Welcome to the North American Subaru Impreza Owners Club Tuesday October 17, 2017
Old 02-08-2012, 05:32 PM   #1
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Default Eibach/SPC lateral links (Pro Alignment kit)
I have the Eibach branded links. Actually it is only an Eibach box, the links are stamped SPC. They are made in China. Build quality is good at least on par with stock links. The welds are functional but not beautiful. They have rubber bushings which with a fingernail test seems harder than stock. I had no issues with installing them. Very good adjustability too. After a month of driving they are not noisy at all. That is no extra noise, vibration or harshness. The rear has a smooth, solid feel. They are not flashy but work well.
Forgot to mention that they are very reasonably priced. I have seen a full set of 4 links for about $260. I feel they are as good if not better replacement option than stock.
I did not trust the E-Bay(Godspeed, etc.) links to go that route. I have heard of to many failures.
Bikelok is offline   Reply With Quote
Old 08-27-2012, 07:23 PM   #2
robbyh
Member Sales Rating: (1)
Member#: 326959
2004 wrx
black
Just got a set myself to provide some adjustability in the rear. Will be installing them this weekend.
robbyh is offline   Reply With Quote
Old 09-09-2012, 04:41 PM   #3
Legend2
Member Sales Rating: (11)
Member#: 250595
04 wrx wagon
Can you measure one adjusted all the way out to see if these will work for us wagon owners. From bolt hole to bolt hole please.
I hope to catch you before you install.
Legend2 is offline   Reply With Quote
Old 09-13-2012, 02:29 AM   #4
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
RSD says they work for all Impreza/WRX, wagons and sedans, from 1993-2007.
cal_look_zero is offline   Reply With Quote
Old 02-08-2013, 02:01 PM   #5
jkling4591
Member#: 344755
2002 wrx
MBP(08V)
i'm about to order a set myself but they look like its a set of 2 fronts am i mistaken?
jkling4591 is offline   Reply With Quote
Old 02-12-2013, 07:07 PM   #6
jkling4591
Member#: 344755
2002 wrx
MBP(08V)
so even though they stamped SPC they Eibach right?
Old 03-24-2015, 01:20 AM   #7
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Here's an update.
All is well with them.
Zero problems (I do live in salt fee CA though, so I can't comment on how they hold up to the "real" elements).
To answer the old questions from jkling4591 (sorry I never responded. I lost track of this thread).
I got the full kit. This includes 4 lateral links, 2 sway bar end link "blocks", and I believe 4 steel sleeves (the sleeves are used in the front inboard location)(sorry but I'm going off my feeble memory here).
The links are indeed stamped SPC but they came in an Eibach box.
Bottom line is I'm still pleased.
Old 10-11-2015, 11:08 PM   #8
switch900
Member#: 169446
2005 sti
wrb
So I have some on my sti and the bushings are shot. Does anyone know if they are the same size as stock or do they sell just the bushings ,I've had no luck Google it.
switch900 is offline   Reply With Quote
Old 11-27-2015, 02:41 AM   #9
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Sorry I don't keep track of this thread, but I do have measurements. I was thinking the same thing when I bought them.
They are lost in a pile of mess right now.
I'll try to dig them up as soon as I can.
If you have already figured it out please let's us know.
Thanks.
Old 11-27-2015, 09:03 AM   #10
switch900
Member#: 169446
2005 sti
wrb
I have figured it out, they are 40 mm bushings I believe stock is 36 mm and know one makes a replacement except for SPC themselves. I ordered some, 16 bucks each. They also make a pillow style bushing for them as well.
Old 11-27-2015, 12:21 PM   #11
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Sweet!!!
Thanks for the reply.
Old 11-28-2015, 03:48 PM   #12
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Hey, can you share part numbers please.
Old 11-28-2015, 05:34 PM   #13
switch900
Member#: 169446
2005 sti
wrb
60009405 is that part number.
Old 11-29-2015, 12:50 AM   #14
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Thanks!!!
Old 04-08-2017, 10:41 PM   #15
dictoresno
Member Sales Rating: (14)
Member#: 139816
2002 WRX, VF34 swap
I need these bushings too and can't find them by the part number listed. Anyone else have the right part number or know where to get them?
dictoresno is offline   Reply With Quote
Old 10-11-2017, 11:30 PM   #16
Bikelok
Member#: 254851
2002 WRX wagon 5mt
They do have a phone number to call. Perhaps try calling directly.
Old 10-11-2017, 11:32 PM   #17
dictoresno
Member#: 139816
2002 WRX, VF34 swap
I did call them and got the bushings I needed back in April.
SPC adjustable lateral links FastfreddyRs Suspension/Brakes/Handling 3 10-28-2008 10:08 AM
Feeler - SPC Lateral links hybrid gti 2 Suspension/Brakes/Handling 18 03-19-2008 11:09 PM
What chould I do with these SPC lateral links? hybrid gti 2 Brakes, Steering & Suspension 12 02-13-2008 02:32 AM
What do I do with these lateral links? SPC hybrid gti 2 Suspension/Brakes/Handling 0 02-11-2008 04:19 PM
SPC Lateral Links 69_Lex Suspension/Brakes/Handling 1 11-17-2007 09:01 PM
