07-06-2012, 06:25 PM | #1 |
Member#: 91757
SCIC
Vehicle:2013 Limited BRZ Dark Gray |
Clunking noise
I've noticed sometimes when I'm shifting into first gear there would be a clunk every so often. It only happens when I'm going into first gear. Has anyone else experienced this? I emailed the dealer asking about it and the guy told me every single BRZ he's driven does that.
07-06-2012, 07:02 PM | #2 |
Member#: 159474
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
This has DEFINITELY been discussed here, but I'm having trouble finding the thread. I'm sure it's in this BRZ Forum, though. I'll keep checking.
07-06-2012, 07:08 PM | #3 | |
Member#: 174268
Vehicle:2002 WRX |
This was covered in the May techtalk newsletter
07-06-2012, 07:09 PM | #4 |
Member#: 159474
Exactly what I was looking for! Thanks, spacey!
07-06-2012, 07:10 PM | #5 |
Member#: 91757
SCIC
Thanks so much! It's been making me paranoid so thanks for clearing that up for me
07-06-2012, 08:35 PM | #6 |
Member#: 44501
Vehicle:that 's, like, your alternate facts, man. |
I'm glad Toyota could put some Subaru-style farm equipment noises into the BRZ to remind everyone that it's still a Subaru at heart.
07-09-2012, 05:03 PM | #7 |
Member#: 250984
TXIC
Vehicle:2013 WRB BRZ Goodbye Bugeye |
Nice. I too was wondering the same about the clunk. Also, with the radio off I noticed the tranny makes a lot of gear noise similar to an STi, even though its a Toyota tranny.
07-09-2012, 05:35 PM | #8 |
Member#: 44501
That's probably due to stiff mounts (wild guess).
07-10-2012, 01:50 PM | #9 |
Member#: 150248
SCIC
Vehicle:08 FXT Sports WRB |
Anyone else notice a bit of "groaning" from the rear when taking off from a stop? It's most noticable when the car has been sitting. Not quite a shudder, but I can feel it and barely hear it. LSD maybe? It happens when starting in a straight line as well as turning (like getting out of a parking space).
So far nothing has fallen apart and it sounds like just another one of those quirky Subaru noises. |
08-14-2012, 01:29 AM | #10 |
Member#: 328667
has the same problem for the transmission
08-14-2012, 01:31 AM | #11 |
Member#: 328667
that's the only issue i have so far and dislike.the clunking noise in first gear!
08-14-2012, 01:33 AM | #12 |
Member#: 328667
Is it really a common problem for every BRZ/FRS though?
08-14-2012, 11:47 AM | #13 |
Member#: 150248
SCIC
Did you read post #3? It's normal.
08-14-2012, 03:43 PM | #14 |
Member#: 328667
I know but just can't believe that and I really wanna confirm w owners.
08-14-2012, 04:49 PM | #15 |
Member#: 150248
SCIC
Well, I'm at over 5000 miles and I can confirm.
I believe Kartboy is working on trans bushings to help. Push the clutch pedal in for a few sec before shifting into 1st. |
08-14-2012, 05:06 PM | #16 |
Member#: 174268
Vehicle:2002 WRX |
I find that leaving the shifter in gear when coming to a stop helps. this way the output shaft is still connected to the wheels when they stop, so it stops instead of spinning freely which causes the clunk
08-14-2012, 08:44 PM | #17 |
Member#: 328667
already thx for the input.
08-14-2012, 09:40 PM | #18 | |
Member#: 13339
E. Canada
Vehicle:2014 SWP WRX Wagon White |
08-15-2012, 12:10 AM | #19 |
Member#: 198231
Vehicle:2007 Not a Subaru |
I hate it but sadly I'm used to it. My Genesis Coupe did it as well.
08-15-2012, 07:38 AM | #20 |
Member#: 34228
Vehicle:13 BRZ WRB |
As long as it's normal and nothing is being damaged I'm fine with it.
08-15-2012, 02:56 PM | #21 |
Member#: 250984
TXIC
This is correct. I have noticed a couple other noises on mine that bug me, not sure if they are normal or not. My trans makes a medium-loud whirring sound when the car is warmed up and I let off the clutch while in neutral at a stand still. Sounds like a throw out bearing, it started at around 3k miles. Anyone else hearing this?
08-15-2012, 03:03 PM | #22 |
Member#: 198231
I don't think I have this but I have 10% the miles you do.
08-15-2012, 03:08 PM | #23 |
Member#: 174268
Vehicle:2002 WRX |
Mine hasn't done that, I'll listen for it. I usually have the radio on so I don't really pick up on these things.
