Welcome to the North American Subaru Impreza Owners Club Sunday June 24, 2018
Old 07-16-2017, 08:34 AM   #1
Boxerscoopy90
Member#: 309974
Default Perrin rear speherical bearing endlinks
Just bought these from a friend they were in his 06wrx. But it seems like the upper bearing moves so easily which is bad i think. And idea if i can replace these or convert it to a bushing as i read here that these become very noisy by time
Boxerscoopy90 is offline   Reply With Quote
Old 07-16-2017, 10:21 AM   #2
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
You can get replacement sphericals from PERRIN.
Old 07-16-2017, 12:04 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Did you ever think that maybe 3 are stuck in position? They should not be real hard to move around, but they shouldn't bang around in the bore.
Old 07-17-2017, 03:10 PM   #4
lpxltt
Member#: 395574
2007 OBS
Spherical stuff really isn't the best idea for a DD. They don't last too long without making a whole bunch of noise. The issue is compounded if the car sees any snow and salt.
I had them on my 03 when I bought it. I repaired them because they were about the same cost of OEM endlinks but they failed again in less 20k.
lpxltt is offline   Reply With Quote
Old 07-17-2017, 04:00 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Hmmmm.....my Poltecs were bought when they first came out and they had a group buy, still going fine with a once a year spray of lube. Yes, they see year round use as well as salt.
Out of curiosity, Iooked up when I bought my Poltecs, it was over 13 years ago.....http://www.newtonnet.co.uk/coupe/GK-...PDF/ETM-SD.pdf
Old 07-18-2017, 11:18 PM   #6
Boxerscoopy90
Member#: 309974
I read so many reviews on sphericals that its not the best on the streets and they always become noisy by time. im asking if i can remove sphericals and add bushings ?
Old 07-19-2017, 08:02 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Probably, but finding a suitable bushing and installing it, may be faster/cheaper/easier to just buy a set made with bushings. The holes are likely different sizes thus requiring machining or fitting.
