Welcome to the North American Subaru Impreza Owners Club Thursday January 28, 2021
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 12-07-2018, 08:09 AM   #1226
IronmanDaremo
Member#: 461956
2017 WRX Premium
Originally Posted by IronmanDaremo View Post
2017 WRX Premium, 10k miles
SRS resonated J-pipe
Torque Solution TGV deletes
Torque Solution EGR delete
Grimmspeed 3-port EBCS
Boomba BPV
Cobb AP V3
e-tuned by Clark Turner tuning
Virtual dyno of my latest 3rd gear pull I sent for tweaking. Had to zoom in for the chart because it rocketed up to 41000hp on the plot for some reason at redline. SAE corrected, 279whp/318wtq. Uncorrected it was 290whp/328wtq.
Stock everything else.
(Not sure why the image isn't working).
Added Grimmspeed stealth intake and Perrin charge pipe last month.
Re-tuned through Clark Turner Tuning again for the new parts.
SAE corrected, 292whp/339wtq. Uncorrected, obviously higher (302/353 I think it was).
Super happy with the mods and the tuning.
Some day next season, I'll get it out to the strip and do a few runs to get an idea of what it can do.
IronmanDaremo is offline   Reply With Quote
Old 12-07-2018, 08:31 AM   #1227
undyjr
Member#: 459692
2019 WRX STI
silica black
That torque sure does come in soon. I wonder if the torque curve would look the same on a real dyno?
undyjr is offline   Reply With Quote
Old 12-07-2018, 08:42 AM   #1228
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
No it wouldn’t.
Better loading on the street and look at where the pull starts. I’d bet that’s able 3200 rpm on a 2500 rpm dyno pull
simpleJ is offline   Reply With Quote
Old 12-07-2018, 08:54 AM   #1229
IronmanDaremo
Member#: 461956
2017 WRX Premium
In my limited experience, Clark likes to e-tune his WOT with a 2k - 5k pull the first few times, and then once things are more in line, he asks for a full WOT pull. This plot was from when he sent my final map revision and I did a pull at the same location I use for all of the WOT ones.
For all of my pulls, there has always been a spike at the beginning, and then a taper as RPMs go up.
What I like is that it is a relatively even rate, not a flat torque line, but at least consistent, so the power is fairly linear (in the overall sense).
Old 04-30-2019, 09:11 AM   #1230
IronmanDaremo
Member#: 461956
2017 WRX Premium
New mods, new plot.
Added in a GS TMIC and Invidia Q300 single exit cat-back. Clark Turner Tuning re-tune for new mods. 21psi boost.
So now, full bolt-ons except for header. 313whp/339wtq on virtual dyno from a run yesterday.
Old 04-30-2019, 01:38 PM   #1231
Rexy18
Member#: 500337
New mods, new plot.
Did you ask for that dip at 3500 or does that come as part of the package?
Otherwise great numbers, what is this on, 93oct?
Rexy18 is offline   Reply With Quote
Old 04-30-2019, 01:55 PM   #1232
MZR2FA20DIT
Member#: 426776
2016 WRX
lapis blue pearl
Keep in mind that is a virtual dyno plot.
MZR2FA20DIT is offline   Reply With Quote
Old 04-30-2019, 02:15 PM   #1233
IronmanDaremo
Member#: 461956
2017 WRX Premium
Yes, virtual dyno (VD), so it is road loading, not dyno loading. I've had that spike at the start on all of the plots/runs on VD. So I guess, my peak wtq is probably a bit lower that what it shows. Still would be around 330wtq instead of the spike at 339wtq based on the chart.
I've also always had that dip. Boost is consistent at 20 - 22 on a normal weather day. Clark said he does not like to increase boost over that on a 93 map. And I have no intention of going FF as there is limited around in my area (at least that I would get to on a regular basis).
Old 04-30-2019, 02:35 PM   #1234
Rexy18
Member#: 500337
So what if its vd?
I dont have a dip now post tune but i had one before on my vd too. Its got nothing to do with vd or road vs dyno but with the tune itself. You***8217;ve always had it and your tuner should have tuned it down a bit to spike less and later so its more linear instead of oem-ish roller coaster ride.
Thats just coming from a layman who can look at a chart. Go look back and see how some other vd curves are ***8220;smoother***8221; so to speak. You must feel it under wot as violent spike then loss of power before more pull.. i mean nothing happens for 5-600rpm.
Old 04-30-2019, 02:58 PM   #1235
IronmanDaremo
Member#: 461956
2017 WRX Premium
Definitely do not feel it that much.
I'll ask Clark to see if he can do anything about it, or if he is concerned. He's analyzing the logs, so I put my trust in him to do what he thinks is best. It is what I'm paying him for after all. :shrugs:
Old 04-30-2019, 03:11 PM   #1236
Rexy18
Member#: 500337
Im not saying there is cause for concern.. I***8217;d just like a smoother line, not rollercoaster, you know.
Old 04-30-2019, 03:34 PM   #1237
IronmanDaremo
Member#: 461956
2017 WRX Premium
True.
I flipped through the thread, and there seem to be a lot of them with the "surge" at the 3000 - 3500 range. Maybe not quite as obvious as mine (although some were), but a noticeable amount.
I'm happy with the tune overall, but it is certainly worth asking the question.
Old 04-30-2019, 04:06 PM   #1238
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
Im not saying there is cause for concern.. I’d just like a smoother line, not rollercoaster, you know.
Can you post your VD plot? With zero smoothing preferably.
GlarryHoodDIT is offline   Reply With Quote
Old 04-30-2019, 04:39 PM   #1239
Rexy18
Member#: 500337
I could. But you dont know what you’re asking for “with 0 smoothing preferably.” I doubt any of these graphs are with zero smoothing.
So picture a vtach ecg sloped about 30-35deg, thats my chart with zero smoothing.
For all others, just go back one page and look at Rons e50 chart. Thats what it looks like. Almost as if drown by a ruler but with a slight curvature.
My protune doesnt dip like my oem tune did. Thats the point of the protune, it isnt just chasing numbers.
Old 04-30-2019, 04:54 PM   #1240
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
I know exactly what I'm asking for.
If you cant or wont post your plot that's fine, just curious what you're afraid of.
Old 04-30-2019, 05:55 PM   #1241
Rexy18
Member#: 500337
I cant cuz i am at work. But i already told you what it looks like with 0 smoothing, slanted ventricular tachycardia. It also shows i have 700whp+.
When i get home i can post a smoothing 1 or 2 factor, but it looks like all of Rons dyno charts, so not sure what you’re trying to get at? It doesnt have any dips until well past 6000rpm.
Im not trying to show off, im just telling a forum member that id expect a smoother curve paying for a protune instead of oem tune bumped up in power.
Old 04-30-2019, 06:12 PM   #1242
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
It sounds like you have absolutely no idea what you're talking about. Smoothing doesnt change curves that drastically, especially a factor of 1 or 2. Smoothing definitely doesnt account for a change of 100s of whp, maybe 10-15 on the high end. Sounds like you've made some pretty massive mistakes with your VD plots.
That's exactly what you're doing. You come posting about how awesome your VD lines are and how crap his are, then refuse to provide your own plot. At this point I dont even think you'll post your own plot, you'll dig through the thread to find one that matches your requirements and pass that off as your own.
You're like Stija reincarnated. Yesterday you post about how new and confused you are with the platform, today you're an expert.
Old 04-30-2019, 06:22 PM   #1243
Rexy18
Member#: 500337
Sarcasm. To some of your stupid posts as well as others.
Oh i will post it with 0 smoothing just to prove you wrong. Then you can tell me what i did wrong with my vd, cuz naturally i dont know how to use it.
I enjoy reading your posts by the way, there is always an impression you leave as if you know what you’re talking about. But you haven’t a clue what you’re saying 8/10 times, just angry opinions/rants.
Like this for instance. But i can’t wait to learn what i did wrong. Excited.
Old 04-30-2019, 06:49 PM   #1244
Rexy18
Member#: 500337
https://images.app.goo.gl/Eo1smrL35Bs5gbJt5
Actually i changed my mind. Because at home I***8217;m on my own time and my policies and procedures at home do not permit me to waste time on random internet trolls. So i wasted time at work (already wasting anyway) to include this dyno chart with 0 smoothing. Dont know what car since its for educational purposes. But my dyno chart with 0 smoothing looks even worse and more jagged.. couldnt find a worse one than that so i included the closest thing.
So what you see but more dips and cliffs, like vtach as i already mentioned, that***8217;s what my dyno looks with sm0. So this but worse, much worse.
When i get home i will post a dyno chart with smoothing 1 or 2 for comparison reasons with Ironman. I may even plot the oem dyno (if i can find it) so he can see that the oem tune is very similar to his chart and completely different than my current line by Ron.
Old 04-30-2019, 08:32 PM   #1245
curiousfish
Member#: 89283
2017 WRX Premium
ISM
2017 WRX manual, 3rd gear, Mustang dyno
Stock numbers typically 22X WHP, 24X WTQ
Cobb turboback, Cobb EBCS, Cobb intake, IAG TGV delete, TP EGR delete, TurboXS TMIC, Perrin charge pipe
Tuner is Calvin Dotson
[IMG]Scan10001 by [url=https://www.flickr.com/photos/[email protected]/][/IMG]
curiousfish is offline   Reply With Quote
Old 05-13-2019, 10:22 AM   #1246
Rexy18
Member#: 500337
Glarry, a smoothing 0 graph, took me a while cuz i had to reinstall vd new version and that didnt work as i intended.
The other one is smoothing 1 and has no dips as discussed earlier w a member here. Two different tuners but both stage 2 e50 and e60. So what were you trying to illustrate with sm0?
Old 05-13-2019, 12:49 PM   #1247
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Facility: Boost Controlled Performance
Type of Dyno: Dynojet
Baseline #'s: N/A - 220whp-ish vDyno
Peak HP: 349
Peak Torque: 317 - Per my request to keep low end torque down.
Fuel: E85 (E60 capped)
Peak HP: 282
Peak Torque: 271
Fuel: 93 Octane
2017 WRX - 12,500 Miles
Stock Motor / Trans / Clutch
Engine Mods:
COBB Accessport
Grimmspeed J-Pipe
Grimmspeed Intake
Grimmspeed TMIC
Grimmspeed Charge Pipe
PRL TGV/EGR Delete Kit
COBB Flex Fuel
DeatschWerks DW65c Fuel Pump
https://i.imgur.com/P7tbeOm.jpg
gn4rwhals is offline   Reply With Quote
Old 05-13-2019, 01:11 PM   #1248
Straight6
Member#: 419593
Straight6 is offline   Reply With Quote
Old 05-24-2019, 04:56 PM   #1249
h3llsp4wn
Member#: 373546
2015 wrx limited
crystal black
What kind of life span do these IAG and built motors have? I know thats pretty broad statement, but most of these builds seem to be around the 400-450whp mark. Just curious what kind of longevity people are seeing assuming they drive the car responsibly?
h3llsp4wn is offline   Reply With Quote
Old 05-24-2019, 06:41 PM   #1250
Straight6
Member#: 419593
Hard to say. There is a built motor forum where I came across FA20 discussions but there is just so many factors involved that can determine durability.
