 - 4000.......................265 - 290
Small 16g..............................unsure
Big 16g.................................unsure
EVOIII 16g............................3500 - 3600.......................260 - 290
+1 Good idea, well done
shortys64 is offline   Reply With Quote
Old 09-06-2006, 12:57 PM   #4
trustSTI
Member#: 100673
04 STi
Aspen
Well Done.
This thread should serve your intended purpose quite well.
-Joe
trustSTI is offline   Reply With Quote
Old 09-06-2006, 01:00 PM   #5
SparkysJDMSpeedWagon
Member#: 52530
2004 For Sale:
Silver 04 wagon w/18g
Nicely done! A VF30 should make almost exactly the same power as a VF34, since they're both the same design. The only difference between them is that the VF34 is ball-bearing, so the spool is faster, but the power is the same.
SparkysJDMSpeedWagon is offline   Reply With Quote
Old 09-06-2006, 02:31 PM   #6
peterex
Member#: 27021
2015 WRX
Nice chart. What gear was used to obtain those spool times? Makes a big difference.
peterex is offline   Reply With Quote
Old 09-06-2006, 02:38 PM   #7
Bolster
Member#: 22290
2002 WRB STI Wagon
It'd be good to post which gear those spool times are in. Also, if people can include logs and which gear the pulls were done in, we could get a better idea of how each turbo spools and maybe which mods help/hurt spool.
Bolster is offline   Reply With Quote
Old 09-06-2006, 02:52 PM   #8
WoohooRX
Member#: 70296
04 WRX
rally blue
Thanks, I'll add the change
To be honest I'm not sure what gear all those were done in. I just looked through a ton of threads to get those numbers, some people noted it, but most didn't.
I'll try to go through them again, and see what I can pick up.
Old 09-06-2006, 02:54 PM   #9
TJRCS
Member#: 59199
2008 STI
I'm pretty sure most of people compare the spool up at 3rd since that's the widely used during highway pull
TJRCS is offline   Reply With Quote
Old 09-06-2006, 02:55 PM   #10
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
nice, when enough information gets compiled. i bet theres a great chance that it'll end up as a sticky... cause there are way too many.. "how much WHP and how bad will the spool be" threads everyday.
amukaoen is offline   Reply With Quote
Old 09-06-2006, 03:06 PM   #11
Jasper
Member#: 80136
2006 Ford F-150
just to make a note, there ARE TD04 powered WRX's making 240-250whp (albeit heavily modified)
(and FYI, my ported TD04 hits 18psi (in 5th gear) @ 2350ish RPM....4th is roughly 2500rpm, 3rd = ~ 2900rpm, 2nd (17.9psi) = ~ 3200rpm, and i managed to hit 16.6psi in first @ 3800 (although i cant get it to stay constant, it'll surge between 16 and 18psi, gotta mess w/ my WGDC's and temp compensation a bit more, because it changes with the weather)
Jasper is offline   Reply With Quote
Old 09-06-2006, 03:33 PM   #12
ThisizBrian
Member#: 106117
my vf22 doesnt spool that late. its around 3400
ThisizBrian is offline   Reply With Quote
Old 09-06-2006, 04:20 PM   #13
Blown95ImpalaSS
Member#: 87629
I run a vf39 and I believe that in general they spool a bit more quickly (~ 3300 rpms) than the other vf series turbos because it is the smallest of those you have listed aside from the td04. The horsepower figures are right on target though.
my .02..
Blown95ImpalaSS is offline   Reply With Quote
Old 09-06-2006, 04:26 PM   #14
dingobite
Member#: 82391
08 OBP Sti
Nice...............
Now if there was some type of topend chart for the 2.0 to go with it.
Like
TopEnd Distance
16g/Vf -----?
Evo3 -------??
18g --------???
Anything Bigger - ? +
dingobite is offline   Reply With Quote
Old 09-06-2006, 04:27 PM   #15
wrxzboost
Member#: 86322
even though they are approximate times, i think the stock td04 is the hardest to get right since a full exhaust significantly changes the spool characteristics of the turbo. after cobb stage 2, i can hear my turbo spool at 1800-1900 rpms...insanely early. but its a nice idea; especially for noobs.
wrxzboost is offline   Reply With Quote
Old 09-06-2006, 04:32 PM   #16
JWill7
Member#: 123261
2011 WRX 5-Door
Awesome idea. Subscribing in case it doesn't get stickied.
JWill7 is offline   Reply With Quote
Old 09-06-2006, 04:36 PM   #17
WoohooRX
Member#: 70296
04 WRX
rally blue
my .02..
It's important to keep in mind that everyone has access to different tuners. I really think you guys have really good tunes. The general concensus out there, is that the VF34 is the quickest spooling of the vf series turbos. Followed by the VF39, and then lastly the VF22.
I just put those numbers up because it seems like, from reading a ton of threads on these turbos, that the 39/22 are later spoolers, but tend to have a higher top end.
If some more people chime in with their comments/setups/results then we can change it.
Old 09-06-2006, 04:53 PM   #18
REX8
Member#: 24038
I'd say most peoples TD04 on EM are at least the 220 whp mark. maybe 220-230 average.
REX8 is offline   Reply With Quote
Old 09-06-2006, 05:11 PM   #19
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Sticky!!
Awesome work. I was just deciding on a turbo, and this would have saved me many hours of searching.
ErasureWRX is offline   Reply With Quote
Old 09-06-2006, 05:15 PM   #20
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
id say 210-225 whp for TD04 is average. So you're definatly spot on. Cobb OTS Stage 2 map probably claims the majority of these users.
Old 09-06-2006, 05:17 PM   #21
prometheum
Member#: 92003
04 bicycle!
i got a small 16g spools at arround 3400ish can't tell you how much hp though
prometheum is offline   Reply With Quote
Old 09-06-2006, 05:28 PM   #22
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
What PSI do u consider spool? 18? 19? 22? etc might want to add that to the list.
Token-Negro is offline   Reply With Quote
Old 09-06-2006, 05:32 PM   #23
shikataganai
Member#: 92634
'19 Volvo XC40
'18 Pacifica PHEV
you'd be surprised at how many schmucks here on nasioc quote 5th gear pulls on the highway under load...
shikataganai is offline   Reply With Quote
Old 09-06-2006, 06:10 PM   #24
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Good Point there. When everyone says "it spools at xxxx, what do you really mean ? Are you at full boost at xxxx, or just making boost then?
Old 09-06-2006, 06:49 PM   #25
baldchicken
Member#: 92670
03 WRX
Very good write up. I always did the research on the interweb about the different turbos, but there wasnt really anything to compare them. Thanks for taking the time to do this for us.
baldchicken is offline   Reply With Quote
List of Turbos specs alex02wrx Built Motor Discussion 1 09-05-2008 10:47 AM
list of turbos capable of 500whp... 300zrex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 54 08-18-2007 12:08 PM
Know a list of turbo sizes for all Impreza versions? WRX, STI, Spec C etc. MarylandEcstasy General Community 9 01-01-2007 10:19 AM
List of Turbo Kits Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-25-2005 01:47 PM
Complete List Of Turbo Kit Suppliers For RS subarumantoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2001 09:43 AM
