Welcome to the North American Subaru Impreza Owners Club Monday October 15, 2018
Old 10-22-2002, 07:55 PM   #1
kiwirallynut
Member#: 19032
2002 wrx
Default CEL Lean on bank one ??
Ok I have a major hesitation, surge on very light throttle in any gear, 5 to 10% throttle. As the weather has cooled it has become worse. I can drive the car hard and it feels perfect. CEL is on and comes up with lean on bank 1. The only mod is HKS downpipe everthing else is stock, only 5500 miles any suggestions??
kiwirallynut is offline   Reply With Quote
Old 10-22-2002, 08:18 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
"Bank 1" on a WRX means the front A/F sensor. And you don't have an aftermarket intake?
Jon [in CT] is offline   Reply With Quote
Old 10-22-2002, 08:42 PM   #3
kiwirallynut
Member#: 19032
2002 wrx
Ok stock intake, no mods there. Where is the front A/F sensor I can at least make sure its pluged in Thanks.
Old 10-23-2002, 02:01 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
actually Jon Bank 1 refers to the primary injector bank being lean, i.e.: all 4 cylinders.
You have a vacuum leak somewhere. Almost guarantee it, that or you have a bad FRP.
jeremy
Old 10-23-2002, 06:17 PM   #5
kiwirallynut
Member#: 19032
2002 wrx
More info, when I start the car from cold, as it comes down from the fast idle it starts to run on 3 cyls I have isolated it to number 1, when it gets to normal temperature its on 4 again. Does that mean bad injecter? Thanks Jeremy for your reply , what is FRP? Thanks.
Old 10-24-2002, 02:45 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
FPR=Fuel pressure Regulator, sounds like you have a dead injector, i rec you take it to the dealer, you'll need to check for injector pulse. If you want to know if the injector is firing you can pick up a $10 Automotive Stehoscope(spelling??) from your local pep boys, auto zone, checker, whatever and listen to all 4 injectors, you should get the same sharp clicking noise out of them. Make sure the vaccum hose to the fuel pressure regulator hasn't fallen off(since it runs off #1). Do you hear any strange whistling?? it honestly sounds like a dead injector(rarely see harness problems, unless it's my mom's saturn which just instantly lost injector pulse on #1 2 weeks ago)
Jeremy
CEL running lean on bank 1 gobluesubygo Engine Management & Tuning 1 02-27-2010 10:52 PM
cel code p0171 system too lean ( bank 1) gillyfesh7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-01-2008 11:59 AM
Lean Burn Bank 1 CEL - Searched JSarv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-24-2008 09:46 PM
CEL says lean on bank one.... sflint50 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-11-2007 10:39 PM
Cel thrown saying lean on bank one redhat778 Engine Management & Tuning 0 10-06-2003 08:43 PM
