05-31-2011, 02:50 PM | #51 | |
Member#: 19640
RMIC
Vehicle:2003 WRX Sedan WRB |
And yes, it was crying. Damn car is brand new!!!
05-31-2011, 04:12 PM | #52 |
Member#: 90597
Vehicle:2011 WRX Premium SWP |
Would it be worth it to use a sandwich block adapter as opposed to the stock location? Is this a better spot? I want a oil pressure gauge but I also want to keep my dummy light as a redundant safety.
05-31-2011, 04:21 PM | #53 |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
Replacing the stock sensor is a much better location to read oil pressure.
06-02-2011, 08:49 AM | #54 | |
Member#: 19640
RMIC
Plus taking apart a new car is fun - even when you cry (phat Korean). |
06-02-2011, 09:17 AM | #55 |
Member#: 276710
Vehicle:2010 Impreza 2.5i Dark Grey Metallic |
Great job!!! Looks clean.
06-03-2011, 04:21 PM | #56 |
Member#: 284392
South East
Vehicle:2011 STI Limited Plasma Blue Pearl |
Super useful write-up, thank you kindly and awesome idea with the longer bolt for a 'stiff' mounting spot.
Gonna do the same for my '11 STI |
06-29-2011, 04:34 AM | #57 |
Member#: 262683
BAIC
Vehicle:2011 WRX base SWP |
Thank you so much for the tutorial! I have the exact same setup. I didn't have the foresight for the fuse extensions. I couldn't wait, so I did the lamebrain stick-the-wire in w/ the fuse method. Functionality-wise it does work, but that shall be a temporary solution.
You can actually use the existing allen socket head cap screw and the lock washer/nuts that come in the package with the gauges to hold the boost gauge sensor attachment to the hose. That, and I was too lazy to take drive to the hardware store. .. . haha |
06-30-2011, 07:27 AM | #58 |
Member#: 286449
RMIC
Vehicle:2000 RSTi (v6 EJ207) Silver |
1) Where does the wire coming out of this box go? What does it connect to?
2) Is this box included with the boost gauge? Or is it purchased seperately? 3) I assume that this box takes the boost/vacuum reading and sends it out electronically to the gauge. Is this correct? 4) The only wires coming out of the gauge appear to be a ground, constant, switched, and dimmer wire. Where is the gauge getting the actual boost signal from? Is there a plug or something on the back of the gauge like in the BF series? 5) Where did you get your Defi Red Racer gauges from? (And would you recommend getting mine from the same place?) 6) Is there any place in particular you found to be an easy, out of the way location to mount the ground wire to? Last edited by TeeJayHoward; 06-30-2011 at 07:46 AM. |
06-30-2011, 07:52 AM | #59 | |
Member#: 261612
06-30-2011, 04:50 PM | #60 |
Member#: 19081
SCIC
Vehicle:2011 WRX 5 Door Silver |
Great writeup OCD. This is what I was planning to do anyway except have Oil Temp and your instructions are helpful. Does Defi do a those gauges with white needles to match the Subie instruments more perfectly?
BillRo |
07-07-2011, 09:01 AM | #61 | |
Member#: 128643
Vehicle:2022 WRX White |
MadDad also has gauges that match but not a full line like Prosport. Friend me on Facebook for updates. smyclustermaker |
07-09-2011, 03:26 PM | #62 |
Member#: 267906
W. Canada
Vehicle:'11 STi Hatch SWP |
You could go super spendy and get the JDM Subaru Meter set (H5017FG011). They are basically Defi Racer gauges with white needles, no flashing on startup and no shutdown "ceremony". They aren't cheap but match perfect. Only downsides is that they are only available in boost (kPa - metric) and oil temp (degrees C - metric).
07-09-2011, 03:49 PM | #63 | |
Member#: 286449
RMIC
07-09-2011, 05:33 PM | #64 | |
Member#: 274670
Vehicle:2016 S3 Glacier Metallic White |
Weird ... it doesn't bother me so much that the needles don't match |
07-25-2011, 10:30 AM | #65 |
Member#: 284003
Vehicle:2010 Alpine 135i |
For anyone looking for those fuse taps, i think i found them on Ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT I just got a set of 5 for $17 shipped, assuming they are the mini size and not the larger size. |
07-25-2011, 10:37 PM | #66 |
Member#: 266458
Vehicle:2011 WRX sedan black |
nice setup..anyway you can throw me the part number or the exact specs of those fuse taps? Thanks
07-28-2011, 07:53 PM | #67 |
Member#: 98210
Vehicle:2016 Forester XT CWP 2002 WRX SRP 2016 Sienna |
thanks a lot! this thread was extremely helpful
07-29-2011, 12:36 PM | #68 |
Member#: 204304
Vehicle:2008 WRX 4D Stage 2 Silver |
Great write up.
08-01-2011, 08:44 PM | #69 |
Member#: 19640
RMIC
08-01-2011, 09:47 PM | #70 |
Member#: 98210
Just get the jdm spt gauges or w/e
08-03-2011, 10:10 AM | #71 |
Member#: 128643
ProSport White Needle Gauges
08-03-2011, 11:39 AM | #72 |
Member#: 19640
RMIC
Could it be irony that I am wearing my SMY shirt today and then see this?! Hmmmmm.
08-03-2011, 11:45 AM | #73 |
Member#: 128643
08-03-2011, 01:09 PM | #74 |
Member#: 98210
is it normal for the boost to spike to around 15 and then drop down a bit stock? anyone have a stock acceleration vid with a boost gauge?
08-04-2011, 11:52 AM | #75 |
Member#: 282204
Vehicle:2011 5 Door STi Plasma Blue Pearl |
I think I did it
I think I've wired the defi boost gauge so that it does not do the double sweep during the ignition cycle.
To be totally honest it was by accident when I was fiddling with the illumination wire. for reference: 2011 STi Orange # 4 Red #24 White #14 I hope this helps... BTW here is the youtube: http://youtu.be/uxUkeY_po1w Last edited by CTSparky; 08-04-2011 at 11:58 AM. Reason: adding in the video |
Similar Threads | ||||
NOAH is a tool....and I can proove it (Post here if you want points!) | madcatz | Mid West Subaru Owners Club Forum -- MWSOC | 14 | 05-02-2011 06:47 PM |
Tell us how Subiefest went when you get back tonight & pics if you have them | KB'izzle | Southern California Impreza Club Forum -- SCIC | 361 | 10-30-2009 07:57 PM |
ssr professors, post pics if you have them | streko | Member's Car Gallery | 2 | 07-22-2004 04:27 PM |
Anyone put WRX stock rims on an RS? Pics if you have them... | Samirr76 | Interior & Exterior Modification | 2 | 07-21-2001 03:15 AM |
