Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 01-27-2017, 04:18 PM   #226
yfz460
Member#: 167143
2011 SWP WRX Hatch
2007 SWP STi
Originally Posted by jlangholzj View Post
2014 USDM wrx. Built everything as-advertised (sans a different FDTI widget) and I'm getting the below in my log. The only reference I was able to find with the last lines was on an FT86 forum and it didn't sound too good Only other thing I can think of is that my fluke is telling me my 555 is outputing 230Hz and not 150, despite the values being correct. I guess I don't have a scope to see if it's ACTUALLY at 230 or if its because it's too low a voltage for the fluke to read reliably.
Anyway, got an email into tactrix but I'm assuming because of the long weekend they'll probably be out. Figured I'd toss up something on here and see if anyone knew what was up. thanks all.
Code:
[12:55:21.048] Logging to file C:/Users/John/AppData/Roaming/OpenECU/EcuFlash/logs/ecuflash_log_20160703t125521.txt
[12:55:21.048] EcuFlash Version 1.44.4799
[12:55:21.048] OS Version Windows 8.1
[12:55:21.048] Kernel Type winnt
[12:55:21.048] Kernel Version 6.3.9600
[12:55:21.048] CPU i386
[12:55:21.048] Product Name Windows 8.1
[12:55:21.048] Product Type windows
[12:55:21.048] Product Version 8.1
[12:55:21.048] Qt Version 5.6.0
[12:55:21.048] Qwt Version 6.1.2
[12:55:21.048] QwtPlot3D Version 0.2.6
[12:55:21.048] Boost Version 1.60
[12:55:21.048] FTDI Library Version 3.02.11
[12:55:21.048] Openport J2534 Library Version 1.02.4798
[12:55:21.079] 67 memory models read.
[12:55:21.079] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[12:55:21.532] 745 ROM metadata models scanned.
[12:55:21.532] checksum module "subarudbw" loaded.
[12:55:21.532] checksum module "subarudiesel" loaded.
[12:55:21.532] checksum module "subaruhitachi" loaded.
[12:55:21.532] checksum module "mitsucan" loaded.
[12:55:21.532] checksum module "mitsuh8" loaded.
[12:55:21.532] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[12:55:21.532] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[12:55:21.548] using metadata XML ID read_subarush7058can from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_subarush7058can.xml
[12:55:21.610] flashing tool "wrx02" loaded.
[12:55:21.626] flashing tool "wrx04" loaded.
[12:55:21.626] flashing tool "sti04" loaded.
[12:55:21.642] flashing tool "sti05" loaded.
[12:55:21.642] flashing tool "mitsucan" loaded.
[12:55:21.642] flashing tool "mitsukernel" loaded.
[12:55:21.642] flashing tool "mitsukernelocp" loaded.
[12:55:21.642] flashing tool "mitsubootloader" loaded.
[12:55:21.642] flashing tool "shbootmode" loaded.
[12:55:21.642] flashing tool "shaudmode" loaded.
[12:55:21.657] flashing tool "subarucan" loaded.
[12:55:21.657] flashing tool "subarucand" loaded.
[12:55:21.673] flashing tool "subarubrz" loaded.
[12:55:21.673] flashing tool "subaruhitachi" loaded.
[12:55:21.720] FTDI Driver Version 2.12.16
[12:55:21.720] Using interface FT232R USB UART A50285BI
[12:55:21.720] interface close
[12:55:21.782] FTDI Driver Version 2.12.16
[12:55:21.782] Using interface FT232R USB UART A50285BI
[12:55:21.782] interface close
[12:55:21.845] FTDI Driver Version 2.12.16
[12:55:21.845] Using interface FT232R USB UART A50285BI
[12:55:21.845] interface close
[12:55:21.907] FTDI Driver Version 2.12.16
[12:55:21.907] Using interface FT232R USB UART A50285BI
[12:55:21.907] interface close
[12:55:21.970] FTDI Driver Version 2.12.16
[12:55:21.970] Using interface FT232R USB UART A50285BI
[12:55:21.970] interface close
[12:55:22.032] FTDI Driver Version 2.12.16
[12:55:22.032] Using interface FT232R USB UART A50285BI
[12:55:22.032] interface close
[12:55:30.830] opening rom file C:/Users/John/Google Drive/ROMS/USDM_2014_WRX.bin
[12:55:31.158] AE5Q100L (365 tables) inheriting 32BITBASE (1237 tables)
[12:55:31.251] 1048576 byte image read.
[12:55:31.345] using metadata XML ID AE5Q100L from file C:/Program Files/OpenECU/EcuFlash/rommetadata/subaru/Impreza WRX/AE5Q100L 2014 USDM Impreza WRX MT.xml
                which inherits XML ID 32BITBASE from file C:/Program Files/OpenECU/EcuFlash/rommetadata/subaru/Bases/32BITBASE.xml
[12:55:31.345] ---notes for 32BITBASE---
               2014/06/20 [Tactrix] Tactrix definition auto cleaned|merged w/ RomRaiderGitHubAlphaMay2014.
               ---notes for AE5Q100L---
               2014/05/22 [Tactrix] Tactrix definition auto cleaned|merged w/ RomRaiderGitHubAlphaMay2014.
[12:55:36.736] FTDI Driver Version 2.12.16
[12:55:39.033] sending bit rate sync bytes...
[12:55:39.143] received bit rate adjust response
               sending boot command
[12:55:39.659] got boot response
[12:55:39.800] 1 supported device(s):
[12:55:39.800]    1n01 R4F70580S
[12:55:39.800] selecting device 1n01
[12:55:40.034] 1 supported clock mode(s):
[12:55:40.034]    0
[12:55:40.034] selecting clock mode 0
[12:55:40.269] 2 supported clock type(s):
[12:55:40.269] 1 ratios for clock type 1
[12:55:40.269]    x8
[12:55:40.269] 1 ratios for clock type 2
[12:55:40.269]    x2
[12:55:40.394] 2 supported clock frequency range(s):
[12:55:40.394] 1 40000000-80000000
[12:55:40.394] 2 10000000-20000000
[12:55:40.519] 1 user boot MAT area(s):
[12:55:40.519] 1 00000000-00002fff
[12:55:40.628] 1 user MAT area(s):
[12:55:40.628] 1 00000000-000fffff
[12:55:40.753] programming unit is 128
[12:55:40.878] one MAT programming supported at 00000000
[12:55:40.878] setting baud rate to 62500
[12:55:41.128] there are more memory areas in this CPU that will be erased than the ROM file you have has data for. write process aborted.
[12:55:41.128] interface close
Did you ever resolve this issue? Currently in the same boat, built with FTDI 6-wire cable, 555 only verified at 2.4vdc with RMS meter (no access to o-scope). My original issue was after unmarrying an AP V2, I was never able to flash again. Car runs and drives fine, and can log data/reset without issue. Here's my log from ECUflash:
[15:56:53.905] using metadata XML ID AE5I910L from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Impreza WRX/AE5I910L 2011 USDM WRX MT.xml
which inherits XML ID 32BITBASE from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Bases/32BITBASE.xml
[15:56:53.905] ---notes for 32BITBASE---
---notes for AE5I910L---
2012/11/30 [Tactrix] Experimental definition from RomRaider.
2012/12/05 [Tactrix] Visually examined a portion of tables for obvious errors, but no in-car verification has been done. Standardized file name.
[15:57:48.423] FTDI Driver Version 2.12.24
[15:57:50.615] sending bit rate sync bytes...
[15:57:51.473] received bit rate adjust response
[15:57:54.343] received bit rate adjust response
[15:57:58.399] no bit rate adjust response
[15:57:58.399] interface close
[15:58:11.299] FTDI Driver Version 2.12.24
[15:58:16.149] sending bit rate sync bytes...
[15:58:16.273] received bit rate adjust response
[15:58:16.788] got boot response
[15:58:16.913] 1 supported device(s):
[15:58:16.913] 1n01 R4F70580S
[15:58:16.913] selecting device 1n01
[15:58:17.163] 1 supported clock mode(s):
[15:58:17.163] 0
[15:58:17.163] selecting clock mode 0
[15:58:17.397] 2 supported clock type(s):
[15:58:17.397] 1 ratios for clock type 1
[15:58:17.397] x8
[15:58:17.397] 1 ratios for clock type 2
[15:58:17.397] x2
[15:58:17.521] 2 supported clock frequency range(s):
[15:58:17.521] 1 40000000-80000000
[15:58:17.521] 2 10000000-20000000
[15:58:17.631] 1 user boot MAT area(s):
[15:58:17.631] 1 00000000-00002fff
[15:58:17.755] 1 user MAT area(s):
[15:58:17.755] 1 00000000-000fffff
[15:58:17.865] programming unit is 128
[15:58:17.989] one MAT programming supported at 00000000
[15:58:17.989] setting baud rate to 62500
[15:58:18.255] query complete
[15:58:18.255] interface close
[15:58:27.971] FTDI Driver Version 2.12.24
[15:58:30.699] sending bit rate sync bytes...
[15:58:31.026] no bit rate adjust response
[15:58:31.026] interface close
[15:58:44.152] FTDI Driver Version 2.12.24
[15:58:47.249] sending bit rate sync bytes...
[15:58:47.374] received bit rate adjust response
[15:58:47.888] got boot response
[15:58:48.013] 1 supported device(s):
[15:58:48.013] 1n01 R4F70580S
[15:58:48.013] selecting device 1n01
[15:58:48.263] 1 supported clock mode(s):
[15:58:48.263] 0
[15:58:48.263] selecting clock mode 0
[15:58:48.512] 2 supported clock type(s):
[15:58:48.512] 1 ratios for clock type 1
[15:58:48.512] x8
[15:58:48.512] 1 ratios for clock type 2
[15:58:48.512] x2
[15:58:48.622] 2 supported clock frequency range(s):
[15:58:48.622] 1 40000000-80000000
[15:58:48.622] 2 10000000-20000000
[15:58:48.746] 1 user boot MAT area(s):
[15:58:48.746] 1 00000000-00002fff
[15:58:48.871] 1 user MAT area(s):
[15:58:48.871] 1 00000000-000fffff
[15:58:48.980] programming unit is 128
[15:58:49.105] one MAT programming supported at 00000000
[15:58:49.105] setting baud rate to 62500
[15:58:49.370] there are more memory areas in this CPU that will be erased than the ROM file you have has data for. write process aborted.
[15:58:49.370] interface close
yfz460 is offline   Reply With Quote
Old 01-27-2017, 04:49 PM   #227
jlangholzj
Member#: 377640
2014 WRX hatch
Negative mate, sorry. I've still got the ECU pigeonholed away in a box for future fiddling but for the time being I found a good used ECU on flebay and had a local dealership reprogram the immobilizer.
jlangholzj is offline   Reply With Quote
Old 04-03-2017, 11:52 PM   #228
leandropim
Member#: 465484
2015 STI
Someone can help me with powering a STI 2015 ECU (SH7058)
112331-7390
thank you
leandropim is offline   Reply With Quote
Old 04-04-2017, 11:22 AM   #229
leandropim
Member#: 465484
2015 STI
i would like to know if a 0.6w 47.5Kohms 1% will work? or will i need 1w or more?
Old 04-05-2017, 11:44 PM   #230
leandropim
Member#: 465484
2015 STI
"there are more memory areas in this CPU that will be erased than the ROM file you have has data for. write process aborted."
*** Use Renesas FDT and write the ROM on the User Area
https://www.renesas.com/pt-br/software/D3017335.html
Old 04-10-2017, 11:01 AM   #231
leandropim
Member#: 465484
2015 STI
Old 04-10-2017, 12:31 PM   #232
yfz460
Member#: 167143
2011 SWP WRX Hatch
2007 SWP STi
I'll have to check that out, I don't recall doing anything specific to try and flash via FDT, just clicked through the program as it was set up.
Thanks!
Old 07-28-2017, 11:07 PM   #233
Counti41
Member#: 471893
Need to recover my 05 LGT ecu as well. Anyone that can help.
Counti41 is offline   Reply With Quote
Old 10-02-2017, 05:24 PM   #234
BoxerLove
Member#: 411441
Im ready to give this a shot on my 05 STI as the ecu has to be locked up. My car has the immobilizer, would flashing with the Shboot method require me to have the immobilizer portion reprogrammed? Does the ecu store that data in whats being force flashed over?
BoxerLove is offline   Reply With Quote
Old 10-02-2017, 06:45 PM   #235
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
I haven't had any issues with immobilizers on all of the ECUs that I've done. It's just overwriting the engine parameters, nothing to do with the immobilizer.
Noah is offline   Reply With Quote
Old 10-03-2017, 03:22 PM   #236
BoxerLove
Member#: 411441
Awesome man. Thanks. Wanted to make sure I didn't back myself into paying a tow bill to get it to the dealer lol. I decided to try purchasing an adjustable ne555 board and using my usb uart I already had to test on a spare ecu I have before flashing my presumed locked one in the car now. Will report the results!
Old 10-04-2017, 05:49 PM   #237
BoxerLove
Member#: 411441
Noah,
So today I got it all wired to the ECU and did a test flash on my spare ECU. Here is the log.
Flash Development Toolkit and flash programming components
are provided without support
OS: Windows 10 (Windows 8) [Admin]
Disconnecting
Disconnected
Clock Frequency (External) = 10.0000MHz, Clock Mode = 0, CKM = 4, and CKP = 2
Connecting to device 'SH/7058F' on 'COM4'
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'COM4' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Attempting 9600
Received immediate response from device: 0xE6
Detected generic boot device
Sending inquiry for getting line size
Buffer size has been set to default (128 bytes)
Sending selection of device command
Selection of Device - Device selected, code 0601
Sending selection of clock mode
Selection of Clock Mode - Clock selected, code 0
Changing baud rate to 57600 bps
Set baud rate value = 57600
Determining block usage
Connection complete
Processing file :"C:\Users\Anon\Desktop\A2ZJB10J.bin"
Loading image file : 'C:\Users\Anon\Desktop\A2ZJB10J.bin'
Operation on User Flash
Loaded the Write operation module
Writing image to device... [0x00000000 - 0x00000E7F]
Writing image to device... [0x00000F80 - 0x00001F7F]
Writing image to device... [0x00001F80 - 0x0007B07F]
Writing image to device... [0x000C0000 - 0x000CADFF]
Writing image to device... [0x000CAE00 - 0x000CD6FF]
Writing image to device... [0x000FFA80 - 0x000FFAFF]
Writing image to device... [0x000FFB80 - 0x000FFFFF]
Data programmed at the following positions:
0x00000000 - 0x00000E7F Length : 0x00000E80
0x00000F80 - 0x00001F7F Length : 0x00001000
0x00001F80 - 0x0007B07F Length : 0x00079100
0x000C0000 - 0x000CADFF Length : 0x0000AE00
0x000CAE00 - 0x000CD6FF Length : 0x00002900
0x000FFA80 - 0x000FFAFF Length : 0x00000080
0x000FFB80 - 0x000FFFFF Length : 0x00000480
546.88 K programmed in 106 seconds
Image written to device
Disconnecting
Disconnected
Does everything look ok here? Seemed quick compared to the OP's post. I noticed some differences in his vs my log. Wondering if thats because my ECU had the 7058 chip?
Just wanted to be sure of myself and my setup before attempting the ECU I believe is locked in my car now.
I was using a purchased Adjustable NE555 device that I set to 125-150 HZ and checked with my Fluke 77 IV multimeter on AC HZ mode, And my USB UART
Old 10-05-2017, 12:50 PM   #238
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Noah,
Disconnecting
Disconnected
Configuration:
Loading Comms DLL
Loaded Comms DLL
Attempting 9600
Connection complete
Disconnecting
Disconnected
If you've made it to the highlighted section, you're good to go. The 2004 STI uses the SH 7055 chip, all revisions after 2004 used the 7058 chip so no worries. It looks like you flashed a 2005 STI ROM on to your ECU. If that's correct and it matches your car, plug it in and make sure your car starts.
Old 10-06-2017, 01:17 AM   #239
BoxerLove
Member#: 411441
Looks like I'll be trying this on my actual ecu in the car (attempted my first flash on my spare ecu just so I didn't leave the car dead in the water). The car came with a spare ecu which wasnt programmed to the immobilizer. My car is an 05 STI so correct I have the 7058 chip. Will post back my results tomorrow! Setup was honestly super easy with a $5 555 adjustable timing board and the $3-5 UART being I have a multimeter than could read hz
Old 10-12-2017, 08:13 PM   #240
hopefullynotrice01
Member#: 472940
bravo
hopefullynotrice01 is offline   Reply With Quote
Old 10-13-2017, 01:17 PM   #241
BoxerLove
Member#: 411441
IT WORKED! Successfully flashed my 05 STI ECU and was able to pull the rom with ECU Flash after.
Old 01-19-2018, 02:34 PM   #242
jmfangio
Member#: 480852
Hi Franko ! nice too meet you i readed your post.
I brick the ECU too but mine is different i attached the link
https://drive.google.com/open?id=1Sy...DYiW3ZKd5429p-
so if you know about recovery this ECU i willl very grateful.
thanks for your time
Seb
PD: i cant create a post because im newbie
jmfangio is offline   Reply With Quote
Old 04-12-2018, 10:27 AM   #243
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Looks like I'll be trying this on my 05 sti as my laptop decided mid flash to get confused. It may be a blessing in disguise as i found an issue with the ecu circuit board (probably my original issue) I'll have to take care of first, if even possible. Anyone familiar with what this component is?....
TyranosaurusWRX is offline   Reply With Quote
Old 04-17-2018, 06:17 AM   #244
teds-rex
Member#: 400886
2004 STi
From the label looks to be a diode. Can you read any of the text on the top of the component or is it too toasty?
teds-rex is offline   Reply With Quote
Old 04-17-2018, 06:37 AM   #245
JMlegacy
Member#: 341649
"D5" is what I make out too. Diode.
JMlegacy is offline   Reply With Quote
Old 04-17-2018, 12:25 PM   #246
mikeyPSF
Member#: 236475
It's definitely a diode. Looking at a similar ECU board we have here, your cooked component is labeled D505 on the board and D4 3G on the component itself. Nearby (13/16" away) D808 on the board uses the same D4 3G labeled diode. I've been trying to find some schematic info we have here somewhere to see if I can figure out the other details so you can source a replacement but I haven't been able to dig that up yet. If you don't have any luck by Friday, I might have some help here that day that can get it figured out for you.
-Mike
Tactrix
mikeyPSF is offline   Reply With Quote
How to Make an STI Look Like a Sleeper? FostersAFB General Community 92 10-12-2017 09:24 PM
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 09:26 AM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 08:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 02:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 03:28 PM
