#1 |
Member#: 192990
Vehicle:2012 Impreza WRX Satin White Pearl |
![]() Long overdue but what else are you gonna do during a pandemic?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Mod List: Engine/Power: Blouch XTR 1.5 twin scroll Andrewtech Automotive built motor Closed deck short block Manley forged pistons & rods Titanium valve springs Grimmspeed TMIC AEM CAI IAG AOS ID 1000cc injectors Walbro fuel pump IAG fuel rails, fuel lines IAG TVG delete IAG airpump delete Aeromotive FPR Custom twinscroll DP with thermal coating Tomei expreme twinscroll exhaust header Grimmspeed 3 port EBCS Grimmspeed resonated exhaust Turbo XS tuned: dynapack 365whp 357lb/ft torque Suspension/Brakes/Driveline: Bilstein struts/RCE blacks Whiteline 22mm F/R sway bar Kartboy F/Rendlinks Whiteline - subframe, ALK, transmission, steering rack, rear diff, RCA, front LCA bushings Circuit motorsport 4 point H brace Cusco rear LCA SS brake lines Grimmspeed master cylinder brace Circuit motorsport clutch brace Verus engineering gas pedal relocation bracket/brace Exterior CS style front lip CS style rear spat S206 style side skirt HT Auto rear diffuser OEM exhaust finisher $10 amazon CF vinyl + covid-19 = random vinyl wrapped parts 720 form 18x9 wheels Firestone firehawk indy 500 265/35/18 Muteki lug nuts Grimmspeed license plate relocation Lightwerkz custom headlight gunmetal paint job morimoto retrofit HID projectors and HID kit morimoto LED fog lights Custom made "Fujiwara Tofu Shop" front plate delete OEM moonroof visor Auto Vent Shade rain guard Hella supertones **beep beep** Interior Cobb short shifter Raceseng shift knob SMY cluster with Prosport boost & Oil pressure gauge alcantara shift and ebrake boot
#2 |
Member#: 431618
SWIC
![]() Pics aren't loading for me. Are you using NASIOC's image host?
#3 |
Member#: 192990
#4 |
Member#: 507933
BAIC
Vehicle:2013 WRX Base Hatch Obsidian Black Pearl |
![]() super sexy, i'm on rce blacks too but on 17 235 wheels and my car doesn't look anywhere near as low as yours,
#5 |
Member#: 369934
Vehicle:2018 STI Limited Heritage Blue |
![]() Looks good, is the twinscoll set up tuned on pump gas?
#6 |
Member#: 192990
![]() pics of the build via Andrewtech!
#7 |
Member#: 192990
![]() couple more
#8 |
Member#: 192990
![]() yea I think it has to do with when GTWORX designed the strut with bilstein they must have used a 08-10 wrx strut. Apparently the spring perch sits lower on those than the 11-14 wrx so it gets even lower. What struts are you on?
#9 |
Member#: 192990
