05-14-2014, 07:29 PM | #26 |
Member#: 287701
Vehicle:2015 WRX WRB |
05-14-2014, 11:27 PM | #27 |
Member#: 386441
did you guys disable the DRL?
05-15-2014, 07:31 PM | #28 |
Member#: 387955
05-15-2014, 09:00 PM | #29 |
Member#: 306501
Vehicle:2015 Subaru WRX White |
05-15-2014, 09:16 PM | #30 |
Member#: 389886
Can we get some more exhaust video clips
05-17-2014, 02:54 AM | #31 |
Member#: 386441
Very cool - Thanks for the update. I think I too will disable my DRL's, at least until people can figure out how to make the C light the DRL instead (if it's possible at all)
05-18-2014, 12:42 PM | #32 |
Member#: 387955
We are using a Greddy Evo 3 cat-back from the GR chassis. It works, but it does not fit. A couple hangers are a bit short and the exhaust tips rub ever so slightly on the OEM diffuser, so they melted the inner corners. We are testing quite a few to see what works and what doesn't, but we assume that most manufacturers will have to make some tweaks to their cat-backs for this car.
Otherwise, if you don't mind that stuff, works just fine Working on it, we promise! Also, we just wrapped up filming our other project Bar & Track with the WRX as our feature car. We'll have the WRX on track and be down in Omaha's Old Market for the episode. Check out the preview If you are interested in the show, you can check out first full episode where we are at Road Atlanta. That will give you an idea of what we are doing with the WRX Last edited by Subi Speed; 05-18-2014 at 12:49 PM. |
05-20-2014, 04:34 PM | #33 |
Member#: 387955
05-21-2014, 05:01 PM | #34 |
Member#: 387955
We got some new wheels in.... WedsSports SA-10R 18x9.5+38 in Hankook RS3 265/35/18 |
05-21-2014, 05:05 PM | #35 |
Member#: 386441
Wow those are the rims I was looking at. Do you guys rub with that offset? Looks great!
05-21-2014, 07:55 PM | #36 |
Member#: 48025
Vehicle:24 FL5 CTR Champ White |
Great job on the C light vid guys!
05-21-2014, 09:22 PM | #37 |
Member#: 247999
Vehicle:2015 WRX Limited Crystal White Pearl |
Wow! Loving those WedsSport wheels. Curious about the rub as well. Throw the lower lip in the front and it will look fantastic!
05-23-2014, 09:03 AM | #38 | ||
Member#: 387955
Thank you for watching! More to come |
05-23-2014, 04:56 PM | #39 |
Member#: 306733
Vehicle:2016 Forester 6MT Silver |
Those wheels look awesome!
05-24-2014, 04:22 PM | #40 |
Member#: 359679
Vehicle:2006 Impreza 2.5i Red |
Love the car
05-25-2014, 09:25 PM | #41 |
Member#: 391068
RMIC
Vehicle:2015 WRX Limited WRB |
Any idea how much those WedsSports weigh? Also, can you guys get a shot looking down from the fenders to show poke?
05-26-2014, 05:07 PM | #42 | |
Member#: 387955
How is this for a shot? Don't have one going from the front, but it should give you an idea. |
05-26-2014, 05:09 PM | #43 |
Member#: 387955
A Little snippet from our lighting thread that you can follow here, as well.
http://forums.nasioc.com/forums/show....php?t=2633423 Now that we got these 2015 models out in the wild, it's time to start modifying.... Not much has been released for these cars in terms of performance and exterior styling, so in the meantime, we can get started on some lighting upgrades. We hope these videos will help you guys out on installing and choosing what lighting upgrades you'll be doing to your 2015 WRX or 2015 STI. Let's start off with fog lights... Install video |
05-26-2014, 08:29 PM | #44 |
Member#: 391068
RMIC
Awesome! Any issues rubbing the splash guard under the turbo skid plate at this height? Thinking about using this exact set up except maybe SA-55M blue instead. Might be a little too expensive for a daily driver though...
05-27-2014, 07:32 PM | #45 | |
Member#: 387955
Put on an Invidia Q300 this past weekend too |
05-27-2014, 08:08 PM | #46 |
Member#: 391068
RMIC
So now that you've tried the Greddy Evo 3, Perrin resonated quad tip, and Invidia Q300 TI quad tip; Which do you guys think sounds the best and why?
05-28-2014, 07:44 AM | #47 |
Member#: 389296
Vehicle:2015 WRX Limited 6MT ISM |
05-29-2014, 03:13 PM | #48 |
Member#: 387955
Yo's back again to show you guys how to get rid of those halogen DRLs.....
Install Video http://youtu.be/-ISnOjtCBYI |
05-29-2014, 04:57 PM | #49 | |
Member#: 387955
So far I like the look of the Greddy the best, and the Q300 for sound. More to come on this though. |
05-29-2014, 07:04 PM | #50 |
Member#: 389749
BAIC
Vehicle:2015 WRX |
I thought you couldn't use LED's as DRL's, since the DRL resistor causes the regular halogen high-beam bulb to run at approximately half-power when in DRL mode. As LED's have such low power draws to begin with, it won't be noticeable in the day; how is it operating in your above picture at such brightness? My guess is you don't have it in DRL mode at all, but you are showing us the high-beam turned on?
