Welcome to the North American Subaru Impreza Owners Club Tuesday January 19, 2021
Old 08-15-2020, 04:08 PM   #1
makikogi
Member#: 192990
2012 Impreza WRX
Default My 2012 wrx daily
Long overdue but what else are you gonna do during a pandemic?
Mod List:
Engine/Power:
Blouch XTR 1.5 twin scroll
Andrewtech Automotive built motor
Closed deck short block
Manley forged pistons & rods
Titanium valve springs
Grimmspeed TMIC
AEM CAI
IAG AOS
ID 1000cc injectors
Walbro fuel pump
IAG fuel rails, fuel lines
IAG TVG delete
IAG airpump delete
Aeromotive FPR
Custom twinscroll DP with thermal coating
Tomei expreme twinscroll exhaust header
Grimmspeed 3 port EBCS
Grimmspeed resonated exhaust
Turbo XS tuned: dynapack 365whp 357lb/ft torque
Suspension/Brakes/Driveline:
Bilstein struts/RCE blacks
Whiteline 22mm F/R sway bar
Kartboy F/Rendlinks
Whiteline - subframe, ALK, transmission, steering rack, rear diff, RCA, front LCA bushings
Circuit motorsport 4 point H brace
Cusco rear LCA
SS brake lines
Grimmspeed master cylinder brace
Circuit motorsport clutch brace
Verus engineering gas pedal relocation bracket/brace
Exterior
CS style front lip
CS style rear spat
S206 style side skirt
HT Auto rear diffuser
OEM exhaust finisher
$10 amazon CF vinyl + covid-19 = random vinyl wrapped parts
720 form 18x9 wheels
Firestone firehawk indy 500 265/35/18
Muteki lug nuts
Grimmspeed license plate relocation
Lightwerkz custom headlight gunmetal paint job
morimoto retrofit HID projectors and HID kit
morimoto LED fog lights
Custom made "Fujiwara Tofu Shop" front plate delete
OEM moonroof visor
Auto Vent Shade rain guard
Hella supertones **beep beep**
Interior
Cobb short shifter
Raceseng shift knob
SMY cluster with Prosport boost & Oil pressure gauge
alcantara shift and ebrake boot
makikogi is offline   Reply With Quote
Old 08-15-2020, 04:34 PM   #2
CoronaWRX
Member#: 431618
Pics aren't loading for me. Are you using NASIOC's image host?
CoronaWRX is offline   Reply With Quote
Old 08-15-2020, 06:08 PM   #3
makikogi
Member#: 192990
2012 Impreza WRX
Now they are, thanks corona. It's been awhile since I posted
Old 08-22-2020, 10:26 AM   #4
jeffambo
Member#: 507933
2013 WRX Base Hatch
Obsidian Black Pearl
super sexy, i'm on rce blacks too but on 17 235 wheels and my car doesn't look anywhere near as low as yours,
jeffambo is offline   Reply With Quote
Old 08-22-2020, 02:20 PM   #5
Chief_WRX
Member#: 369934
2018 STI Limited
Heritage Blue
Looks good, is the twinscoll set up tuned on pump gas?
Chief_WRX is offline   Reply With Quote
Old 08-24-2020, 10:00 PM   #6
makikogi
Member#: 192990
2012 Impreza WRX
pics of the build via Andrewtech!
Old 08-24-2020, 10:01 PM   #7
makikogi
Member#: 192990
2012 Impreza WRX
couple more
Old 08-24-2020, 10:04 PM   #8
makikogi
Member#: 192990
2012 Impreza WRX
yea I think it has to do with when GTWORX designed the strut with bilstein they must have used a 08-10 wrx strut. Apparently the spring perch sits lower on those than the 11-14 wrx so it gets even lower. What struts are you on?
Old 08-24-2020, 10:10 PM   #9
makikogi
Member#: 192990
2012 Impreza WRX
Thank you sir, yes pump gas. There isn't really an e85 gas station near where I live or work, so until they start popping up more I'll keep my car on pump gas
